Freezes a couple of seconds/minute after updates
What is this showing? What is the command you used?
But it works perfectly fine!
It’s just like the user in that other thread had. It just freezes a bit and then it works :slight_smile:
EndeavourOS doesn’t have flatpak installed.
flatpak list
It shows all flatpaks installed.
Here is a better list
https://clbin.com/LgPy2
EDIT: Maybe it’s KDE? Since it’s mostly it’s applications in it. I only installed Discord and Transmission. Nothing else.
It’s not KDE! We have many of us here using kde for more than 3 years on EOS with zero issues including myself.
So strange still then. I promise you, I haven’t manually installed it.
Anyway I removed Bauh, so lets see if it helps. “Yay” showed no updates.
I don’t blame KDE for the freezes, just maybe KDE included flatpak but apparently not.
First version of EOS I installed with Nvidia drivers where Atlantis.
EDIT: ran the “UpdateInTerminal” and it found an update to “rust”. I will reboot my computer before I update just to be sure.
I would believe it’s flatpak for sure if anything.
Maybe!
Anyways just after updating:
https://clbin.com/URMV1
Same after the freezes.I wonder if it have to do with the Tuxedo Control Center. It controls the fans, power etc. Since they don’t have official support for “Arch” it might interfere.
EDIT: Oh right, here is the other https://clbin.com/jR1Nv
EDIT2: Thanks for all the help btw <3
What does this show if anything?
journalctl | grep -i "hardware err"
If it is only after doing a full system upgrade, then you should check all alpm/pacman hooks and find if it happens when a specific package is updated, or for any package(s).
You could also find any timers that may have been installed/enabled from some system utility, like bauh or flatpak, or Discovery, or Gnome Software.
Since you know when it happens, just set a trap :wink:
Before running an update, have a terminal (or two) open running htop, sorted by CPU usage (and/or journalctl -f to watch any useful message).
If I misunderstood, please, explain more.
I also haven’t understood what is that list posted, flatpaks?
You seem to ignore advice to post also the input (command you used to run and get output). Is there a reason, or just forgotten?
Sadly it’s blank.
Hi! Sorry, it even happens when I remove a software. It’s very strange, it’s more interesting than not to find the culprit than an actually big issue.
About flatpak it was just a hunch that it might cause some issues, but nay. It shouldn’t, I think?
I’ve tried to remove Bauh and even Tuxedo Control Center but avast, same issue(s).
I now done a timeshift back, so it’s “back again” to where it was when the issues begun again, to try to nail it down.
EDIT: I will do a journalctl -f,before I do an update next to the system. It seem to only affect when I do a pacman upgrade (or yay), flatpak seems to just roll on like clockwork.
Re-installing might help.
Flatpak does not belong to the default packages in EndeavourOS.
And I wouldn’t recommend using flatpak either, unless you know exactly what the consequences are.
Some updates are available at this very moment.
After recommendations I’ve removed Flatpak completely and I’ve removed Bauh since it’s unnecessary.
I’ll take a journalctl -f now and update, brb with an edit.
EDIT:
maj 19 23:30:50 swebow-xmgcoreczne21 systemd[1]: libvirtd.service: Deactivated successfully.
maj 19 23:30:50 swebow-xmgcoreczne21 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=libvirtd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
maj 19 23:30:50 swebow-xmgcoreczne21 systemd[1]: libvirtd.service: Unit process 819 (dnsmasq) remains running after unit stopped.
maj 19 23:30:50 swebow-xmgcoreczne21 systemd[1]: libvirtd.service: Unit process 820 (dnsmasq) remains running after unit stopped.
maj 19 23:30:50 swebow-xmgcoreczne21 kernel: audit: type=1131 audit(1652995850.687:139): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=libvirtd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
maj 19 23:30:52 swebow-xmgcoreczne21 kwin_x11[1005]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 21024, resource id: 41943269, major code: 18 (ChangeProperty), minor code: 0
maj 19 23:30:52 swebow-xmgcoreczne21 systemd[926]: Started UpdateInTerminal.
