Graphic problem of unknown origin
Hi.
Today I try to open a kdenlive project of less than 6 months, which used to work.
No graphism. Same for shotcut (image). When I double-click on the project monitor, it’s displayed fullscreen. It doesn’t do it here. Be it through packages, or the standalone program. I couldn’t try the appimage, because now none work either !
When I install something through packages, I would want all dependencies to get installed with it, and increasingly it’s not the case.
I tried the last version of everything.
no_graphics
I didn’t understand, please try to describe better your issue:
  • What are you doing and what do you expect to happen?
  • What’s happening instead?
  • Provide information about your installation:
    • Operating system and kernel
    • Desktop environment
    • KDEnlive version
  • In order to discard hardware or drivers issues, please provide your hardware information: inxi -Fxxc0z --no-host | eos-sendlog
With this information, surely one of the experts will be able to help.
Here's for you:
Kernel: 5.17.3-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
Desktop: sway v: 1.7 dm: N/A Distro: EndeavourOS base: Arch Linux
Type: Laptop System: LENOVO product: 80QR v: Lenovo B50-10
serial: Chassis: type: 10 v: Lenovo B50-10
serial:
Mobo: LENOVO model: Lenovo B50-10 v: No DPK serial:
UEFI-[Legacy]: LENOVO v: CCCN18WW(V2.04) date: 11/11/2015
Battery:
ID-1: BAT1 charge: 19.4 Wh (100.0%) condition: 19.4/23.8 Wh (81.6%)
volts: 12.3 min: 10.8 model: LENOVO PABAS0241231 serial:
status: full
Info: dual core model: Intel Celeron N2840 bits: 64 type: MCP
arch: Silvermont rev: 8 cache: L1: 112 KiB L2: 1024 KiB
Speed (MHz): avg: 2583 min/max: 500/2582 cores: 1: 2583 2: 2583
bogomips: 8671
Flags: ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
Device-1: Intel Atom Processor Z36xxx/Z37xxx Series Graphics & Display
vendor: Lenovo driver: i915 v: kernel ports: active: eDP-1
empty: DP-1,HDMI-A-1,VGA-1 bus-ID: 00:02.0 chip-ID: 8086:0f31
Device-2: Syntek Lenovo EasyCamera type: USB driver: uvcvideo
bus-ID: 1-3:4 chip-ID: 174f:1169
Display: wayland server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.1
compositor: sway v: 1.7 driver: X: loaded: intel unloaded: modesetting
alternate: fbdev,vesa gpu: i915 display-ID: 1
Monitor-1: eDP-1 model: ChiMei InnoLux 0x15c5 res: 1366x768 dpi: 101
diag: 394mm (15.5")
OpenGL: renderer: Mesa Intel HD Graphics (BYT) v: 4.2 Mesa 22.0.1
compat-v: 3.1 direct render: Yes
Device-1: Intel Atom Processor Z36xxx/Z37xxx Series High Definition Audio
vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:0f04
Sound Server-1: ALSA v: k5.17.3-arch1-1 running: yes
Sound Server-2: sndio v: N/A running: no
Sound Server-3: PulseAudio v: 15.0 running: no
Sound Server-4: PipeWire v: 0.3.50 running: yes
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Lenovo
driver: r8169 v: kernel pcie: speed: 2.5 GT/s lanes: 1 port: 2000
bus-ID: 03:00.0 chip-ID: 10ec:8136
IF: enp3s0 state: up speed: 100 Mbps duplex: full mac:
Device-2: Realtek RTL8723BE PCIe Wireless Network Adapter vendor: XAVi
driver: rtl8723be v: kernel pcie: speed: 2.5 GT/s lanes: 1 port: 1000
bus-ID: 04:00.0 chip-ID: 10ec:b723
IF: wlan0 state: down mac:
Bluetooth:
Device-1: Chicony Bluetooth (RTL8723BE) type: USB driver: btusb v: 0.8
bus-ID: 1-4:5 chip-ID: 04f2:b49f
Report: rfkill ID: hci0 rfk-id: 5 state: down bt-service: not found
Local Storage: total: 698.64 GiB used: 226.32 GiB (32.4%)
ID-1: /dev/sda vendor: Seagate model: ST750LM022 HN-M750MBB
size: 698.64 GiB speed: 3.0 Gb/s serial:
ID-1: / size: 677.94 GiB used: 225.56 GiB (33.3%) fs: ext4 dev: /dev/sda1
ID-1: swap-1 type: partition size: 8.8 GiB used: 780.4 MiB (8.7%)
priority: -2 dev: /dev/sda2
System Temperatures: cpu: 59.0 C mobo: N/A
Fan Speeds (RPM): N/A
Processes: 170 Uptime: 2d 6h 53m Memory: 7.65 GiB used: 3.21 GiB (41.9%)
Init: systemd v: 250 Compilers: gcc: 11.2.0 Packages: note: see --pkg
pacman: 1298 Shell: fish v: 3.4.1 running-in: foot inxi: 3.3.15
Linux 5.17.3-arch1-1 #1 SMP PREEMPT Thu, 14 Apr 2022 01:18:36 +0000 x86_64 GNU/Linux
Shotcut ARCH-22.03.30, kdenlive 21.12.3
I expect video editors to show footages or videos they produce in their monitor, as they used to do a few months ago on the same computer, and the same system (endeavour, though not the same version I suppose). They seem to process footages nonetheless but I can’t see them (green monitor) so I can’t edit $**t of course. Vlc and mpv do show read the rushs. And resulting edited video, or anything else.
I think the same shared library meant to display stuff on both of these editors is lacking or corrupted.
Try to start KDEnlive from terminal:
kdenlive &
Example screen capture
imagen
Note: The background is the video I’ve selected and double clicked on project monitor.
Do you see any errors on console when you double click on project monitor? If there are errors, please copy and paste them.
On my end works fine with MP4 videos and I’m using:
    Desktop: Cinnamon v: 5.2.7 tk: GTK v: 3.24.33 dm: LightDM
  Info: dual core model: Intel Core i5-5200U bits: 64 type: MT MCP
    arch: Broadwell rev: 4 cache: L1: 128 KiB L2: 512 KiB L3: 3 MiB
  Speed (MHz): avg: 972 high: 1243 min/max: 500/2700 cores: 1: 797 2: 944
    3: 1243 4: 905 bogomips: 17566
  Device-1: Intel HD Graphics 5500 vendor: Toshiba driver: i915 v: kernel
    ports: active: DP-1 off: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0
    chip-ID: 8086:1616
  Display: x11 server: X.Org v: 21.1.3 driver: X: loaded: intel
    unloaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0
    screens: 1
kdenlive 21.12.3
Entire command output
kdenlive Vidéos/projets\ vidéos/M11/m11p2.kdenlive
=== /// CANNOT ACCESS SPEECH DICTIONARIES FOLDER
mlt_repository_init: failed to dlopen /usr/lib/mlt-7/libmltrtaudio.so
(librtaudio.so.6: Ne peut ouvrir le fichier d’objet partagé: Aucun fichier ou dossier de ce type)
mlt_repository_init: failed to dlopen /usr/lib/mlt-7/libmltopencv.so
(libopencv_tracking.so.405: Ne peut ouvrir le fichier d’objet partagé: Aucun fichier ou dossier de ce type)
mlt_repository_init: failed to dlopen /usr/lib/mlt-7/libmltsox.so
(libsox.so.3: Ne peut ouvrir le fichier d’objet partagé: Aucun fichier ou dossier de ce type)
mlt_repository_init: failed to dlopen /usr/lib/mlt-7/libmltsdl.so
(libSDL-1.2.so.0: Ne peut ouvrir le fichier d’objet partagé: Aucun fichier ou dossier de ce type)
profilePath from KdenliveSetting::mltPath: “/usr/share/mlt-7/profiles”
meltPath from KdenliveSetting::rendererPath: “/usr/share/mlt-7/profiles”
Empty metadata for “deinterlace”
Empty metadata for “avcolour_space”
Empty metadata for “avcolor_space”
Empty metadata for “avdeinterlace”
Empty metadata for “swscale”
Empty metadata for “swresample”
Empty metadata for “audiochannels”
Empty metadata for “audioconvert”
Empty metadata for “imageconvert”
Empty metadata for “glsl.manager”
Empty metadata for “movit.convert”
Empty metadata for “movit.crop”
Empty metadata for “movit.resample”
Empty metadata for “movit.resize”
Empty metadata for “telecide”
plugin not available: “avfilter.acompressor”
plugin not available: “avfilter.aecho”
plugin not available: “avfilter.agate”
plugin not available: “avfilter.atadenoise”
plugin not available: “avfilter.bs2b”
plugin not available: “avfilter.bwdif”
plugin not available: “avfilter.deblock”
plugin not available: “avfilter.dedot”
plugin not available: “avfilter.deflate”
plugin not available: “avfilter.derain”
plugin not available: “avfilter.doubleweave”
plugin not available: “avfilter.field”
plugin not available: “avfilter.framestep”
plugin not available: “avfilter.fspp”
plugin not available: “avfilter.graphmonitor”
plugin not available: “avfilter.hqdn3d”
plugin not available: “avfilter.inflate”
plugin not available: “avfilter.lagfun”
plugin not available: “avfilter.loudnorm”
plugin not available: “avfilter.mcdeint”
plugin not available: “avfilter.random”
plugin not available: “avfilter.removegrain”
plugin not available: “avfilter.separatefields”
plugin not available: “avfilter.shuffleplanes”
plugin not available: “avfilter.sofalizer”
plugin not available: “avfilter.sr”
plugin not available: “avfilter.tmix”
plugin not available: “avfilter.w3fdif”
plugin not available: “avfilter.weave”
plugin not available: “avfilter.yadif”
plugin not available: “frei0r.baltan”
plugin not available: “frei0r.bgsubtract0r”
plugin not available: “frei0r.bigsh0t_eq_mask”
plugin not available: “frei0r.bigsh0t_eq_to_rect”
plugin not available: “frei0r.bigsh0t_hemi_to_eq”
plugin not available: “frei0r.bigsh0t_rect_to_eq”
plugin not available: “frei0r.bigsh0t_stabilize_360”
plugin not available: “frei0r.bigsh0t_transform_360”
plugin not available: “frei0r.delay0r”
plugin not available: “frei0r.delaygrab”
plugin not available: “frei0r.facebl0r”
plugin not available: “frei0r.facedetect”
plugin not available: “frei0r.lightgraffiti”
plugin not available: “ladspa”
plugin not available: “ladspa.9354877”
plugin not available: “movit.unsharp_mask”
plugin not available: “region”
plugin not available: “sox”
plugin not available: “timewarp”
plugin not available: “opencv.tracker”
kf.service.services: KServiceTypeTrader: serviceType “ThumbCreator” not found
“Could not convert argument 0 at”
“expression for text@qrc:/qml/assetList.qml:263”
“Passing incompatible arguments to C++ functions from JavaScript is dangerous and deprecated.”
