sirmud
October 31, 2022, 1:28pm
1
My grub is not booting. I was able to chroot but the commands that follow don’t seem to work. I followed these tutorials.
https://discovery.endeavouros.com/system-rescue/arch-chroot-for-efi-uefi-systems/2021/03/
and then I did this one and got stuck:
https://discovery.endeavouros.com/system-rescue/repair-a-non-booting-grub/2021/03/
I attached a picture. madad madad.
pebcak
October 31, 2022, 1:37pm
2
Your grub-install command is not correct.
You are using one for MBR/Legacy system.
You would need to use one adapted to the UEFI boot mode.
You have correctly mounted the relevant partitions and successfully chrooted into your installed system:
Just use:
grub-install
or the more elaborate one:
grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=enos-grub
Then regenerate grub.cfg:
Lastly, type exit to quit chroot and reboot.
Hopefully this will fix the Grub issue for you.
sirmud
October 31, 2022, 2:04pm
3
GOD BLESS YOU
Was stuck for an entire week. actually maybe longer. wohoooooo
pebcak
October 31, 2022, 2:10pm
4
Glad you got it sorted out!
Next time, don’t wait one week. Just post on the forum
And also, welcome to the community @sirmud
PS. please consider checking the solution box under the post pointing out the solution for the forum software to regard the topic as solved and for other users with similar issue to find the solution more easily.
Pudge
October 31, 2022, 4:58pm
5
Welcome to the EndeavourOS forum. I hope you enjoy your time here.
Pudge