maj 19 23:30:52 swebow-xmgcoreczne21 kwin_x11[1005]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 21168, resource id: 41943270, major code: 18 (ChangeProperty), minor code: 0
maj 19 23:30:52 swebow-xmgcoreczne21 plasmashell[1080]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipDelegate.qml:89:9: QML ScrollView: Binding loop detected for property "bottomPadding"
maj 19 23:31:01 swebow-xmgcoreczne21 su[3882]: (to root) swebow on pts/1
maj 19 23:31:01 swebow-xmgcoreczne21 kernel: audit: type=1100 audit(1652995861.884:140): pid=3882 uid=1000 auid=1000 ses=2 msg='op=PAM:authentication grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=? addr=? terminal=/dev/pts/1 res=success'
maj 19 23:31:01 swebow-xmgcoreczne21 kernel: audit: type=1101 audit(1652995861.884:141): pid=3882 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=? addr=? terminal=/dev/pts/1 res=success'
maj 19 23:31:01 swebow-xmgcoreczne21 kernel: audit: type=1103 audit(1652995861.884:142): pid=3882 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=? addr=? terminal=/dev/pts/1 res=success'
maj 19 23:31:01 swebow-xmgcoreczne21 kernel: audit: type=1105 audit(1652995861.884:143): pid=3882 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=? addr=? terminal=/dev/pts/1 res=success'
maj 19 23:31:01 swebow-xmgcoreczne21 audit[3882]: USER_AUTH pid=3882 uid=1000 auid=1000 ses=2 msg='op=PAM:authentication grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=? addr=? terminal=/dev/pts/1 res=success'
maj 19 23:31:01 swebow-xmgcoreczne21 audit[3882]: USER_ACCT pid=3882 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=? addr=? terminal=/dev/pts/1 res=success'
maj 19 23:31:01 swebow-xmgcoreczne21 audit[3882]: CRED_ACQ pid=3882 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=? addr=? terminal=/dev/pts/1 res=success'
maj 19 23:31:01 swebow-xmgcoreczne21 audit[3882]: USER_START pid=3882 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=? addr=? terminal=/dev/pts/1 res=success'
maj 19 23:31:01 swebow-xmgcoreczne21 su[3882]: pam_unix(su:session): session opened for user root(uid=0) by (uid=1000)
maj 19 23:31:58 swebow-xmgcoreczne21 kwin_x11[1005]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 31736, resource id: 56623115, major code: 18 (ChangeProperty), minor code: 0
maj 19 23:32:02 swebow-xmgcoreczne21 rtkit-daemon[1226]: Supervising 7 threads of 5 processes of 1 users.
maj 19 23:32:11 swebow-xmgcoreczne21 crontab[4534]: (root) LIST (root)
maj 19 23:32:11 swebow-xmgcoreczne21 crontab[4535]: (root) LIST (root)
maj 19 23:32:12 swebow-xmgcoreczne21 crontab[4579]: (root) LIST (root)
maj 19 23:32:12 swebow-xmgcoreczne21 crontab[4580]: (root) LIST (root)
maj 19 23:32:12 swebow-xmgcoreczne21 crontab[4633]: (root) LIST (root)
maj 19 23:32:12 swebow-xmgcoreczne21 crontab[4634]: (root) LIST (root)
maj 19 23:32:14 swebow-xmgcoreczne21 kernel: SGI XFS with ACLs, security attributes, realtime, scrub, repair, quota, no debug enabled
maj 19 23:32:14 swebow-xmgcoreczne21 kernel: JFS: nTxBlock = 8192, nTxLock = 65536
