Zut
1
Hi, I just installed Cassini 22_12. Working great, but I can’t get OpenVPN to connect automatically. I can connect to the VPN manually.
I used Advanced Network Connection in previous EOS editions. You could set the network connection to use the vpn on startup.
I don’t see how to do that now? Any suggestions?
Thanks Very Much!
Z
pebcak
2
Try installing nm-connection-editor
sudo pacman -Syu nm-connection-editor
The above will update your system and install the package.
Zut
3
Worked perfectly pebcak! Thanks very much.
This forum is why I am a devout EOS user!
Cheers
Z
system
Closed
4