“This will throw a JavaScript TypeError in future releases of Qt!”
file:///usr/lib/qt/qml/QtQuick/Controls/Private/TreeViewItemDelegateLoader.qml:85:9: Unable to assign [undefined] to int
file:///usr/lib/qt/qml/QtQuick/Controls/Private/TreeViewItemDelegateLoader.qml:86:9: Unable to assign [undefined] to bool
file:///usr/lib/qt/qml/QtQuick/Controls/Private/TreeViewItemDelegateLoader.qml:87:9: Unable to assign [undefined] to bool
file:///usr/lib/qt/qml/QtQuick/Controls/Private/TreeViewItemDelegateLoader.qml:88:9: Unable to assign [undefined] to bool
QWidget::setMinimumSize: (effect_list/QDockWidget) Negative sizes (0,-1) are not possible
QWidget::setMinimumSize: (transition_list/QDockWidget) Negative sizes (0,-1) are not possible
QObject::disconnect: Unexpected nullptr parameter
LOCALE: Document uses “.” as decimal point and “C” as locale
Searching for locale: Found QLocale(Oromo, Latin, Ethiopia) with match type 1
=== REG FOCUS: false
// ADDING MARKER AT POS: 1908 , FPS: 30
// ADDING MARKER AT POS: 12123 , FPS: 30
// ADDING MARKER AT POS: 12794 , FPS: 30
// ADDING MARKER AT POS: 20313 , FPS: 30
// ADDING MARKER AT POS: 21231 , FPS: 30
// ADDING MARKER AT POS: 26967 , FPS: 30
// ADDING MARKER AT POS: 28131 , FPS: 30
// ADDING MARKER AT POS: 30327 , FPS: 30
// ADDING MARKER AT POS: 31414 , FPS: 30
// ADDING MARKER AT POS: 35196 , FPS: 30
// ADDING MARKER AT POS: 35916 , FPS: 30
// ADDING MARKER AT POS: 39119 , FPS: 30
// ADDING MARKER AT POS: 39712 , FPS: 30
// ADDING MARKER AT POS: 40703 , FPS: 30
// ADDING MARKER AT POS: 16731 , FPS: 30
// ADDING MARKER AT POS: 7172 , FPS: 30
*- - REGISTERING MARKER: 1908
*- - REGISTERING MARKER: 12123
*- - REGISTERING MARKER: 12794
*- - REGISTERING MARKER: 20313
*- - REGISTERING MARKER: 21231
*- - REGISTERING MARKER: 26967
*- - REGISTERING MARKER: 28131
*- - REGISTERING MARKER: 30327
*- - REGISTERING MARKER: 31414
*- - REGISTERING MARKER: 35196
*- - REGISTERING MARKER: 35916
*- - REGISTERING MARKER: 39119
*- - REGISTERING MARKER: 39712
*- - REGISTERING MARKER: 40703
*- - REGISTERING MARKER: 16731
*- - REGISTERING MARKER: 7172
qrc:/qml/timeline.qml:2022:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo() { … }
========== STARTING TASK FOR: 2
========== STARTING TASK FOR: 3
// ADDING MARKER AT POS: 1687 , FPS: 30
READY FOR THUMB ClipType::Video
=== FOUND THUMB IN CACHe
READY FOR THUMB ClipType::Audio
::: REGISTERING CLIP TO BIN:::::
REGISTRATION 19 ptr count 3
*- - REGISTERING MARKER: 1687
qml: loaded clip: 0 , ID: 19 , index: 0 , TYPE: Audio
qml: loaded clip with Astream: 0
REGISTRATION 20 ptr count 3
qml: loaded clip: 489 , ID: 20 , index: 0 , TYPE: Audio
REGISTRATION 21 ptr count 3
qml: loaded clip: 3692 , ID: 21 , index: 0 , TYPE: Audio
REGISTRATION 22 ptr count 3
qml: loaded clip: 4285 , ID: 22 , index: 0 , TYPE: Audio
REGISTRATION 23 ptr count 3
qml: loaded clip: 5276 , ID: 23 , index: 0 , TYPE: Audio
REGISTRATION 24 ptr count 3
qml: loaded clip: 6233 , ID: 24 , index: 0 , TYPE: Audio
REGISTRATION 25 ptr count 3
qml: loaded clip: 7357 , ID: 25 , index: 0 , TYPE: Audio
REGISTRATION 26 ptr count 3
qml: loaded clip: 11632 , ID: 26 , index: 0 , TYPE: Audio
REGISTRATION 27 ptr count 3
