So for some reason I cant pull from my git repos anymore. I have the remotes as ssh keys. I already deleted them, and added new keys to my github account. Its the only ssh key I have so it definitely cant pick the wrong private key. with a simple ssh command I can connect to github, verifying that it works but when I try to pull or clone a repo I get a fatal: Could not read from remote repository
i also tried the whole thing with eval $(ssh-agent) and ssh-add but still doesn’t work
This is the whole output im getting when trying to clone something
❯ GIT_SSH_COMMAND="ssh -v" git clone git@github.com:OverloaderV/Web-Praktikum.git
Cloning into 'Web-Praktikum'...
OpenSSH_9.1p1, OpenSSL 1.1.1q 5 Jul 2022
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: Connecting to github.com [140.82.121.4] port 22.
debug1: Connection established.
debug1: identity file /home/lukas/.ssh/id_rsa type 0
debug1: identity file /home/lukas/.ssh/id_rsa-cert type -1
debug1: identity file /home/lukas/.ssh/id_ecdsa type -1
debug1: identity file /home/lukas/.ssh/id_ecdsa-cert type -1
debug1: identity file /home/lukas/.ssh/id_ecdsa_sk type -1
debug1: identity file /home/lukas/.ssh/id_ecdsa_sk-cert type -1
debug1: identity file /home/lukas/.ssh/id_ed25519 type -1
debug1: identity file /home/lukas/.ssh/id_ed25519-cert type -1
debug1: identity file /home/lukas/.ssh/id_ed25519_sk type -1
debug1: identity file /home/lukas/.ssh/id_ed25519_sk-cert type -1
debug1: identity file /home/lukas/.ssh/id_xmss type -1
debug1: identity file /home/lukas/.ssh/id_xmss-cert type -1
debug1: identity file /home/lukas/.ssh/id_dsa type -1
debug1: identity file /home/lukas/.ssh/id_dsa-cert type -1
debug1: Local version string SSH-2.0-OpenSSH_9.1
debug1: Remote protocol version 2.0, remote software version babeld-a0da6a28
debug1: compat_banner: no match: babeld-a0da6a28
debug1: Authenticating to github.com:22 as 'git'
debug1: load_hostkeys: fopen /home/lukas/.ssh/known_hosts2: No such file or directory
debug1: load_hostkeys: fopen /etc/ssh/ssh_known_hosts: No such file or directory
debug1: load_hostkeys: fopen /etc/ssh/ssh_known_hosts2: No such file or directory
debug1: SSH2_MSG_KEXINIT sent
debug1: SSH2_MSG_KEXINIT received
debug1: kex: algorithm: curve25519-sha256
debug1: kex: host key algorithm: ssh-ed25519
debug1: kex: server->client cipher: chacha20-poly1305@openssh.com MAC: <implicit> compression: none
debug1: kex: client->server cipher: chacha20-poly1305@openssh.com MAC: <implicit> compression: none
debug1: expecting SSH2_MSG_KEX_ECDH_REPLY
debug1: SSH2_MSG_KEX_ECDH_REPLY received
debug1: Server host key: ssh-ed25519 SHA256:+DiY3wvvV6TuJJhbpZisF/zLDA0zPMSvHdkr4UvCOqU
debug1: Host 'github.com' is known and matches the ED25519 host key.
