Hello everyone,
The installation aborts with an error message. "The package manager could not change the installed system. The
pacman
command produced error code 1. In the forum I find the tip to disable the package ipw2100-fw under network. I can’t find the package there. what do i have to do here Can someone help me?
Hello @Arautyman
Sounds like you are using an older ISO. That package was removed. On the installer packages under network you would have to uncheck both ipw2100 and ipw2200 or download the latest ISO and create a new live usb.