qml: loaded clip: 14595 , ID: 27 , index: 0 , TYPE: Audio
REGISTRATION 28 ptr count 3
qml: loaded clip: 15234 , ID: 28 , index: 0 , TYPE: Audio
REGISTRATION 29 ptr count 3
qml: loaded clip: 20172 , ID: 29 , index: 0 , TYPE: Audio
REGISTRATION 30 ptr count 3
qml: loaded clip: 24795 , ID: 30 , index: 0 , TYPE: Audio
REGISTRATION 31 ptr count 3
qml: loaded clip: 25754 , ID: 31 , index: 0 , TYPE: Audio
REGISTRATION 32 ptr count 3
qml: loaded clip: 27368 , ID: 32 , index: 0 , TYPE: Audio
REGISTRATION 33 ptr count 3
qml: loaded clip: 27773 , ID: 33 , index: 0 , TYPE: Audio
REGISTRATION 34 ptr count 3
qml: loaded clip: 28148 , ID: 34 , index: 0 , TYPE: Audio
============= CLONED CLIP:
“<?xml version=\"1.0\" encoding=\"utf-8\"?>\n<mlt LC_NUMERIC="C" version="7.6.0" parent="producer0" in="0" out="213514"><producer id="producer0" in="0" out="213514"><property name="length">213515<property name="eof">pause<property name="resource">/home/drm/Vid\xC3\xA9os/projets vid\xC3\xA9os/M11/m11p1_M.wav<property name="seekable">1<property name="audio_index">0<property name="video_index">-1<property name="mute_on_pause">1<property name="mlt_service">avformat<property name="kdenlive:clipname"><property name="kdenlive:folderid">-1<property name="kdenlive:id">3<property name="kdenlive:file_size">1366497944<property name="kdenlive:file_hash">ee932ec6bae4a3ba8ee4e2d8168d1cff<property name="kdenlive:audio_max0">250<property name="kdenlive:markers">[\n {\n "comment": "00:00:56:07",\n "pos": 1687,\n "type": 0\n }\n]\n\n”
REGISTRATION 35 ptr count 3
qml: loaded clip: 28246 , ID: 35 , index: 0 , TYPE: Audio
REGISTRATION 36 ptr count 3
qml: loaded clip: 28268 , ID: 36 , index: 0 , TYPE: Audio
REGISTRATION 37 ptr count 3
qml: loaded clip: 28757 , ID: 37 , index: 0 , TYPE: Audio
REGISTRATION 38 ptr count 3
qml: loaded clip: 28777 , ID: 38 , index: 0 , TYPE: Audio
REGISTRATION 39 ptr count 3
qml: loaded clip: 29846 , ID: 39 , index: 0 , TYPE: Audio
REGISTRATION 40 ptr count 3
qml: loaded clip: 31382 , ID: 40 , index: 0 , TYPE: Audio
REGISTRATION 41 ptr count 3
qml: loaded clip: 33184 , ID: 41 , index: 0 , TYPE: Audio
REGISTRATION 42 ptr count 3
qml: loaded clip: 34295 , ID: 42 , index: 0 , TYPE: Audio
REGISTRATION 43 ptr count 3
qml: loaded clip: 35133 , ID: 43 , index: 0 , TYPE: Audio
REGISTRATION 44 ptr count 3
qml: loaded clip: 35628 , ID: 44 , index: 0 , TYPE: Audio
REGISTRATION 45 ptr count 3
qml: loaded clip: 37333 , ID: 45 , index: 0 , TYPE: Audio
REGISTRATION 46 ptr count 3
qml: loaded clip: 38065 , ID: 46 , index: 0 , TYPE: Audio
REGISTRATION 47 ptr count 3
qml: loaded clip: 38379 , ID: 47 , index: 0 , TYPE: Audio
REGISTRATION 48 ptr count 3
qml: loaded clip: 39715 , ID: 48 , index: 0 , TYPE: Audio
REGISTRATION 49 ptr count 3
qml: loaded clip: 44236 , ID: 49 , index: 0 , TYPE: Audio
REGISTRATION 50 ptr count 3
qml: loaded clip: 49157 , ID: 50 , index: 0 , TYPE: Audio
REGISTRATION 51 ptr count 3
qml: loaded clip: 50791 , ID: 51 , index: 0 , TYPE: Audio
REGISTRATION 52 ptr count 3
qml: loaded clip: 50823 , ID: 52 , index: 0 , TYPE: Audio
REGISTRATION 54 ptr count 3
qml: loaded clip: 0 , ID: 54 , index: 0 , TYPE: Video
qml: loaded clip with Astream: -1
REGISTRATION 55 ptr count 3
qml: loaded clip: 489 , ID: 55 , index: 0 , TYPE: Video
REGISTRATION 56 ptr count 3
qml: loaded clip: 3692 , ID: 56 , index: 0 , TYPE: Video
REGISTRATION 57 ptr count 3
qml: loaded clip: 4285 , ID: 57 , index: 0 , TYPE: Video
REGISTRATION 58 ptr count 3
qml: loaded clip: 5276 , ID: 58 , index: 0 , TYPE: Video
REGISTRATION 59 ptr count 3
qml: loaded clip: 6233 , ID: 59 , index: 0 , TYPE: Video
REGISTRATION 60 ptr count 3
qml: loaded clip: 7357 , ID: 60 , index: 0 , TYPE: Video
REGISTRATION 61 ptr count 3
qml: loaded clip: 11632 , ID: 61 , index: 0 , TYPE: Video
REGISTRATION 62 ptr count 3
qml: loaded clip: 14595 , ID: 62 , index: 0 , TYPE: Video
REGISTRATION 63 ptr count 3
qml: loaded clip: 15234 , ID: 63 , index: 0 , TYPE: Video
REGISTRATION 64 ptr count 3
qml: loaded clip: 20172 , ID: 64 , index: 0 , TYPE: Video
REGISTRATION 65 ptr count 3
qml: loaded clip: 24795 , ID: 65 , index: 0 , TYPE: Video
REGISTRATION 66 ptr count 3
qml: loaded clip: 25754 , ID: 66 , index: 0 , TYPE: Video
REGISTRATION 67 ptr count 3
qml: loaded clip: 27368 , ID: 67 , index: 0 , TYPE: Video
REGISTRATION 68 ptr count 3
qml: loaded clip: 27746 , ID: 68 , index: 0 , TYPE: Video
REGISTRATION 69 ptr count 3
qml: loaded clip: 27773 , ID: 69 , index: 0 , TYPE: Video
REGISTRATION 70 ptr count 3
qml: loaded clip: 28148 , ID: 70 , index: 0 , TYPE: Video
REGISTRATION 71 ptr count 3
qml: loaded clip: 28246 , ID: 71 , index: 0 , TYPE: Video
REGISTRATION 72 ptr count 3
qml: loaded clip: 28268 , ID: 72 , index: 0 , TYPE: Video
REGISTRATION 73 ptr count 3
qml: loaded clip: 28757 , ID: 73 , index: 0 , TYPE: Video
REGISTRATION 74 ptr count 3
qml: loaded clip: 28777 , ID: 74 , index: 0 , TYPE: Video
REGISTRATION 75 ptr count 3
qml: loaded clip: 29846 , ID: 75 , index: 0 , TYPE: Video
REGISTRATION 76 ptr count 3
qml: loaded clip: 31382 , ID: 76 , index: 0 , TYPE: Video
REGISTRATION 77 ptr count 3
qml: loaded clip: 33184 , ID: 77 , index: 0 , TYPE: Video
REGISTRATION 78 ptr count 3
qml: loaded clip: 34295 , ID: 78 , index: 0 , TYPE: Video
REGISTRATION 79 ptr count 3
qml: loaded clip: 35133 , ID: 79 , index: 0 , TYPE: Video
REGISTRATION 80 ptr count 3
qml: loaded clip: 35628 , ID: 80 , index: 0 , TYPE: Video
REGISTRATION 81 ptr count 3
qml: loaded clip: 37333 , ID: 81 , index: 0 , TYPE: Video
REGISTRATION 82 ptr count 3
qml: loaded clip: 38065 , ID: 82 , index: 0 , TYPE: Video
REGISTRATION 83 ptr count 3
qml: loaded clip: 38379 , ID: 83 , index: 0 , TYPE: Video
REGISTRATION 84 ptr count 3
qml: loaded clip: 39715 , ID: 84 , index: 0 , TYPE: Video
REGISTRATION 85 ptr count 3
qml: loaded clip: 44236 , ID: 85 , index: 0 , TYPE: Video
REGISTRATION 86 ptr count 3
qml: loaded clip: 49157 , ID: 86 , index: 0 , TYPE: Video
REGISTRATION 87 ptr count 3
qml: loaded clip: 50791 , ID: 87 , index: 0 , TYPE: Video
REGISTRATION 88 ptr count 3
qml: loaded clip: 50823 , ID: 88 , index: 0 , TYPE: Video
“qtcrop” : Setting parameter “rect” to “00:00:00.000=139 0 1280 720”
“qtcrop” : Setting parameter “radius” to “00:00:00.000=0”
“qtcrop” : Setting parameter “circle” to “0”
“qtcrop” : Setting parameter “color” to “0x00000000”
XML parsing of “qtcrop” . found 4 parameters
= = SET EFFECT PARAM: “rect” = 00:00:00.000=139 0 1280 720
