Everything in the installation process is fine until the last step, where it throws package manager error:
The package manager could not make changes to the installed system. The command pacman -S --noconfirm --noprogressbar --needed --disable-download-timeout mesa-utils xf86-input-libinput xorg-xdpyinfo xorg-server xorg-xinit xorg-xinput xorg-xkill xorg-xrandr xf86-video-amdgpu xf86-video-ati b43-fwcutter dialog dnsmasq dnsutils ethtool iwd modemmanager networkmanager networkmanager-openconnect networkmanager-openvpn nss-mdns openssh usb_modeswitch whois wireless-regdb wpa_supplicant xl2tpd downgrade pacman-contrib pkgfile rebuild-detector reflector yay accountsservice bash-completion bluez bluez-utils gst-libav gst-plugin-pipewire gst-plugins-bad gst-plugins-ugly libdvdcss libgsf libopenraw plocate poppler-glib xdg-user-dirs xdg-utils efitools haveged nfs-utils nilfs-utils ntp smartmontools unrar unzip xz cantarell-fonts freetype2 noto-fonts noto-fonts-emoji noto-fonts-cjk noto-fonts-extra ttf-bitstream-vera ttf-dejavu ttf-liberation ttf-opensans alsa-firmware alsa-plugins alsa-utils pavucontrol pipewire-pulse wireplumber pipewire-alsa pipewire-jack rtkit dmidecode dmraid hdparm hwdetect lsscsi mtools sg3_utils sof-firmware power-profiles-daemon upower endeavouros-branding eos-apps-info eos-log-tool eos-packagelist eos-quickstart eos-rankmirrors reflector-simple welcome duf findutils git glances hwinfo inxi meld nano-syntax-highlighting python-defusedxml python-jinja python-packaging rsync tldr sed vi wget firewalld firewall-applet cups cups-browsed cups-filters cups-pdf foomatic-db foomatic-db-engine foomatic-db-gutenprint-ppds foomatic-db-nonfree foomatic-db-nonfree-ppds foomatic-db-ppds ghostscript gsfonts gutenprint splix system-config-printer hplip python-pillow python-pyqt5 python-reportlab sane cups cups-browsed cups-filters cups-pdf acpi arandr arc-gtk-theme-eos archlinux-xdg-menu awesome-terminal-fonts brightnessctl dex dmenu dunst eos-settings-i3wm endeavouros-xfce4-terminal-colors eos-lightdm-slick-theme eos-qogir-icons feh galculator gvfs gvfs-afc gvfs-gphoto2 gvfs-mtp gvfs-nfs gvfs-smb i3-wm i3blocks i3lock i3status jq lightdm lightdm-slick-greeter nwg-look mpv network-manager-applet numlockx playerctl polkit-gnome rofi scrot sysstat thunar thunar-archive-plugin thunar-volman tumbler unzip xarchiver xbindkeys xdg-user-dirs-gtk xed xfce4-terminal xorg-xdpyinfo xss-lock zip returned error code 1.
When I attempt to redo the process, I get error when tables are partitioned:
Create a new partition table (type: gpt) on ‘/dev/nvme1n1’
Job: Create new partition table on device ‘/dev/nvme1n1’
Command: sfdisk --wipe=always /dev/nvme1n1
