I have this error on both of my systems using EOS. Whenever i open or create a image and use the pencil on it i’ll get a “memory access error” on exiting gimp (reported by gimp). Both systems have been tested with Memtest so i think this is a bug or related to some “access” issues. Does someone know how to fix it?
Did the application crash when this happened?
Going to need some logs:
There are no EOS Crash logs. The only log i get is from the GIMP Crash Dialog opening up on exiting Gimp. I can give you that if you need it? Pasted it here
Gimp doesn’t “really” crash. It’s just the dialog popping up after editing a image then exiting Gimp.
I just made another discovery: The Issue only seems to appear if you don’t save the changes made in the image. If you save it it works without crashing after exiting. Otherwise i’ll get that stupid dialog on exit.
inxi?
Host: Mandarine Kernel: 6.8.2-arch2-1 arch: x86_64 bits: 64
Desktop: KDE Plasma v: 6.0.3 Distro: EndeavourOS
Type: Desktop System: Micro-Star product: MS-7C56 v: 6.0
serial: <superuser required>
Mobo: Micro-Star model: B550-A PRO (MS-7C56) v: 2.0
serial: <superuser required> UEFI: American Megatrends LLC. v: A.H0
date: 03/11/2024
Info: 8-core AMD Ryzen 7 5700X3D [MT MCP] speed (MHz): avg: 2284
min/max: 2200/4148
Device-1: AMD Navi 32 [Radeon RX 7700 XT / 7800 XT] driver: amdgpu v: kernel
Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 23.2.4 driver: X:
loaded: amdgpu unloaded: modesetting,radeon dri: radeonsi gpu: amdgpu
resolution: 2560x1440~165Hz
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.4-arch1.1
renderer: AMD Radeon RX 7700 XT (radeonsi navi32 LLVM 17.0.6 DRM 3.57
6.8.2-arch2-1)
Device-1: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet
driver: r8169
Local Storage: total: 6.37 TiB used: 1.04 TiB (16.3%)
Memory: total: 32 GiB available: 31.27 GiB used: 4.42 GiB (14.1%)
Processes: 319 Uptime: 42m Shell: Zsh inxi: 3.3.33
The other system is pretty much the same. Just a 5600X/6600RX and less RAM instead.
EDIT
In case someone is having the same issue. I have found a open issue about this on the Gimp Gitlab. So this issue seems known. Therefore i think no one will be able to help here
I also have the problem, but it is the same whether I save or not. The crash dialog always appears when I close GIMP.
It’s happening here when i “discard” changes. So if you saved and then do changes that you discard it will also crash. It only doesn’t crash when you don’t discard any changes. You might have a look here to see if you have the same issue.
