Hi,
I did a fresh installation of the most recent release of Endeavour OS on an Acer Aspire5745g laptop. I cannot use WiFi. I can see my WiFi network under “WiFi Networks > Available Networks” but when I enter it’s password a connection is not established.
For network adapters lspci shows:
02:00.0 Ethernet controller: Qualcomm Atheros AR8151 v1.0 Gigabit Ethernet (rev c0)
03:00.0 Network controller: Qualcomm Atheros AR9287 Wireless Network Adapter (PCI-Express) (rev 01)
I am using a Lan cable and can use the Ethernet adapter to go online.
What do I need to do to connect to the Internet via WiFi?
Open a terminal and run the following command:
journalctl -f
While the above command is running, try to connect to wifi.
When it fails, do you see any relevant messages in the terminal output? If positive, copy and paste them in your reply, highlight the text and format it by clicking on </>.
Just guessing, but maybe package linux-firmware-qcom needs to be installed.
@Lincat11
What does this show?
inxi -Na
Is it using the ath9k module?
Here is the result from running journalctl -f. I selected my WiFi two times:
[user@Aspire5745g ~]$ journalctl -f
May 25 05:24:25 Aspire5745g systemd[553]: Starting Virtual filesystem service - Media Transfer Protocol monitor...
May 25 05:24:25 Aspire5745g dbus-daemon[569]: [session uid=1000 pid=569] Successfully activated service 'org.gtk.vfs.MTPVolumeMonitor'
May 25 05:24:25 Aspire5745g systemd[553]: Started Virtual filesystem service - Media Transfer Protocol monitor.
May 25 05:24:25 Aspire5745g dbus-daemon[569]: [session uid=1000 pid=569] Successfully activated service 'org.freedesktop.thumbnails.Thumbnailer1'
May 25 05:24:25 Aspire5745g dbus-daemon[569]: [session uid=1000 pid=569] Activating via systemd: service name='org.gtk.vfs.Metadata' unit='gvfs-metadata.service' requested by ':1.19' (uid=1000 pid=647 comm="xfdesktop")
May 25 05:24:26 Aspire5745g systemd[553]: Starting Virtual filesystem metadata service...
May 25 05:24:26 Aspire5745g dbus-daemon[569]: [session uid=1000 pid=569] Successfully activated service 'org.gtk.vfs.Metadata'
May 25 05:24:26 Aspire5745g systemd[553]: Started Virtual filesystem metadata service.
May 25 05:24:30 Aspire5745g systemd-timesyncd[251]: Contacted time server 44.190.6.254:123 (0.arch.pool.ntp.org).
May 25 05:24:30 Aspire5745g systemd-timesyncd[251]: Initial clock synchronization to Wed 2022-05-25 05:24:31.042925 EDT.
May 25 05:26:13 Aspire5745g NetworkManager[387]: <info> [1653470773.1112] device (wlan0): Activation: starting connection 'HEZZ6' (f0ce663d-f2c5-411a-8a1e-7baaf6a7bce2)
May 25 05:26:13 Aspire5745g NetworkManager[387]: <info> [1653470773.1116] audit: op="connection-activate" uuid="f0ce663d-f2c5-411a-8a1e-7baaf6a7bce2" name="HEZZ6" pid=716 uid=1000 result="success"
May 25 05:26:13 Aspire5745g NetworkManager[387]: <info> [1653470773.1118] device (wlan0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
May 25 05:26:13 Aspire5745g audit[387]: USYS_CONFIG pid=387 uid=0 auid=4294967295 ses=4294967295 msg='op=connection-activate uuid=f0ce663d-f2c5-411a-8a1e-7baaf6a7bce2 name="HEZZ6" pid=716 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
May 25 05:26:13 Aspire5745g kernel: audit: type=1111 audit(1653470773.108:120): pid=387 uid=0 auid=4294967295 ses=4294967295 msg='op=connection-activate uuid=f0ce663d-f2c5-411a-8a1e-7baaf6a7bce2 name="HEZZ6" pid=716 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
May 25 05:26:13 Aspire5745g NetworkManager[387]: <info> [1653470773.1255] device (wlan0): set-hw-addr: reset MAC address to 5C:AC:4C:32:B7:09 (preserve)
May 25 05:26:13 Aspire5745g NetworkManager[387]: <info> [1653470773.1448] device (wlan0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
May 25 05:26:13 Aspire5745g NetworkManager[387]: <info> [1653470773.1456] device (wlan0): Activation: (wifi) access point 'HEZZ6' has security, but secrets are required.