= = SET EFFECT PARAM: “radius” = 00:00:00.000=0
= = SET EFFECT PARAM: “circle” = 0
= = SET EFFECT PARAM: “color” = 0x00000000
END parsing of “qtcrop” . Number of found parameters 4
Construct keyframemodellist. Checking model: false
Construct keyframemodel. Checking model: false
Found 1 , OUT: 51823 , animation properties: “00:00:00.000=139 0 1280 720”
ADD keyframe 0 QVariant(QString, “139 0 1280 720”) true
add lambda 0 QVariant(QString, “139 0 1280 720”) true
Found 1 , OUT: 51823 , animation properties: “00:00:00.000=0”
ADD keyframe 0 QVariant(double, 0) true
add lambda 0 QVariant(double, 0) true
“qtblend” : Setting parameter “rect” to “00:00:00.000=-73 0 1280 720 1.000000”
“qtblend” : Setting parameter “rotation” to “00:00:00.000=0”
“qtblend” : Setting parameter “compositing” to “0”
“qtblend” : Setting parameter “distort” to “0”
“qtblend” : Setting parameter “rotate_center” to “1”
XML parsing of “qtblend” . found 5 parameters
= = SET EFFECT PARAM: “rect” = 00:00:00.000=-73 0 1280 720 1.000000
= = SET EFFECT PARAM: “rotation” = 00:00:00.000=0
= = SET EFFECT PARAM: “compositing” = 0
= = SET EFFECT PARAM: “distort” = 0
= = SET EFFECT PARAM: “rotate_center” = 1
END parsing of “qtblend” . Number of found parameters 5
Found 1 , OUT: 51823 , animation properties: “00:00:00.000=-73 0 1280 720 1.000000”
ADD keyframe 0 QVariant(QString, “-73 0 1280 720 1.000000”) true
add lambda 0 QVariant(QString, “-73 0 1280 720 1.000000”) true
“mirror” : Setting parameter “mirror” to “flip”
“mirror” : Setting parameter “reverse” to “0”
XML parsing of “mirror” . found 2 parameters
= = SET EFFECT PARAM: “mirror” = flip
= = SET EFFECT PARAM: “reverse” = 0
END parsing of “mirror” . Number of found parameters 2
qml: loaded clip: 0 , ID: 54 , index: 1 , TYPE: Video
qml: loaded clip: 489 , ID: 55 , index: 1 , TYPE: Video
qml: loaded clip: 3692 , ID: 56 , index: 1 , TYPE: Video
qml: loaded clip: 4285 , ID: 57 , index: 1 , TYPE: Video
qml: loaded clip: 5276 , ID: 58 , index: 1 , TYPE: Video
qml: loaded clip: 6233 , ID: 59 , index: 1 , TYPE: Video
qml: loaded clip: 7357 , ID: 60 , index: 1 , TYPE: Video
qml: loaded clip: 11632 , ID: 61 , index: 1 , TYPE: Video
qml: loaded clip: 14595 , ID: 62 , index: 1 , TYPE: Video
qml: loaded clip: 15234 , ID: 63 , index: 1 , TYPE: Video
qml: loaded clip: 20172 , ID: 64 , index: 1 , TYPE: Video
qml: loaded clip: 24795 , ID: 65 , index: 1 , TYPE: Video
qml: loaded clip: 25754 , ID: 66 , index: 1 , TYPE: Video
qml: loaded clip: 27368 , ID: 67 , index: 1 , TYPE: Video
qml: loaded clip: 27746 , ID: 68 , index: 1 , TYPE: Video
qml: loaded clip: 27773 , ID: 69 , index: 1 , TYPE: Video
qml: loaded clip: 28148 , ID: 70 , index: 1 , TYPE: Video
qml: loaded clip: 28246 , ID: 71 , index: 1 , TYPE: Video
qml: loaded clip: 28268 , ID: 72 , index: 1 , TYPE: Video
qml: loaded clip: 28757 , ID: 73 , index: 1 , TYPE: Video
qml: loaded clip: 28777 , ID: 74 , index: 1 , TYPE: Video
qml: loaded clip: 29846 , ID: 75 , index: 1 , TYPE: Video
qml: loaded clip: 31382 , ID: 76 , index: 1 , TYPE: Video
qml: loaded clip: 33184 , ID: 77 , index: 1 , TYPE: Video
qml: loaded clip: 34295 , ID: 78 , index: 1 , TYPE: Video
