Great stuff for 6.4
Interesting…well I mostly went through the very very extensive Spectacle bugs and decided my eyes are too tired for this.
If you’re using kde-unstable you’re probably aware that you also have to enable core-testing and extra-testing.
But maybe you’re just one of the kde-unstable only connoisseurs. Qt 6.9.1 is in extra testing, which also resulted in a new kwin-beta build in kde-unstable.
Don’t update kde-unstable/kwin without having received Qt 6.9.1…
Just as a heads up. I didn’t try, but I assume it will break.
I tried. Didn’t break for me.
Plasma 6.4 is out :partying_face:
Unless I missed it by mere minutes, Arch hasn’t let the floodgates open yet though :0
Some great stuff in the announcement :partying_face:
I have NONE! Gimme now! (lol)
Hurry, hurry, hurry - it’s in repos! :wink:
EDIT: success and new Firefox too
(140) Which somehow manages to break GTK window control buttons. :crying_cat:
It was perfectly integrated (breeze) until about an hour ago or so.
Downgrade return previous breeze styled buttons, but is not really an option.
Imgur
Does it? I didn’t notice… I use two finger swipe to navigate back and forth between pages and occasionally I need to close and reopen Firefox if that functionality isn’t working, but seems OK here. Do you have an example?
Sorry I was posting the scrot above.
But you can see there .. I have kate and gimp open to show GTK and QT matching .. but firefox is the lone standout having its own controls (the pink highlight is my own annotation).
I have had my own css in userChrome.css for various things and that included some styling for those controls but I’ve also checked removing it and a few related about:config options .. nothing seems to make it budge .. but 139 looked/looks as it should. As does firefox --ProfileManager.
Maybe something to just wait out. :crying_cat:
Updated :blush:.
I saw another linux-firmware updates.
Hmmm… still not sure. I changed widget.gtk.non-native-titlebar-buttons.enabled to False and restarted Firefox, but no difference (afterwards changed back to True):
Firefox is the back window and Kate is in front
I also have Plasma Integration installed as a Firefox add-on. How can I help you test?
Yes, that is one of the newer ones I tried to toggle.
In the past it did not exist and I relied on my own CSS.
Still no combination resulted in anything other than what must be the default embedded ff controls.
While yours seems to be properly presenting breeze controls.
I have tried a fresh profile as well.
This is a difference. I suppose I will try that.
Result: Did not seem to make a difference adding the extension and restarting.
Maybe it would be interesting to know if it followed any GTK theme setting.
Though what I am trying for here is breeze.
Just a double check - what firefox theme? Just the “System Theme / Auto” ?
Maybe I might ask about a few packages that are sometimes mentioned.. do you happen to have gnome-settings-daemon or gsettings-qt installed (I do not)?
System Theme - Auto is Enabled and Breeze system theming here
pacman -Qs gnome-settings —> No Results
pacman -Qs gsettings results in:
local/gsettings-desktop-schemas 48.0-1
    GSettings schemas for GNOME desktop components
local/gsettings-system-schemas 48.0-1
    GSettings schemas for GNOME system components
