I am new to Endeavor and new to bspwm. I just installed Endeavor. When I reboot my grub menu only shows endeavor (sda1) and not my Opensuse installation (sda2).
What do I need to do to fix this and why did this happen?
Thanks!!
Thanks!!
Hi! Welcome to the forum! ![]()
Is your issue because grub is not running os prober? ![]()
You may try this:
sudo nano /etc/default/grub
Go to the end of the file, and type this in a new line:
GRUB_DISABLE_OS_PROBER=false
Ctrl + s to save
Ctrl + x to exit
Now update Grub configuration:
It may take some time because os-prober is slow. Be patient!
Welcome to the forum @rmcellig
Thanks a million!! That worked!
I’m glad to be part of this forum!
welcome here
Welcome to the community
Welcome aboard @rmcellig