qml: loaded clip: 35133 , ID: 79 , index: 1 , TYPE: Video
qml: loaded clip: 35628 , ID: 80 , index: 1 , TYPE: Video
qml: loaded clip: 37333 , ID: 81 , index: 1 , TYPE: Video
qml: loaded clip: 38065 , ID: 82 , index: 1 , TYPE: Video
qml: loaded clip: 38379 , ID: 83 , index: 1 , TYPE: Video
qml: loaded clip: 39715 , ID: 84 , index: 1 , TYPE: Video
qml: loaded clip: 44236 , ID: 85 , index: 1 , TYPE: Video
qml: loaded clip: 49157 , ID: 86 , index: 1 , TYPE: Video
qml: loaded clip: 50791 , ID: 87 , index: 1 , TYPE: Video
qml: loaded clip: 50823 , ID: 88 , index: 1 , TYPE: Video
qml: loaded clip: 0 , ID: 19 , index: 2 , TYPE: Audio
qml: loaded clip: 489 , ID: 20 , index: 2 , TYPE: Audio
qml: loaded clip: 3692 , ID: 21 , index: 2 , TYPE: Audio
qml: loaded clip: 4285 , ID: 22 , index: 2 , TYPE: Audio
qml: loaded clip: 5276 , ID: 23 , index: 2 , TYPE: Audio
qml: loaded clip: 6233 , ID: 24 , index: 2 , TYPE: Audio
qml: loaded clip: 7357 , ID: 25 , index: 2 , TYPE: Audio
qml: loaded clip: 11632 , ID: 26 , index: 2 , TYPE: Audio
qml: loaded clip: 14595 , ID: 27 , index: 2 , TYPE: Audio
qml: loaded clip: 15234 , ID: 28 , index: 2 , TYPE: Audio
qml: loaded clip: 20172 , ID: 29 , index: 2 , TYPE: Audio
qml: loaded clip: 24795 , ID: 30 , index: 2 , TYPE: Audio
qml: loaded clip: 25754 , ID: 31 , index: 2 , TYPE: Audio
qml: loaded clip: 27368 , ID: 32 , index: 2 , TYPE: Audio
qml: loaded clip: 27773 , ID: 33 , index: 2 , TYPE: Audio
qml: loaded clip: 28148 , ID: 34 , index: 2 , TYPE: Audio
qml: loaded clip: 28246 , ID: 35 , index: 2 , TYPE: Audio
qml: loaded clip: 28268 , ID: 36 , index: 2 , TYPE: Audio
qml: loaded clip: 28757 , ID: 37 , index: 2 , TYPE: Audio
qml: loaded clip: 28777 , ID: 38 , index: 2 , TYPE: Audio
qml: loaded clip: 29846 , ID: 39 , index: 2 , TYPE: Audio
qml: loaded clip: 31382 , ID: 40 , index: 2 , TYPE: Audio
qml: loaded clip: 33184 , ID: 41 , index: 2 , TYPE: Audio
qml: loaded clip: 34295 , ID: 42 , index: 2 , TYPE: Audio
qml: loaded clip: 35133 , ID: 43 , index: 2 , TYPE: Audio
qml: loaded clip: 35628 , ID: 44 , index: 2 , TYPE: Audio
qml: loaded clip: 37333 , ID: 45 , index: 2 , TYPE: Audio
qml: loaded clip: 38065 , ID: 46 , index: 2 , TYPE: Audio
qml: loaded clip: 38379 , ID: 47 , index: 2 , TYPE: Audio
qml: loaded clip: 39715 , ID: 48 , index: 2 , TYPE: Audio
qml: loaded clip: 44236 , ID: 49 , index: 2 , TYPE: Audio
qml: loaded clip: 49157 , ID: 50 , index: 2 , TYPE: Audio
qml: loaded clip: 50791 , ID: 51 , index: 2 , TYPE: Audio
qml: loaded clip: 50823 , ID: 52 , index: 2 , TYPE: Audio
qml: ENDING DRAG!!!
qml: ENDING DRAG!!!
qml: ENDING DRAG!!!
qml: ENDING DRAG!!!
qml: ENDING DRAG!!!
qml: ENDING DRAG!!!
qml: ENDING DRAG!!!
qml: ENDING DRAG!!!
qml: ENDING DRAG!!!
qml: ENDING DRAG!!!
qml: ENDING DRAG!!!
qml: ENDING DRAG!!!
qml: ENDING DRAG!!!
qml: ENDING DRAG!!!
qml: ENDING DRAG!!!
qml: ENDING DRAG!!!
pos: 46369 out-offset: 51823
qt.qpa.wayland: Wayland does not support QWindow::requestActivate()
pos: 46446 out-offset: 51823
pos: 46451 out-offset: 51823
qml: ENDING DRAG!!!
qml: ENDING DRAG!!!
qml: ENDING DRAG!!!
qml: ENDING DRAG!!!
qml: ENDING DRAG!!!
qml: ENDING DRAG!!!
qml: ENDING DRAG!!!
qml: ENDING DRAG!!!
qml: ENDING DRAG!!!
qml: ENDING DRAG!!!
========== READY FOR TASK DELETION ON: 2
========== READY FOR TASK DELETION ON: 54
========== READY FOR TASK DELETION ON: 55
========== READY FOR TASK DELETION ON: 56
========== READY FOR TASK DELETION ON: 57
========== READY FOR TASK DELETION ON: 58
========== READY FOR TASK DELETION ON: 59
========== READY FOR TASK DELETION ON: 60
========== READY FOR TASK DELETION ON: 61
========== READY FOR TASK DELETION ON: 62
========== READY FOR TASK DELETION ON: 63
========== READY FOR TASK DELETION ON: 64
========== READY FOR TASK DELETION ON: 65
========== READY FOR TASK DELETION ON: 66
========== READY FOR TASK DELETION ON: 67
========== READY FOR TASK DELETION ON: 68
========== READY FOR TASK DELETION ON: 69
========== READY FOR TASK DELETION ON: 70
========== READY FOR TASK DELETION ON: 71
========== READY FOR TASK DELETION ON: 72
========== READY FOR TASK DELETION ON: 73
========== READY FOR TASK DELETION ON: 74
========== READY FOR TASK DELETION ON: 75
========== READY FOR TASK DELETION ON: 76
========== READY FOR TASK DELETION ON: 77
========== READY FOR TASK DELETION ON: 78
========== READY FOR TASK DELETION ON: 79
========== READY FOR TASK DELETION ON: 80
========== READY FOR TASK DELETION ON: 81
========== READY FOR TASK DELETION ON: 82
========== READY FOR TASK DELETION ON: 83
========== READY FOR TASK DELETION ON: 84
========== READY FOR TASK DELETION ON: 85
========== READY FOR TASK DELETION ON: 86
========== READY FOR TASK DELETION ON: 87
========== READY FOR TASK DELETION ON: 88
===== REMOVING MASTER PRODUCER; CURRENT COUNT: 1
========== READY FOR TASK DELETION ON: 3
========== READY FOR TASK DELETION ON: 19
========== READY FOR TASK DELETION ON: 20
========== READY FOR TASK DELETION ON: 21
========== READY FOR TASK DELETION ON: 22
========== READY FOR TASK DELETION ON: 23
========== READY FOR TASK DELETION ON: 24
========== READY FOR TASK DELETION ON: 25
========== READY FOR TASK DELETION ON: 26
========== READY FOR TASK DELETION ON: 27
========== READY FOR TASK DELETION ON: 28
========== READY FOR TASK DELETION ON: 29
========== READY FOR TASK DELETION ON: 30
========== READY FOR TASK DELETION ON: 31
========== READY FOR TASK DELETION ON: 32
========== READY FOR TASK DELETION ON: 33
========== READY FOR TASK DELETION ON: 34
========== READY FOR TASK DELETION ON: 35
========== READY FOR TASK DELETION ON: 36
========== READY FOR TASK DELETION ON: 37
========== READY FOR TASK DELETION ON: 38
========== READY FOR TASK DELETION ON: 39
========== READY FOR TASK DELETION ON: 40
========== READY FOR TASK DELETION ON: 41
========== READY FOR TASK DELETION ON: 42
========== READY FOR TASK DELETION ON: 43
========== READY FOR TASK DELETION ON: 44
========== READY FOR TASK DELETION ON: 45
========== READY FOR TASK DELETION ON: 46
========== READY FOR TASK DELETION ON: 47
========== READY FOR TASK DELETION ON: 48
========== READY FOR TASK DELETION ON: 49
========== READY FOR TASK DELETION ON: 50
========== READY FOR TASK DELETION ON: 51
========== READY FOR TASK DELETION ON: 52
screenshot
In fact I can double-click on the monitor to lauch fullscreen display. Still green though. No visual error indication.
It seems it’s not a new issue:
As you said, you’ve already tried Appimage, then maybe the problem is with your GPU driver. Maybe you can try these options (one at a time):
  • Be sure your system is up to date by running yay
  • Boot with another Kernel (better an LTS one)
  • Downgrade KDEnlive
  • Don’t know if it’s a good idea: Downgrade GPU Drivers
I don’t know how to use kdenlive but maybe this is your issue?
