Fresh install, display sometimes black, audio sometimes stutters
Hello all,
I’m new to linux and haven’t built a computer in ~7 years so I just made a new one and only installed Endeavour OS to challenge myself and did that work. but now I can’t… lol
In short sometimes on boot the videocard output is just not being sent to the tv, other times when I can boot, the display goes dark if I’m not playing video/games and can’t wake it up even though the pc’s rgb lights are still on. Even while using it sometimes the audio stream stops for a moment (while time running) and then resumes after the glitch time.
I’ve tried going on the welcome menu and updating all mirrors in order to use this FAQ
however on the first step I get a “WARNING: failed to rate rsync/http(s) … Download timed out after 5 seconds” so did try to extend that timeout however don’t see if that’s the right approach, also saw in a forum that I could switch bios setting so uefi is correctly selected but don’t know this motherboard in order to know what to change.
Thank you for the help and if any logs/steps are needed I’ll do my best to accomodate
ASUS B650-A
AMD Ryzen 7 7800X3D
ASRock AMD Radeon RX 7900 XT
Sample from PCI-InfoCenter
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge Root Complex
	Subsystem: ASUSTeK Computer Inc. Device 8877
	Flags: fast devsel
00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge IOMMU
	Flags: bus master, fast devsel, latency 0, IRQ 26
	Capabilities: <access denied>
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge Dummy Host Bridge
	Flags: fast devsel, IOMMU group 0
00:01.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge GPP Bridge (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 27, IOMMU group 1
	Bus: primary=00, secondary=01, subordinate=03, sec-latency=0
	I/O behind bridge: f000-ffff [size=4K] [16-bit]
	Memory behind bridge: f6b00000-f6dfffff [size=3M] [32-bit]
	Prefetchable memory behind bridge: 1400000000-1fffffffff [size=48G] [32-bit]
	Kernel driver in use: pcieport
00:01.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge GPP Bridge (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 28, IOMMU group 2
	Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
	I/O behind bridge: [disabled] [32-bit]
	Memory behind bridge: f6f00000-f6ffffff [size=1M] [32-bit]
	Prefetchable memory behind bridge: [disabled] [64-bit]
00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge Dummy Host Bridge
	Flags: fast devsel, IOMMU group 3
00:02.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge GPP Bridge (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 29, IOMMU group 4
	Bus: primary=00, secondary=05, subordinate=0d, sec-latency=0
	Memory behind bridge: f6200000-f66fffff [size=5M] [32-bit]
	Prefetchable memory behind bridge: fcfff00000-fcffffffff [size=1M] [32-bit]
