Would be good to know… Have I been blacklisted? LOL So no help for me?
Or has Enos just sadly become a rubbish place to seek help?
assuming to get band by these normal questions and post deleted.
or some stupid aggy response by someone whod never speak like that f2f.
Many thanks.
Hi all,
lol I need help big time. Where’s my elbow at? Just been dying with this issue. in my .zshrc i have export GNUPGHOME=/etc/gnupg
I’m running vanillah arch with hyprland. I also installed a hyprdots theme from github and loads of packages from previous installs.
my laptop
inxi -Fxxz
Kernel: 6.10.1-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
Desktop: Hyprland v: 0.41.2 dm: 1: LightDM note: stopped 2: SDDM
Distro: Arch Linux
Type: Laptop System: LENOVO product: 81N7 v: Lenovo IdeaPad S340-14IWL
serial: <superuser required> Chassis: type: 10 v: Lenovo IdeaPad S340-14IWL
Mobo: LENOVO model: LNVNB161216 v: SDK0R32776 WIN
part-nu: LENOVO_MT_81N7_BU_idea_FM_IdeaPad S340-14IWL UEFI: LENOVO
v: ALCN33WW(V2.10) date: 06/23/2021
Battery:
ID-1: BAT1 charge: 25.8 Wh (69.4%) condition: 37.2/36.0 Wh (103.5%)
volts: 11.7 min: 11.3 model: LGC L18L3PF2 serial: <filter>
status: discharging
Info: quad core model: Intel Core i5-8265U bits: 64 type: MT MCP
arch: Whiskey Lake rev: B cache: L1: 256 KiB L2: 1024 KiB L3: 6 MiB
Speed (MHz): avg: 792 high: 1200 min/max: 400/3900 cores: 1: 1200 2: 1200
3: 1137 4: 400 5: 400 6: 400 7: 400 8: 1200 bogomips: 28808
Device-1: Intel WhiskeyLake-U GT2 [UHD Graphics 620] vendor: Lenovo
driver: i915 v: kernel arch: Gen-9.5 ports: active: eDP-1
empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:3ea0
Device-2: Bison Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 bus-ID: 1-6:2 chip-ID: 5986:2115
Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.1
compositor: Hyprland v: 0.41.2 driver: X: loaded: modesetting unloaded: vesa
alternate: fbdev,intel dri: iris gpu: i915 display-ID: 1
Monitor-1: eDP-1 model: ChiMei InnoLux 0x14e5 res: 1920x1080 dpi: 158
diag: 354mm (13.9")
API: EGL v: 1.5 platforms: device: 0 drv: iris device: 1 drv: swrast
surfaceless: drv: iris wayland: drv: iris x11: drv: iris inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.1.4-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 620 (WHL
GT2) device-ID: 8086:3ea0
Device-1: Intel Cannon Point-LP High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:9dc8
API: ALSA v: k6.10.1-arch1-1 status: kernel-api
Server-2: PipeWire v: 1.2.1 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin
Device-1: Intel Cannon Point-LP CNVi [Wireless-AC] driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:9df0
Bluetooth:
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) driver: btusb
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 bus-ID: 1-10:3
chip-ID: 8087:0aaa
Report: btmgmt ID: hci0 rfk-id: 2 state: down bt-service: enabled,running
rfk-block: hardware: no software: yes address: <filter> bt-v: 5.1 lmp-v: 10
Local Storage: total: 1.4 TiB used: 46.03 GiB (3.2%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 PRO 1TB size: 953.87 GiB
speed: 31.6 Gb/s lanes: 4 serial: <filter> temp: 34.9 C
ID-2: /dev/sda vendor: Samsung model: SSD 860 PRO 512GB size: 476.94 GiB
speed: 6.0 Gb/s serial: <filter>
ID-1: / size: 929.95 GiB used: 45.77 GiB (4.9%) fs: ext4 dev: /dev/nvme0n1p3
ID-2: /boot size: 1022 MiB used: 259.9 MiB (25.4%) fs: vfat
dev: /dev/nvme0n1p1
ID-1: swap-1 type: partition size: 7 GiB used: 256 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p2
System Temperatures: cpu: 57.0 C pch: 58.0 C mobo: N/A
Fan Speeds (rpm): N/A
Memory: total: 8 GiB note: est. available: 7.48 GiB used: 4.04 GiB (54.0%)
Processes: 256 Power: uptime: 4h 24m wakeups: 0 Init: systemd v: 256
default: graphical
Packages: 1585 pm: pacman pkgs: 1556 pm: flatpak pkgs: 29 Compilers:
clang: 18.1.8 gcc: 14.1.1 Shell: Zsh v: 5.9 running-in: kitty inxi: 3.3.35
I run these commands:
sudo killall gpg-agent
sudo rm -rf /etc/pacman.d/gnupg/*.*
pacman-key --init
sudo pacman-key --populate archlinux
sudo pacman -Sy archlinux-keyring
and then when i run this sudo pacman-key --refresh-keys I see loads of errors and keys not being imported.