maj 19 23:32:14 swebow-xmgcoreczne21 os-prober[5366]: debug: running /usr/lib/os-probes/mounted/05efi on mounted /dev/nvme0n1p1
maj 19 23:32:14 swebow-xmgcoreczne21 05efi[5368]: debug: /dev/nvme0n1p1 is a FAT32 partition
maj 19 23:32:14 swebow-xmgcoreczne21 05efi[5376]: debug: /dev/nvme0n1p1 partition scheme is gpt
maj 19 23:32:14 swebow-xmgcoreczne21 05efi[5377]: debug: /dev/nvme0n1p1 partition type is c12a7328-f81f-11d2-ba4b-00a0c93ec93b
maj 19 23:32:14 swebow-xmgcoreczne21 05efi[5381]: debug: running subtest /usr/lib/os-probes/mounted/efi/10elilo
maj 19 23:32:14 swebow-xmgcoreczne21 05efi[5384]: debug: running subtest /usr/lib/os-probes/mounted/efi/20microsoft
maj 19 23:32:14 swebow-xmgcoreczne21 os-prober[5389]: debug: running /usr/lib/os-probes/mounted/10freedos on mounted /dev/nvme0n1p1
maj 19 23:32:14 swebow-xmgcoreczne21 10freedos[5391]: debug: /dev/nvme0n1p1 is a FAT32 partition
maj 19 23:32:14 swebow-xmgcoreczne21 os-prober[5394]: debug: running /usr/lib/os-probes/mounted/10qnx on mounted /dev/nvme0n1p1
maj 19 23:32:14 swebow-xmgcoreczne21 10qnx[5396]: debug: /dev/nvme0n1p1 is not a QNX4 partition: exiting
maj 19 23:32:14 swebow-xmgcoreczne21 os-prober[5397]: debug: running /usr/lib/os-probes/mounted/20macosx on mounted /dev/nvme0n1p1
maj 19 23:32:14 swebow-xmgcoreczne21 macosx-prober[5399]: debug: /dev/nvme0n1p1 is not an HFS+ partition: exiting
maj 19 23:32:14 swebow-xmgcoreczne21 os-prober[5400]: debug: running /usr/lib/os-probes/mounted/20microsoft on mounted /dev/nvme0n1p1
maj 19 23:32:14 swebow-xmgcoreczne21 20microsoft[5402]: debug: Skipping legacy bootloaders on UEFI system
maj 19 23:32:14 swebow-xmgcoreczne21 os-prober[5403]: debug: running /usr/lib/os-probes/mounted/30utility on mounted /dev/nvme0n1p1
maj 19 23:32:14 swebow-xmgcoreczne21 30utility[5405]: debug: /dev/nvme0n1p1 is a FAT32 partition
maj 19 23:32:14 swebow-xmgcoreczne21 os-prober[5410]: debug: running /usr/lib/os-probes/mounted/40lsb on mounted /dev/nvme0n1p1
maj 19 23:32:14 swebow-xmgcoreczne21 os-prober[5412]: debug: running /usr/lib/os-probes/mounted/70hurd on mounted /dev/nvme0n1p1
maj 19 23:32:14 swebow-xmgcoreczne21 os-prober[5414]: debug: running /usr/lib/os-probes/mounted/80minix on mounted /dev/nvme0n1p1
maj 19 23:32:14 swebow-xmgcoreczne21 os-prober[5416]: debug: running /usr/lib/os-probes/mounted/83haiku on mounted /dev/nvme0n1p1
maj 19 23:32:14 swebow-xmgcoreczne21 83haiku[5418]: debug: /dev/nvme0n1p1 is not a BeFS partition: exiting
maj 19 23:32:14 swebow-xmgcoreczne21 os-prober[5419]: debug: running /usr/lib/os-probes/mounted/90linux-distro on mounted /dev/nvme0n1p1
maj 19 23:32:14 swebow-xmgcoreczne21 os-prober[5424]: debug: running /usr/lib/os-probes/mounted/90solaris on mounted /dev/nvme0n1p1
maj 19 23:32:14 swebow-xmgcoreczne21 os-prober[5440]: debug: /dev/nvme0n1p3: is active swap
maj 19 23:32:16 swebow-xmgcoreczne21 systemd[1]: tmp-grub\x2dbtrfs.XWPCpMmTal.mount: Deactivated successfully.
maj 19 23:32:26 swebow-xmgcoreczne21 rtkit-daemon[1226]: Supervising 7 threads of 5 processes of 1 users.
maj 19 23:32:30 swebow-xmgcoreczne21 rtkit-daemon[1226]: Supervising 7 threads of 5 processes of 1 users.
