I just installed endeavouros yesterday and im having an issue where when i tell the computer to sleep, it freezes. the screen goes partway into the login screen, and then everything is unresponsive. i am able to REISUB but the mouse and keyboard don’t do anything otherwise.
when i run inxi -Fxxc0z
i get:
output
Kernel: 6.6.23-1-lts arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
Desktop: KDE Plasma v: 6.0.3 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
Type: Desktop Mobo: Gigabyte model: B660M DS3H DDR4
serial: UEFI: American Megatrends LLC. v: F21
date: 11/15/2022
Info: quad core model: 12th Gen Intel Core i3-12100F bits: 64 type: MT MCP
arch: Alder Lake rev: 5 cache: L1: 320 KiB L2: 5 MiB L3: 12 MiB
Speed (MHz): avg: 800 min/max: 800/4300 cores: 1: 800 2: 800 3: 800 4: 800
5: 800 6: 800 7: 800 8: 800 bogomips: 52856
Device-1: AMD Navi 23 [Radeon RX 6600/6600 XT/6600M] vendor: XFX
driver: amdgpu v: kernel arch: RDNA-2 pcie: speed: 16 GT/s lanes: 16 ports:
active: DP-3,HDMI-A-1 empty: DP-1,DP-2 bus-ID: 03:00.0 chip-ID: 1002:73ff
Display: wayland server: X.org v: 1.21.1.12 with: Xwayland v: 23.2.5
gpu: amdgpu d-rect: 4480x2520 display-ID: 0
Monitor-1: DP-3 pos: primary,top-left res: 2560x1440 size: N/A
Monitor-2: HDMI-A-1 pos: bottom-r res: 1920x1080 size: N/A
API: EGL v: 1.5 platforms: device: 0 drv: radeonsi device: 1 drv: swrast
surfaceless: drv: radeonsi wayland: drv: radeonsi x11: drv: radeonsi
inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.4-arch1.2
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6600 (radeonsi navi23
LLVM 17.0.6 DRM 3.54 6.6.23-1-lts) device-ID: 1002:73ff display-ID: :1.0
Device-1: Intel Alder Lake-S HD Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel bus-ID: 00:1f.3 chip-ID: 8086:7ad0
Device-2: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel
pcie: speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
API: ALSA v: k6.6.23-1-lts status: kernel-api
Server-1: PipeWire v: 1.0.4 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin
Device-1: Realtek RTL8125 2.5GbE vendor: Gigabyte driver: r8169 v: kernel
pcie: speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 06:00.0 chip-ID: 10ec:8125
IF: enp6s0 state: up speed: 100 Mbps duplex: full mac:
Device-2: Broadcom BCM4360 802.11ac Dual Band Wireless Network Adapter
vendor: ASUSTeK driver: wl v: kernel pcie: speed: 2.5 GT/s lanes: 1
bus-ID: 07:00.0 chip-ID: 14e4:43a0
Bluetooth:
Device-1: TP-Link UB500 Adapter driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 bus-ID: 1-3:3 chip-ID: 2357:0604
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: bt-v: 5.1
lmp-v: 10
Local Storage: total: 931.51 GiB used: 25.28 GiB (2.7%)
ID-1: /dev/nvme0n1 vendor: Western Digital model: WD Blue SN570 1TB
size: 931.51 GiB speed: 31.6 Gb/s lanes: 4 serial: temp: 33.9 C
ID-1: / size: 579.39 GiB used: 12.05 GiB (2.1%) fs: ext4 dev: /dev/nvme0n1p5
ID-2: /boot/efi size: 96 MiB used: 26.7 MiB (27.8%) fs: vfat
dev: /dev/nvme0n1p1
ID-3: /home size: 119.97 GiB used: 13.2 GiB (11.0%) fs: ext4
dev: /dev/nvme0n1p6
System Temperatures: cpu: 33.0 C mobo: 29.0 C gpu: amdgpu temp: 33.0 C
mem: 30.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 0
Memory: total: 32 GiB available: 31.19 GiB used: 8.97 GiB (28.8%)
Processes: 298 Power: uptime: 10m wakeups: 0 Init: systemd v: 255
default: graphical
Packages: pm: pacman pkgs: 1019 Compilers: gcc: 13.2.1 Shell: Bash
v: 5.2.26 running-in: konsole inxi: 3.3.33
please tell me if there is any other information i should post! i really need some help.
