I have an issue with Gnome when using the latest 5.10.11-arch1-1 kernel: when starting the computer, Gnome does not appear to load. It gets stuck at a black screen with a white blinking cursor. To solve it, I switch the virtual console by pressing ctrl+alt+f2 and then go back to the 1st one with ctrl+alt+f1 and Gnome suddenly starts.
I’m quite sure it’s a kernel issue as this does not happen with LTS (although with that one I run with some Lutris issues).
Any clue or tip on how to fix it? Here are my system specs:
5.10.12 is in Arch testing, so either use LTS for now, or if you want to see if 5.10.12 will work then either cherry-pick it from testing or or use another kernel at 5.10.12 (e.g. linux-lqx).
(Also, it’s generally a good thing to post text output as text.)
Sorry for posting as image, instead of text. Won’t happen again.
In the meantime I’ve found a failed systemd backlight service and masked it, and it solved the issue at least for now. I’ll look into your suggestion too.
Welcome to the forum. Thanks for giving EndeavourOS a try. Good to see it being used on a production machine? (Senior Software Developer working on EndeavourOS)
Hey, thanks for the welcome Yes, I actually use EndeavourOS on my production machine doing a lot of coding and devops stuff. I’ve been doing distro-hopping a lot recently loving Arch Linux the most because it keeps me very productive. After having Manjaro for some time I noticed I’m more the vanilla-kinda-guy, so I gave EOS a try. And I think I may have found my final destination, so I signed up here