debug1: Found key in /home/lukas/.ssh/known_hosts:2
debug1: rekey out after 134217728 blocks
debug1: SSH2_MSG_NEWKEYS sent
debug1: expecting SSH2_MSG_NEWKEYS
debug1: SSH2_MSG_NEWKEYS received
debug1: rekey in after 134217728 blocks
debug1: get_agent_identities: bound agent to hostkey
debug1: get_agent_identities: agent returned 1 keys
debug1: Will attempt key: /home/lukas/.ssh/id_rsa RSA SHA256:H5JDypggyIaxAREi4UWYhGooW09RafD9qMw4oyJGxEY agent
debug1: Will attempt key: /home/lukas/.ssh/id_ecdsa
debug1: Will attempt key: /home/lukas/.ssh/id_ecdsa_sk
debug1: Will attempt key: /home/lukas/.ssh/id_ed25519
debug1: Will attempt key: /home/lukas/.ssh/id_ed25519_sk
debug1: Will attempt key: /home/lukas/.ssh/id_xmss
debug1: Will attempt key: /home/lukas/.ssh/id_dsa
debug1: SSH2_MSG_EXT_INFO received
debug1: kex_input_ext_info: server-sig-algs=<ssh-ed25519-cert-v01@openssh.com,ecdsa-sha2-nistp521-cert-v01@openssh.com,ecdsa-sha2-nistp384-cert-v01@openssh.com,ecdsa-sha2-nistp256-cert-v01@openssh.com,sk-ssh-ed25519-cert-v01@openssh.com,sk-ecdsa-sha2-nistp256-cert-v01@openssh.com,rsa-sha2-512-cert-v01@openssh.com,rsa-sha2-256-cert-v01@openssh.com,ssh-rsa-cert-v01@openssh.com,sk-ssh-ed25519@openssh.com,sk-ecdsa-sha2-nistp256@openssh.com,ssh-ed25519,ecdsa-sha2-nistp521,ecdsa-sha2-nistp384,ecdsa-sha2-nistp256,rsa-sha2-512,rsa-sha2-256,ssh-rsa>
debug1: SSH2_MSG_SERVICE_ACCEPT received
debug1: Authentications that can continue: publickey
debug1: Next authentication method: publickey
debug1: Offering public key: /home/lukas/.ssh/id_rsa RSA SHA256:H5JDypggyIaxAREi4UWYhGooW09RafD9qMw4oyJGxEY agent
debug1: Server accepts key: /home/lukas/.ssh/id_rsa RSA SHA256:H5JDypggyIaxAREi4UWYhGooW09RafD9qMw4oyJGxEY agent
Authenticated to github.com ([140.82.121.4]:22) using "publickey".
debug1: channel 0: new [client-session]
debug1: Entering interactive session.
debug1: pledge: filesystem
debug1: client_input_global_request: rtype hostkeys-00@openssh.com want_reply 0
debug1: client_input_hostkeys: searching /home/lukas/.ssh/known_hosts for github.com / (none)
debug1: client_input_hostkeys: searching /home/lukas/.ssh/known_hosts2 for github.com / (none)
debug1: client_input_hostkeys: hostkeys file /home/lukas/.ssh/known_hosts2 does not exist
debug1: client_input_hostkeys: no new or deprecated keys from server
debug1: Sending environment.
debug1: channel 0: setting env GIT_PROTOCOL = "version=2"
debug1: Sending command: git-upload-pack 'OverloaderV/Web-Praktikum.git'
debug1: client_input_global_request: rtype keepalive@openssh.com want_reply 1
debug1: channel 0: free: client-session, nchannels 1
Connection to github.com closed by remote host.
Transferred: sent 3220, received 2528 bytes, in 780.2 seconds
Bytes per second: sent 4.1, received 3.2
debug1: Exit status -1
fatal: Could not read from remote repository.
Please make sure you have the correct access rights
and the repository exists.
At this point the things I can think of that could be at fault are: The packaged version of git and/or ssh provided by endeavor/arch or the upstream of git or openssh
Yep, I use git push, git pull, and other git commands via SSH everytime I update the EnOS ARM package repositories. Works like a charm. But I have not ever did a git clone via ssh.
It worked for > A year and suddenly stopped working now
I deleted my ssh kes, generated new ones and put the public key on github.
I can connect to github with ssh to test the connection
❯ ssh git@github.com
PTY allocation request failed on channel 0
Hi OverloaderV! You've successfully authenticated, but GitHub does not provide shell access.
Connection to github.com closed.
But when trying to clone or pull a repo i get the error from above