I’ve also run:
sudo pacman -Sc and sudo paccache -r
timedatectl is fine and ntp is set to true.
I’ve changed the keyserver to well here’s my gpg.conf:
sudo cat /etc/gnupg/gpg.conf
# Key server to use
#keyserver keyserver.archlinux.org
keyserver hkp://keyserver.ubuntu.com
#keyserver hkp://keys.openpgp.org
allow-weak-key-signatures
# Automatically retrieve keys from keyservers
auto-key-retrieve
# Default key to use for signing
default-key F4FDB18A9937358364B276E9E25D679AF73C6D2F
I haven’t got an issue updating but am trying to keep this system clean lol and not reinstall. Like I started this post lol I don’t know my elbow from my armpit… don’t even know if these errors are an issue or if they are going to turn into an issue and give me updating problems later. here’s some of the errors:
gpg: error retrieving 'martin@flexion.org' via WKD: No data
gpg: error reading key: No data
gpg: error retrieving 'martin+arch@flexion.org' via WKD: No data
gpg: error retrieving 'code@flexion.org' via WKD: No data
gpg: error retrieving 'lug@flexion.plus.com' via WKD: Unknown host
gpg: error reading key: Unknown host
gpg: error retrieving 'martin@wimpress.com' via WKD: No data
gpg: error retrieving 'martin@wimpress.org' via WKD: No data
gpg: refreshing 1 key from hkp://keyserver.ubuntu.com
gpg: key 654B877A0864983E: 1 duplicate signature removed
gpg: key 654B877A0864983E: "Martin Wimpress (http://www.flexion.org) <martin@flexion.org>" not changed
gpg: Total number processed: 1
gpg: unchanged: 1
gpg: error retrieving 'andrew@crerar.io' via WKD: No data
gpg: key F6B1610B3ECDBC9F: "Andrew Crerar <andrew@crerar.io>" not changed
gpg: unchanged: 1
pub rsa2048 2017-11-17 [SC] [expires: 2025-11-16]
601F20F1D1BBBF4A78CF5B6DF6B1610B3ECDBC9F
uid [marginal] Andrew Crerar <andrew@crerar.io>
uid [ full ] Andrew Crerar <crerar@archlinux.org>
sub rsa2048 2017-11-17 [E] [expires: 2025-11-16]
gpg: key B1A1D3C5F2DF9BC5: "Dan Printzell <me@vild.io>" not changed
gpg: unchanged: 1
pub ed25519 2021-10-31 [SC] [expires: 2025-12-31]
60939E55F6D5ABF7EE419F08B1A1D3C5F2DF9BC5
uid [ unknown] Dan Printzell <me@vild.io>
uid [ unknown] Dan Printzell <arch@vild.io>
uid [ unknown] Dan Printzell <dan@mutate.se>
uid [ full ] Dan Printzell <wild@archlinux.org>
uid [ unknown] Dan Printzell <xwildn00bx@gmail.com>
sub ed25519 2021-10-31 [A] [expires: 2025-12-31]
sub cv25519 2021-10-31 [E] [expires: 2025-12-31]
gpg: error retrieving 'dieter@plaetinck.be' via WKD: Network error
gpg: error reading key: Network error
gpg: key F2DBB4931985A992: 1 duplicate signature removed
gpg: key F2DBB4931985A992: "Dieter Plaetinck <dieter@plaetinck.be>" not changed
gpg: unchanged: 1
gpg: error retrieving 'git@rxv.cc' via WKD: Unknown host
gpg: key FE763A64F5E54FD6: "kpcyrd <git@rxv.cc>" not changed
gpg: unchanged: 1
pub rsa4096 2018-10-16 [SC] [expires: 2025-08-18]
64B13F7117D6E07D661BBCE0FE763A64F5E54FD6
uid [marginal] kpcyrd <git@rxv.cc>
uid [ full ] kpcyrd <kpcyrd@archlinux.org>
sub rsa4096 2019-02-07 [S] [expires: 2025-08-18]
sub rsa4096 2018-10-16 [E] [expires: 2025-08-18]
gpg: error retrieving 'danielmicay@gmail.com' via WKD: No data
gpg: error retrieving 'daniel.micay@attestation.app' via WKD: No data
gpg: error retrieving 'daniel.micay@grapheneos.org' via WKD: No data
gpg: error retrieving 'daniel.micay@seamlessupdate.app' via WKD: No data
gpg: error retrieving 'security@attestation.app' via WKD: No data
gpg: error retrieving 'security@grapheneos.org' via WKD: No data
gpg: error retrieving 'security@seamlessupdate.app' via WKD: No data
gpg: key F9E712E59AF5F22A: 1 duplicate signature removed
gpg: key F9E712E59AF5F22A: "Daniel Micay <danielmicay@gmail.com>" not changed
gpg: unchanged: 1
gpg: error retrieving 'me@allanmcrae.com' via WKD: General error
gpg: error reading key: General error
gpg: key F99FFE0FEAE999BD: "Allan McRae <me@allanmcrae.com>" not changed
gpg: unchanged: 1
pub rsa2048 2011-06-03 [SC]
6645B0A8C7005E78DB1D7864F99FFE0FEAE999BD
uid [marginal] Allan McRae <me@allanmcrae.com>
uid [marginal] Allan McRae (Developer) <allan@archlinux.org>
sub rsa2048 2011-06-03 [E]
gpg: key 682758BC60D8F87A: "Christopher Brannon <chris@the-brannons.com>" not changed
gpg: unchanged: 1
pub ed25519 2020-10-08 [SC]
C57F35931F317BF9058F834F682758BC60D8F87A
uid [ unknown] Christopher Brannon <chris@the-brannons.com>
sub cv25519 2020-10-08 [E]
gpg: error retrieving 'thomas@master-key.archlinux.org' via WKD: No data
gpg: error retrieving 'bruno.pagani@astrophysics.eu' via WKD: Network error
gpg: error retrieving 'bruno.n.pagani@gmail.com' via WKD: No data
gpg: key 9D893EC4DAAF9129: "Bruno Pagani <bruno.pagani@astrophysics.eu>" not changed
gpg: unchanged: 1
pub rsa2048 2011-08-22 [SC]
69DA34D78FE0EFD596AC6D049D893EC4DAAF9129
uid [ unknown] Bruno Pagani <bruno.pagani@astrophysics.eu>
uid [marginal] Bruno Pagani (Key for Launchpad) <bruno.n.pagani@gmail.com>
uid [ full ] Bruno Pagani <archange@archlinux.org>
uid [ unknown] Bruno Pagani <bruno.pagani@ac-reunion.fr>
uid [ unknown] Bruno Pagani <bruno.pagani@ac-versailles.fr>
uid [ unknown] Bruno Pagani <bruno.pagani@cea.fr>
uid [marginal] Bruno Pagani <bruno.pagani@ens-lyon.fr>
uid [marginal] Bruno Pagani <bruno.pagani@ens-lyon.org>
uid [marginal] Bruno Pagani <bruno.pagani@obspm.fr>
uid [ unknown] Bruno Pagani <bruno.pagani@u-psud.fr>
uid [ unknown] Bruno Pagani <bruno.pagani@universite-paris-saclay.fr>
uid [marginal] Bruno Pagani <pagani@iap.fr>
sub rsa2048 2011-08-22 [E]
gpg: key 6BA0F5A2037F4F41: "Johannes Löthberg (Arch Linux Master Key) <demize@master-key.archlinux.org>" not changed
gpg: unchanged: 1
pub ed25519 2022-10-24 [SC]
69E6471E3AE065297529832E6BA0F5A2037F4F41
uid [ full ] Johannes Löthberg (Arch Linux Master Key) <demize@master-key.archlinux.org>
sub cv25519 2022-10-24 [E]
gpg: key 3D309011083BA25E: "Carl Smedstad <carsme@archlinux.org>" not changed
gpg: unchanged: 1
pub ed25519 2024-04-01 [C] [expires: 2027-04-02]
69F8E5E5E85F771020A0777C3D309011083BA25E
uid [ full ] Carl Smedstad <carsme@archlinux.org>
sub ed25519 2024-04-01 [S]
sub ed25519 2024-04-01 [A]
sub cv25519 2024-04-01 [E]
gpg: error retrieving 'email@alex19ep.me' via WKD: No data
gpg: error retrieving 'aarnaarn2@gmail.com' via WKD: No data
gpg: key DAD6F3056C897266: "Alexander Epaneshnikov <email@alex19ep.me>" not changed
gpg: unchanged: 1
pub rsa4096 2020-03-04 [SC] [expires: 2025-01-25]
6C7F7F22E0152A6FD5728592DAD6F3056C897266
uid [ unknown] Alexander Epaneshnikov <email@alex19ep.me>
uid [ unknown] Alexander Epaneshnikov <aarnaarn2@gmail.com>
uid [ full ] Alexander Epaneshnikov <alex19ep@archlinux.org>
sub rsa4096 2020-03-04 [E] [expires: 2025-01-25]
sub rsa4096 2020-03-04 [A] [expires: 2025-01-25]
sub rsa4096 2020-03-04 [S] [expires: 2025-01-25]
I know i don’t want to set the SigLevel to Never. just need a little bit of guidance, explanation etc so I can have an understanding and deal with frigging pg tips.
I apologise if this post isnt well written, I do hope I’ve given enough info… I’m just smashed rightnow. Feel like I’ve been arguing with my ex wife for two days straight and I don’t know which way is up or down.
Turning my laptop off now need to get some rest.
Many thanks in advance!
