is there anyone using terminator under Gnome 40? My impression is that the transparency setting is not being honored on the first start of terminator. Exiting and starting again the transparency is there. Could someone check this? I’d like to file a bug report on this but I would appreciate some confirmation.
Thanks for your check. I guess I found the reason but I do not understand it yet. I created a custom profile named cs and put a terminator.desktop into ~/.local/share/applications with Exec=env GDK_BACKEND=x11 terminator --layout=cs. If I simply change the default profile it works. Any idea on this?
