Hey everyone! Yesterday, I tried setting up an install of Nobara linux on a different drive than my Endeavor install. More specifically a partition of a windows drive which I had separated for ubuntu a long time ago. For some reason, although Nobara was installed correctly, Grub does not add a menu entry at the start, which makes the system unbootable as the efi partition is also being used by windows, which makes the drive boot to it on default instead of Nobara when trying to boot from bios.
os-prober does detect Nobara and Windows separately, but only the Windows boot manager option is added to the menu. Nobara is completely missing from any grub.cfg files.
Here’s the output of sudo grub-mkconfig -o /boot/grub/grub.cfg
Generating grub configuration file ...
Found theme: /usr/share/grub/themes/catppuccin-mocha-grub-theme/theme.txt
Found linux image: /boot/vmlinuz-linux
Found initrd image: /boot/amd-ucode.img /boot/initramfs-linux.img
Found fallback initrd image(s) in /boot: amd-ucode.img initramfs-linux-fallback.img
Found linux image: /boot/vmlinuz-linux65-tkg-pds-llvm
Found initrd image: /boot/amd-ucode.img /boot/initramfs-linux65-tkg-pds-llvm.img
Found fallback initrd image(s) in /boot: amd-ucode.img initramfs-linux65-tkg-pds-llvm-fallback.img
Warning: os-prober will be executed to detect other bootable partitions.
Its output will be used to detect bootable binaries on them and create new boot entries.
Found Windows Boot Manager on /dev/sda1@/efi/Microsoft/Boot/bootmgfw.efi
Found Nobara Linux 40 (GNOME Edition) on /dev/sda6
Adding boot menu entry for UEFI Firmware Settings ...
done
