I was told you are behind grub-tools. I know I shouldn’t be posting here as it isn’t directly tied to EOS. But I am building my own Distro and want to integrate it coz I am annoyed by the Linux Linux, with Linux linux crap.
Now if I use the grub-fix-initrd-generation script alone as standalone to execute during build process it works but without proper hooks it will break. So I built and installed directly from gitlab still not working. Can we work together to see why ?
I can try to help some.
The grub-tools package includes a hook file for eos-grub-fix-initrd-generation.
Did you use that?
And could you show the problem exactly and in full detail (all commands and outputs etc.)?
I git clone from EOS gitlab makepkg and install is all I do. I update Grub nothing changes…
I tried adding package to my ISO it installs no errors but grub don’t change xD
I have the feeling that grub-fix-initrd-generation is not running post install … Is there a way to force it to run in pkgbuild or something, like install and run ?
The only way I could get it to work is by integrating grub-tools into ISO as well as renaming grub-fix-initrd-generation to grubfix putting it in usr/local/bin and make Calamares execute it at the end of installation… That way works perfectly but os-prober or grub did not get an update for a while so dunno yet if it’s 100%
A pacman hook (like eos-grub-fix-initrd-generation.hook) can trigger the run when a related package is installed, updated, or removed.
See man alpm-hooks
I hope I understood your question correctly, and hopefully this answers it.
Yeah I figured as much. So until such an event occurs it will not be triggered. Simply installing it will do nothing. That’s why I made it so main script is triggered during Distro installation as well as including full package.
That way immediately fixed and will work on future. What do you think? Good?
