General Install Question
I am not having any issues but I am considering doing a fresh install because I want to switch desktops from cinnamon to KDE . I have noticed that during the install process that one can choose between 2 boot loaders , grub and Endeavor native . So in short what is the difference and is their one better then the other ?
That would depend on your needs. For most people the default Systemd-boot will be fine
The default is systemd boot. It is simpler than grub but also less powerful. If your boot needs are fairly simple, go for systemd boot. If you want to boot from snapshots, or do multi-booting, choose grub.
I found this:
thanks to all for the info :slightly_smiling_face: looks like I will choose the native for security
