General performance optimizations - fast LUKS | best practice?
Dear Community,
I have been researching the topic of performance and encryption for the last few days. The impetus was that I wanted to speed up decryption when starting the laptop.
In the end, I also got stuck in the archwiki performance optimisation guide and now have a few questions that I could not clarify for myself.
  1. Speed up LUKS
    I found this thread where @dalto describes that grub cannot use acceleration when decrypting if /boot is encrypted.
    So far so good.
    I subsequently researched the consequences of a non-encrypted /boot.
    The bottom line seems to be that it is not a big deal to use unencrypted /boot if you only want to protect yourself against casual thieves or nosy people with M2-USB adapters.
If I accept the lower security of unencrypted /boot, what would be the procedure for installing EOS with the rest being encrypted?
Is there now a completely different, more elegant solution?
  1. Speed up boot
    Is there any boost - especially in boot performance - to be expected by switching from grub to systemd boot?
    The “btrfs snapshot available at grub” thing is quite nice, but honestly I never had to use it.
  2. I already turned off the exploit mitigations and this gave a really noticeable boost in normal workflow. (See these benchmarks, especially with my 8th gen intel)
Thank you very much! :heart:
inxi -Fz
[jannisf@t480s ~]$ inxi -Fz
Kernel: 6.4.11-arch2-1 arch: x86_64 bits: 64 Desktop: KDE Plasma v: 5.27.7
Distro: EndeavourOS
Type: Laptop System: LENOVO product: 20L8S9GC00 v: ThinkPad T480s
serial:
Mobo: LENOVO model: 20L8S9GC00 v: SDK0J40697 WIN
serial: UEFI: LENOVO v: N22ET75W (1.52 )
date: 09/28/2022
Battery:
ID-1: BAT0 charge: 51.0 Wh (100.0%) condition: 51.0/57.0 Wh (89.6%)
Info: quad core model: Intel Core i5-8350U bits: 64 type: MT MCP cache:
L2: 1024 KiB
Speed (MHz): avg: 1636 min/max: 400/3600 cores: 1: 1129 2: 1900 3: 1900
4: 1900 5: 1900 6: 1900 7: 563 8: 1900
Device-1: Intel UHD Graphics 620 driver: i915 v: kernel
Device-2: Chicony Integrated Camera (1280x720@30) driver: uvcvideo
type: USB
Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.2.0
compositor: kwin_wayland driver: X: loaded: intel unloaded: modesetting
dri: i965 gpu: i915 resolution: 2560x1440
API: OpenGL v: 4.6 Mesa 23.1.6 renderer: Mesa Intel UHD Graphics 620 (KBL
GT2)
Device-1: Intel Sunrise Point-LP HD Audio driver: snd_hda_intel
Device-2: Lenovo ThinkPad Thunderbolt 3 Dock Audio
driver: hid-generic,snd-usb-audio,usbhid type: USB
API: ALSA v: k6.4.11-arch2-1 status: kernel-api
Server-1: PipeWire v: 0.3.77 status: active
Device-1: Intel Ethernet I219-LM driver: e1000e
IF: enp0s31f6 state: down mac:
Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi
IF: wlan0 state: up mac:
Device-3: Lenovo ThinkPad TBT3 LAN driver: r8152 type: USB
IF: enp11s0u1 state: down mac:
Bluetooth:
Device-1: Intel Bluetooth wireless interface driver: btusb type: USB
Report: btmgmt ID: hci0 state: up address: bt-v: 4.2
Local Storage: total: 476.95 GiB used: 133.33 GiB (28.0%)
ID-1: /dev/nvme0n1 vendor: Western Digital model: PC SN520
SDAPMUW-256G-1101 size: 238.47 GiB
ID-2: /dev/nvme1n1 vendor: Lenovo model: LENSE30256GMSP34MEAT3TA
ID-1: / size: 238.08 GiB used: 133.33 GiB (56.0%) fs: btrfs dev: /dev/dm-0
ID-2: /boot/efi size: 399.2 MiB used: 1.1 MiB (0.3%) fs: vfat
dev: /dev/nvme1n1p1
ID-3: /home size: 238.08 GiB used: 133.33 GiB (56.0%) fs: btrfs
dev: /dev/dm-0
ID-4: /var/log size: 238.08 GiB used: 133.33 GiB (56.0%) fs: btrfs
dev: /dev/dm-0
ID-1: swap-1 type: file size: 11 GiB used: 65 MiB (0.6%)
file: /swap/swapfile
System Temperatures: cpu: 43.0 C pch: 40.0 C mobo: N/A
Fan Speeds (rpm): fan-1: 0
Processes: 228 Uptime: 23m Memory: total: 8 GiB note: est.
available: 7.51 GiB used: 2.91 GiB (38.7%) Shell: Bash inxi: 3.3.29
IMO, the downside is not security related. It is the ability to easily restore snapshots via Timeshift or btrfs. If you don’t need that specific functionality, it shouldn’t be a problem.
There are options here:
  • The easiest solution would be to choose systemd-boot instead of grub. This will move your kernel and boot images to the ESP which is not encrypted.
  • If you prefer grub, you can also use manual partitioning and create a small ext4 partition for /boot.
Alternatively, if your current ESP is big enough, you can avoid re-installation by mounting it on /boot in your current install.
Yes, systemd-boot is faster. However, if it is materially faster is down to personal considerations. Some people care about every millisecond in their boot time while others wouldn’t notice their boot time increasing by a second or two.
In my experience it is faster but, excluding decryption, it is less than a second faster. Other people have reported different numbers so it is likely dependent on the specifics of your system.
Thank you for your reply!
Do you have experience with Data-at-rest encryption with LUKS?
As I understand it, you would only need to enter a password once. That would speed up the boot process too.
Did I understand that correctly?
The tutorials for setting this seem quite complicated. :smiling_face_with_tear:
Using TPM for unlocking? That means that you will not need a password anymore.
The value in that is that if the storage is ever separated from the PC, it cannot be unlocked. However, if someone has the PC, it is unlocked automatically.
For most consumer use cases, this is the opposite of what you what you want.
But can’t you make it so that a password has to be entered to get the key out?
So from the operation like Bitlocker in Windows?
Note: As of systemd 251 it is now possible to require a PIN to be entered in addition to the TPM state being correct. Simply add the option --tpm2-with-pin=yes to the command above and enter the PIN when prompted.
You probably can but that is not what the article you linked does.
So a “bitlocker like” experience is nothing a newbie user could archive atm?
Edit:
You know what?
I’ll just try the TPM pin variant and see if I can get it set up. :cowboy_hat_face:
