av8r
July 27, 2022, 10:36pm
1
This plugin installs and looks to have everything in order, but when you open up gimp (even after reboot) and go to filters>Enhanced there is no “heal-selection” or other plugins from it to be found.
any idea how to make this work?
they are all located in /usr/lib/gimp/2.0.plug-ins/
→ I do not understand why it’s not showing up in gimp.
aur/gimp-plugin-resynthesizer-git 2.0.3.r23.gb6ff907-1 (+209 0.03) (Installed: 2.0.3.r24.gecfc4e7-1)
dalto
July 27, 2022, 10:54pm
2
The issue here seems to be that the maintainer isn’t willing to add one of the dependencies. It appears that installing python2-gimp is required.
Of course, you should be aware that you are installing a bunch of unmaintained or marginally maintained software.
av8r
July 27, 2022, 11:05pm
3
aha. thank you for calrifying. I will be deleting that plugin.
again thank you for your help
Echoa
July 28, 2022, 5:08am
4
i would use the GIMP flatpak if you want that and some of the other big plugins as they are available from flathub easily
mardi
July 29, 2022, 4:07am
5
Lack of heal-selection was the reason I moved using GIMP Appimage. No need to install separate plugins.
mbod
July 29, 2022, 5:31am
6
But gimp appimage is really old (gimp version 2.10.22) and not maintained.
mardi
July 29, 2022, 6:06am
7
Actually, I’m using appimage GIMP 2.10.25 withplugins-x86_64. It’s true it’s quite old, but to me is most important it just works.