May 25 05:26:13 Aspire5745g NetworkManager[387]: <info> [1653470773.1456] device (wlan0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
May 25 05:26:13 Aspire5745g NetworkManager[387]: <info> [1653470773.1462] device (wlan0): supplicant interface state: inactive -> interface_disabled
May 25 05:26:13 Aspire5745g NetworkManager[387]: <info> [1653470773.1463] device (p2p-dev-wlan0): supplicant management interface state: inactive -> interface_disabled
May 25 05:26:13 Aspire5745g NetworkManager[387]: <info> [1653470773.1482] device (wlan0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
May 25 05:26:13 Aspire5745g NetworkManager[387]: <info> [1653470773.1488] device (wlan0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
May 25 05:26:13 Aspire5745g NetworkManager[387]: <info> [1653470773.1492] device (wlan0): Activation: (wifi) connection 'HEZZ6' has security, and secrets exist. No new secrets needed.
May 25 05:26:13 Aspire5745g NetworkManager[387]: <info> [1653470773.1493] Config: added 'ssid' value 'HEZZ6'
May 25 05:26:13 Aspire5745g NetworkManager[387]: <info> [1653470773.1493] Config: added 'scan_ssid' value '1'
May 25 05:26:13 Aspire5745g NetworkManager[387]: <info> [1653470773.1493] Config: added 'bgscan' value 'simple:30:-70:86400'
May 25 05:26:13 Aspire5745g NetworkManager[387]: <info> [1653470773.1493] Config: added 'key_mgmt' value 'NONE'
May 25 05:26:13 Aspire5745g NetworkManager[387]: <info> [1653470773.1494] Config: added 'wep_key0' value '<hidden>'
May 25 05:26:13 Aspire5745g NetworkManager[387]: <info> [1653470773.1494] Config: added 'wep_tx_keyidx' value '0'
May 25 05:26:13 Aspire5745g NetworkManager[387]: <info> [1653470773.1600] device (wlan0): supplicant interface state: interface_disabled -> inactive
May 25 05:26:13 Aspire5745g NetworkManager[387]: <info> [1653470773.1601] device (p2p-dev-wlan0): supplicant management interface state: interface_disabled -> inactive
May 25 05:26:13 Aspire5745g NetworkManager[387]: <warn> [1653470773.1617] sup-iface[bed927045e6fb9ff,0,wlan0]: assoc[9765049770223a5a]: failure to add network: invalid message format
May 25 05:26:13 Aspire5745g NetworkManager[387]: <info> [1653470773.1618] device (wlan0): state change: config -> failed (reason 'supplicant-failed', sys-iface-state: 'managed')
May 25 05:26:13 Aspire5745g NetworkManager[387]: <warn> [1653470773.1624] device (wlan0): Activation: failed for connection 'HEZZ6'
May 25 05:26:13 Aspire5745g NetworkManager[387]: <info> [1653470773.1627] device (wlan0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
May 25 05:26:13 Aspire5745g NetworkManager[387]: <info> [1653470773.1731] device (wlan0): set-hw-addr: set MAC address to 66:33:63:41:72:ED (scanning)
May 25 05:26:13 Aspire5745g NetworkManager[387]: <info> [1653470773.1926] device (wlan0): supplicant interface state: inactive -> interface_disabled
May 25 05:26:13 Aspire5745g NetworkManager[387]: <info> [1653470773.1928] device (p2p-dev-wlan0): supplicant management interface state: inactive -> interface_disabled
May 25 05:26:13 Aspire5745g NetworkManager[387]: <info> [1653470773.2284] device (wlan0): supplicant interface state: interface_disabled -> inactive
May 25 05:26:13 Aspire5745g NetworkManager[387]: <info> [1653470773.2285] device (p2p-dev-wlan0): supplicant management interface state: interface_disabled -> inactive
May 25 05:26:29 Aspire5745g NetworkManager[387]: <info> [1653470789.0508] device (wlan0): Activation: starting connection 'HEZZ6' (f0ce663d-f2c5-411a-8a1e-7baaf6a7bce2)
May 25 05:26:29 Aspire5745g NetworkManager[387]: <info> [1653470789.0511] audit: op="connection-activate" uuid="f0ce663d-f2c5-411a-8a1e-7baaf6a7bce2" name="HEZZ6" pid=716 uid=1000 result="success"
May 25 05:26:29 Aspire5745g NetworkManager[387]: <info> [1653470789.0513] device (wlan0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
May 25 05:26:29 Aspire5745g audit[387]: USYS_CONFIG pid=387 uid=0 auid=4294967295 ses=4294967295 msg='op=connection-activate uuid=f0ce663d-f2c5-411a-8a1e-7baaf6a7bce2 name="HEZZ6" pid=716 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
May 25 05:26:29 Aspire5745g kernel: audit: type=1111 audit(1653470789.047:121): pid=387 uid=0 auid=4294967295 ses=4294967295 msg='op=connection-activate uuid=f0ce663d-f2c5-411a-8a1e-7baaf6a7bce2 name="HEZZ6" pid=716 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
May 25 05:26:29 Aspire5745g NetworkManager[387]: <info> [1653470789.0655] device (wlan0): set-hw-addr: reset MAC address to 5C:AC:4C:32:B7:09 (preserve)
May 25 05:26:29 Aspire5745g NetworkManager[387]: <info> [1653470789.0848] device (wlan0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
May 25 05:26:29 Aspire5745g NetworkManager[387]: <info> [1653470789.0853] device (wlan0): Activation: (wifi) access point 'HEZZ6' has security, but secrets are required.
May 25 05:26:29 Aspire5745g NetworkManager[387]: <info> [1653470789.0853] device (wlan0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
May 25 05:26:29 Aspire5745g NetworkManager[387]: <info> [1653470789.0859] device (wlan0): supplicant interface state: inactive -> interface_disabled
May 25 05:26:29 Aspire5745g NetworkManager[387]: <info> [1653470789.0860] device (p2p-dev-wlan0): supplicant management interface state: inactive -> interface_disabled
May 25 05:26:29 Aspire5745g NetworkManager[387]: <info> [1653470789.0876] device (wlan0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
May 25 05:26:29 Aspire5745g NetworkManager[387]: <info> [1653470789.0880] device (wlan0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
May 25 05:26:29 Aspire5745g NetworkManager[387]: <info> [1653470789.0884] device (wlan0): Activation: (wifi) connection 'HEZZ6' has security, and secrets exist. No new secrets needed.
May 25 05:26:29 Aspire5745g NetworkManager[387]: <info> [1653470789.0884] Config: added 'ssid' value 'HEZZ6'
May 25 05:26:29 Aspire5745g NetworkManager[387]: <info> [1653470789.0884] Config: added 'scan_ssid' value '1'
May 25 05:26:29 Aspire5745g NetworkManager[387]: <info> [1653470789.0884] Config: added 'bgscan' value 'simple:30:-70:86400'
May 25 05:26:29 Aspire5745g NetworkManager[387]: <info> [1653470789.0885] Config: added 'key_mgmt' value 'NONE'
May 25 05:26:29 Aspire5745g NetworkManager[387]: <info> [1653470789.0885] Config: added 'wep_key0' value '<hidden>'
May 25 05:26:29 Aspire5745g NetworkManager[387]: <info> [1653470789.0885] Config: added 'wep_tx_keyidx' value '0'
May 25 05:26:29 Aspire5745g NetworkManager[387]: <info> [1653470789.1303] device (wlan0): supplicant interface state: interface_disabled -> inactive
May 25 05:26:29 Aspire5745g NetworkManager[387]: <info> [1653470789.1304] device (p2p-dev-wlan0): supplicant management interface state: interface_disabled -> inactive
May 25 05:26:29 Aspire5745g NetworkManager[387]: <warn> [1653470789.1333] sup-iface[bed927045e6fb9ff,0,wlan0]: assoc[a51d2662ba04e3cd]: failure to add network: invalid message format
May 25 05:26:29 Aspire5745g NetworkManager[387]: <info> [1653470789.1334] device (wlan0): state change: config -> failed (reason 'supplicant-failed', sys-iface-state: 'managed')
May 25 05:26:29 Aspire5745g NetworkManager[387]: <info> [1653470789.1456] device (wlan0): set-hw-addr: set MAC address to 26:84:26:10:B4:0D (scanning)
