Done a fresh install from a live usb.
Everything seems to have gone fine during installation.
Reboot and I am now looking at a screen saying
Arch Linux 5.16.2-arch1-1 (tty1)
User-name login: _
I can log in to the system but there is no normal desktop only terminal prompt
Coming to think of it, I chose for the online installation and coming to think of it the installer said I was of line - which I thought was an installer mistake because the machine was on line (I did made some donation to EOS)
Any how - is it a question of re installing or is there a way to add the DE on the base Arch ??
Thank you
Selecting a Display Manager, may have to do with your Display Environment or Window Manager you are using. SDDM is easy, LightDM is… light and needs a greeter.
Log in the console/TTY (black screen) with your credentials (username/password).
Update your system and add sddm or lightdm lightdm-gtk-greeter
sudo pacman -Syu sddm
If there are no significant errors, enable and start sddm.
we do work on a way to omit that users do not tag DE/WM on installs, as there is none selected per default, only if you choose offline install it will install the one used also on the ISO (XFCE4).
calamares only does a simple network connectivity check.
But if no internet is connected online install will not be possible, you will get a notification and you can to proceed with install:
