Today I observed that the option Open in Terminal is not working anymore and crashing the window. So I googled and someone somewhere taught how to fix it by opening the Gnome-Terminal directly and by unchecking the “Run custom command instead of my shell” option. But my Gnome-terminal does not open either.
First, make sure your system is fully up-to-date and reboot.
If that doesn’t help, install a different terminal and try running gnome-terminal from that terminal. Hopefully there will be some kind of error message displayed in the terminal.
I created a symlink with sudo ln -s /usr/bin/gnome-tilix /usr/bin/gnome-terminal to use tilix rather than gnome-terminal but it did not work either. And, to make everything worse, open in terminal simply disappeared.
I tried to reinstalled gnome-terminal but the output is:
error: failed to commit transaction (conflicting files)
gnome-terminal: /usr/bin/gnome-terminal exists in filesystem
that is, the fckng package is already installed, but when I run the command pacman -Ss gnome-terminal the output is:
It brought back the Open in Terminal but also installed the Open Tilix Here and the nautilus-terminal. At least, the nautilus-terminal (gnome-terminal) works and Tilix too. And the system is fully updated.
You need to edit your locale-gen (/etc/locale-gen) to suit your locale, uncomment the locale that matches your language and then from tilix run locale-gen again and then Gnome-Terminal should work.
This problem used to occur in Manjaro cuz after the first system update the locale was simply disconfigured. And we had to reconfigure it to fix the terminals. But in EndeavourOS this does not use to happen. My locale.conf was generated by EndeavourOS and had two languages, en_US.UTF-8 for the system language and pt_PT.UTF-8 for time, date, money and for some other portuguese stuff. And, first of all, I have been using it for months, so, why does that problem come up now?
But I decided to follow your hint and edit the locale.conf and I wiped away the pt_PT.UTF-8 from the file, regenerated the locale-gen and reupdated the grub and rebooted the computer and voilà, the gnome-terminal came back. Problem solved!