May 25 05:26:29 Aspire5745g NetworkManager[387]: <warn> [1653470789.1649] device (wlan0): Activation: failed for connection 'HEZZ6'
May 25 05:26:29 Aspire5745g NetworkManager[387]: <info> [1653470789.1652] device (wlan0): supplicant interface state: inactive -> interface_disabled
May 25 05:26:29 Aspire5745g NetworkManager[387]: <info> [1653470789.1652] device (p2p-dev-wlan0): supplicant management interface state: inactive -> interface_disabled
May 25 05:26:29 Aspire5745g NetworkManager[387]: <info> [1653470789.1660] device (wlan0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
May 25 05:26:29 Aspire5745g NetworkManager[387]: <info> [1653470789.1867] device (wlan0): supplicant interface state: interface_disabled -> inactive
May 25 05:26:29 Aspire5745g NetworkManager[387]: <info> [1653470789.1867] device (p2p-dev-wlan0): supplicant management interface state: interface_disabled -> inactive
^C
[user@Aspire5745g ~]$`Preformatted text`
Here is the output from inxi -Na. ath9k driver/module is shown below:
[user@Aspire5745g ~]$ inxi -Na
Device-1: Qualcomm Atheros AR8151 v1.0 Gigabit Ethernet
vendor: Acer Incorporated ALI driver: atl1c v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 02:00.0 chip-ID: 1969:1073
class-ID: 0200
Device-2: Qualcomm Atheros AR9287 Wireless Network Adapter
vendor: Foxconn T77H167.00 driver: ath9k v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 168c:002e
class-ID: 0280
So the module is loaded. It just won’t connect?
Thanks for the reply!
For better readability, please edit your post and format the pasted text by highlighting it and clicking on </>.
Yes. I rechecked the password. I can see my WiFi and it is shown with a red exclamation mark. I also ran pacman -S linux-firmware-qcom and rebooted.
Ok, I will from now on. Thank you.
Try the following
sudo nano /etc/modprobe.d/ath9k.conf
add
options ath9k nohwcrypt=1
ctrl + o then enter to save
ctrl + x to exit nano
reboot and try to connect
pebcak
May 25, 2022, 10:00am
12
This might point to the issue.
I’m not using wpa_supplicant so I am not sure what to look for to troubleshoot. I’ll dig a bit.
what says:
systemctl status wpa_supplicant
PS- You could edit your previous post by clicking on the pen icon and format the text
You can do the same for post #6 Always use code tags when posting output.
I added “options ath9k nohwcrypt=1” to /etc/modprobe.d/ath9k.conf and rebooted
No change on my WiFi connectivity,
Here is the output for
[user@Aspire5745g ~]$ systemctl status wpa_supplicant
● wpa_supplicant.service - WPA supplicant
Loaded: loaded (/usr/lib/systemd/system/wpa_supplicant.service; disabled; vendor preset: disab>
Active: active (running) since Wed 2022-05-25 06:07:56 EDT; 6min ago
Main PID: 407 (wpa_supplicant)
Tasks: 1 (limit: 4299)
Memory: 4.8M
CPU: 480ms
CGroup: /system.slice/wpa_supplicant.service
└─407 /usr/bin/wpa_supplicant -u
May 25 06:07:56 Aspire5745g systemd[1]: Starting WPA supplicant...
May 25 06:07:56 Aspire5745g systemd[1]: Started WPA supplicant.
May 25 06:07:57 Aspire5745g wpa_supplicant[407]: Successfully initialized wpa_supplicant
lines 1-13/13 (END)
Yes, I can see the difference. Thank you.
pebcak
May 25, 2022, 10:18am
18
The issue seems to be less about wifi connectivity than the authentication. While the former works, the latter seems to fail.
I entered the commands
[user@Aspire5745g ~]$ sudo modprobe -r ath9k
[sudo] password for user:
[user@Aspire5745g ~]$ sudo modprobe ath9k
Should I have seen an output in terminal?
pebcak
May 25, 2022, 10:20am
20
Please format your code properly!
Refer to some previous post of mine to see how-to
Thanks!
