I might be the millionth person with this problem but here goes…
I’ve done a fresh install and am not getting any sound from my laptop. LiveCD worked.
I should add, if I plugin a USB-C earphone with microphone, it works fine.
I’ve tried installing sof-firmware, lts/zen kernel and I’m still getting nothing.
Here’s the inxi -Fxxxza --no-host output
Kernel: 5.15.39-1-lts arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-lts
root=UUID=505c6d91-ae75-445f-b5c0-58d0b07056ce rw rootflags=subvol=@
quiet resume=UUID=d13f7c7a-17a5-4269-b47e-b55bb74eef7d loglevel=3
nowatchdog nvme_load=YES
Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 info: xfce4-panel wm: xfwm
v: 4.16.1 dm: LightDM v: 1.30.0 Distro: EndeavourOS base: Arch Linux
Type: Laptop System: SAMSUNG product: 950XED v: P05RGF serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: SAMSUNG model: NT950XEW-A51AS v: SGLFREEDOS-C00-R000-S0000+1.0.0000
serial: <filter> UEFI: American Megatrends LLC. v: P05RGF.044.220307.ZQ
date: 03/07/2022
Battery:
ID-1: BAT1 charge: 30.5 Wh (45.0%) condition: 67.8/66.8 Wh (101.4%)
volts: 16.0 min: 15.4 model: SAMSUNG Electronics SR Real Battery
type: Li-ion serial: <filter> status: charging cycles: 7
Info: model: 12th Gen Intel Core i5-1240P socket: U3E1 bits: 64
type: MST AMCP arch: Alder Lake family: 6 model-id: 0x9A (154) stepping: 3
microcode: 0x41C
Topology: cpus: 1x cores: 12 mt: 4 tpc: 2 st: 8 threads: 16 smt: enabled
cache: L1: 1.1 MiB desc: d-8x32 KiB, 4x48 KiB; i-4x32 KiB, 8x64 KiB
L2: 9 MiB desc: 4x1.2 MiB, 2x2 MiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 681 high: 1056 min/max: 400/4400:3300
base/boost: 1584/4400 scaling: driver: intel_pstate governor: powersave
volts: 0.7 V ext-clock: 100 MHz cores: 1: 486 2: 589 3: 616 4: 560 5: 579
6: 557 7: 745 8: 870 9: 655 10: 580 11: 514 12: 541 13: 1056 14: 867
15: 971 16: 722 bogomips: 67584
Vulnerabilities:
Type: spec_store_bypass
mitigation: Speculative Store Bypass disabled via prctl and seccomp
Type: spectre_v1
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: Intel Alder Lake-P Integrated Graphics vendor: Samsung Co
driver: i915 v: kernel ports: active: eDP-1
empty: DP-1, DP-2, DP-3, HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:46a6
class-ID: 0300
Device-2: SunplusIT 1080p FHD Camera type: USB driver: uvcvideo
bus-ID: 3-6:4 chip-ID: 2b7e:c556 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.3 compositor: xfwm v: 4.16.1 driver:
X: loaded: modesetting alternate: fbdev,intel,vesa gpu: i915
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.00x11.22")
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: Samsung 0x4159 built: 2020 res: 1920x1080 hz: 60
dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel Graphics (ADL GT2) v: 4.6 Mesa 22.0.3
direct render: Yes
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Samsung Co
driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:51c8 class-ID: 0401
Sound Server-1: ALSA v: k5.15.39-1-lts running: yes
Sound Server-2: JACK v: 1.9.21 running: no
Sound Server-3: PulseAudio v: 15.0 running: no
Sound Server-4: PipeWire v: 0.3.51 running: yes
Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:51f0 class-ID: 0280
Bluetooth:
Device-1: Intel type: USB driver: btusb v: 0.8 bus-ID: 3-10:5
chip-ID: 8087:0033 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: up address: see --recommends
Local Storage: total: 238.47 GiB used: 63.49 GiB (26.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVL2256HCHQ-00B
size: 238.47 GiB block-size: physical: 512 B logical: 512 B
speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter> rev: GXA7DK2Q
temp: 43.9 C scheme: GPT
SMART: yes health: PASSED on: 12 hrs cycles: 35
read-units: 138,806 [71.0 GB] written-units: 926,865 [474 GB]
ID-1: / raw-size: 221.38 GiB size: 221.38 GiB (100.00%)
used: 63.49 GiB (28.7%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%)
used: 576 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 221.38 GiB size: 221.38 GiB (100.00%)
maj-min: 259:2
ID-4: /var/log raw-size: 221.38 GiB size: 221.38 GiB (100.00%)
maj-min: 259:2
Kernel: swappiness: 60 (default) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 16.79 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3
System Temperatures: cpu: 44.0 C mobo: 44.0 C
Fan Speeds (RPM): N/A
Processes: 355 Uptime: 8m wakeups: 1034 Memory: 15.26 GiB
used: 3.6 GiB (23.6%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 12.1.0 Packages: pacman: 858 lib: 240 Shell: Bash (sudo) v: 5.1.16
running-in: xfce4-terminal inxi: 3.3.15
