Gparted - Libparted error
I’m not going to worry about it. Hopefully it will sort itself out. I don’t see a problem yet.
Thank you, I am a little calmer now.
On 5.8.7-zen no problem . On 5.8.8-zen yes . I got the same warning
Arch asked to report bugs before 13 , so who is gonna report :thinking: ?
Install gnome-disk-utility and check your partitions if you are not sure . Mine looks unchanged on it .
You could report it then. :wink:
Edit: There is one report already not sure if this is different?
I think this is something else as it is dated from June 22/20
No ,I’m good . Newbies don’t report bugs :hugs: . Experts do :stuck_out_tongue_winking_eye:
I have already done that. Everything all right with the SSD.
I think it’s a software issue with gparted. Probably a certain file needs an update.
Edit: Or it’s a kernel issue.
Ok expert, thanks first! :+1:t2:
Kernel issue because , Gparted didn’t update ; kernel did :rofl:
Edit
This was a simple finding/assumption related to the topic and I have no idea why got flagged .
Anyway thanks for restoring , but I missed to see how it looks when flagged by someone else :joy:
same error on manjaro testing & kernel 5.8.8 ( stable + patches )
:grin: No, Arch doesn’t force this on you!
You can skip packages from being upgraded by adding them to /etc/pacman.conf
To keep your current kernel just add the packages to IgnorePkg, e. g.
IgnorePkg= linux linux-headers
or even
IgnorePkg= linux linux-headers linux-lts linux-lts-headers
Apart from Gentoo where you compile your own kernel, I don’t think you’ll find a better selection of kernels on any other distro, than on Arch.
You can install linux-lts from the repos if you want the LTS kernel (currently 5.4). If you need an even older kernel, you can install it from the AUR.
For example, my laptop only runs smoothly on version 4 kernel. There is no problem running 4.19 on Arch, you can find it on aur.archlinux.org if you search for “linux 419” (make sure to install the headers, as well, of course). When you install it, it will just be another item on the GRUB menu.
Keep in mind, Manjaro is also based on Arch. If it is possible on Manjaro, it’s possible on vanilla Arch, too (as well as on EOS, of course). Manjaro just makes choosing a kernel a bit more streamlined, but they have not invented the wheel :wink:
The information in the error message(s) IS erroneous.
Well well, let’s watch this … :pensive:
They just pushed a minor 5.8.8 kernel update and Gparted is still misbehaving.
FWIW, I just updated to 5.8.9-arch2-1 kernel and now gparted isn’t giving me any errors at all when I start it up. Hooray for quick fixes and rolling releases :smiley:
