Gnome light slider unvisible
Hello.
I think it is after Gnome 48 update. When the system boots, the light/luminosity cursor/slider in the gnome menu (top right) isn’t present when I go for him with the mouse.
It appears when I use the light media shorcut (Fn +F8/F9) and then, stay visible during the session.
Any Idea?
Thank you.
Lcg
This must have been already solved with this update:
[ALPM] upgraded gnome-shell (1:48.0-1.1 -> 1:48.1-1.1)
Is your system fully updated?
extra/gnome-shell 1:48.1-1 (gnome) [installed: 1:48.1-1.1]
    Next generation desktop shell
What says: pacman -Ss gnome-shell on your system?
Hello.
I should have try updating first.
It has solved the problem.
Thank you for your reply.
Have a nice day.