maj 19 23:33:01 swebow-xmgcoreczne21 kwin_x11[1005]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
maj 19 23:33:01 swebow-xmgcoreczne21 kwin_x11[1005]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 55431, resource id: 16788422, major code: 3 (GetWindowAttributes), minor code: 0
maj 19 23:33:01 swebow-xmgcoreczne21 kwin_x11[1005]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 55432, resource id: 16788422, major code: 14 (GetGeometry), minor code: 0
maj 19 23:33:01 swebow-xmgcoreczne21 kwin_x11[1005]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 55435, resource id: 16788422, major code: 3 (GetWindowAttributes), minor code: 0
maj 19 23:33:01 swebow-xmgcoreczne21 kwin_x11[1005]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 55436, resource id: 16788422, major code: 14 (GetGeometry), minor code: 0
maj 19 23:33:05 swebow-xmgcoreczne21 org_kde_powerdevil[1075]: kf.notifications: Audio notification requested, but sound file from notifyrc file was not found, aborting audio notification
maj 19 23:33:10 swebow-xmgcoreczne21 kded5[1002]: kf.service.services: The desktop entry file "/usr/share/applications/qemu.desktop" has Type= "Application" but no Exec line
maj 19 23:33:10 swebow-xmgcoreczne21 kded5[1002]: kf.service.sycoca: Invalid Service :  "/usr/share/applications/qemu.desktop"
maj 19 23:33:13 swebow-xmgcoreczne21 systemd[1]: Reloading.
maj 19 23:33:13 swebow-xmgcoreczne21 systemd[1]: mullvad-daemon.service: Current command vanished from the unit file, execution of the command list won't be resumed.
maj 19 23:33:13 swebow-xmgcoreczne21 kernel: audit: type=1334 audit(1652995993.207:144): prog-id=27 op=LOAD
maj 19 23:33:13 swebow-xmgcoreczne21 kernel: audit: type=1334 audit(1652995993.207:145): prog-id=0 op=UNLOAD
maj 19 23:33:13 swebow-xmgcoreczne21 kernel: audit: type=1334 audit(1652995993.207:146): prog-id=28 op=LOAD
maj 19 23:33:13 swebow-xmgcoreczne21 kernel: audit: type=1334 audit(1652995993.207:147): prog-id=29 op=LOAD
maj 19 23:33:13 swebow-xmgcoreczne21 kernel: audit: type=1334 audit(1652995993.207:148): prog-id=0 op=UNLOAD
maj 19 23:33:13 swebow-xmgcoreczne21 kernel: audit: type=1334 audit(1652995993.207:149): prog-id=0 op=UNLOAD
maj 19 23:33:13 swebow-xmgcoreczne21 kernel: audit: type=1334 audit(1652995993.207:150): prog-id=30 op=LOAD
maj 19 23:33:13 swebow-xmgcoreczne21 kernel: audit: type=1334 audit(1652995993.207:151): prog-id=31 op=LOAD
maj 19 23:33:13 swebow-xmgcoreczne21 kernel: audit: type=1334 audit(1652995993.207:152): prog-id=0 op=UNLOAD
maj 19 23:33:13 swebow-xmgcoreczne21 kernel: audit: type=1334 audit(1652995993.207:153): prog-id=0 op=UNLOAD
maj 19 23:33:13 swebow-xmgcoreczne21 audit: BPF prog-id=27 op=LOAD
maj 19 23:33:13 swebow-xmgcoreczne21 audit: BPF prog-id=0 op=UNLOAD
maj 19 23:33:13 swebow-xmgcoreczne21 audit: BPF prog-id=28 op=LOAD
maj 19 23:33:13 swebow-xmgcoreczne21 audit: BPF prog-id=29 op=LOAD
maj 19 23:33:13 swebow-xmgcoreczne21 audit: BPF prog-id=30 op=LOAD
maj 19 23:33:13 swebow-xmgcoreczne21 audit: BPF prog-id=31 op=LOAD
maj 19 23:33:13 swebow-xmgcoreczne21 audit: BPF prog-id=32 op=LOAD
maj 19 23:33:13 swebow-xmgcoreczne21 audit: BPF prog-id=33 op=LOAD
maj 19 23:33:13 swebow-xmgcoreczne21 audit: BPF prog-id=34 op=LOAD
maj 19 23:33:13 swebow-xmgcoreczne21 audit: BPF prog-id=35 op=LOAD
maj 19 23:33:13 swebow-xmgcoreczne21 audit: BPF prog-id=36 op=LOAD
maj 19 23:33:13 swebow-xmgcoreczne21 audit: BPF prog-id=37 op=LOAD
maj 19 23:33:13 swebow-xmgcoreczne21 audit: BPF prog-id=38 op=LOAD
maj 19 23:33:13 swebow-xmgcoreczne21 audit: BPF prog-id=39 op=LOAD
maj 19 23:33:13 swebow-xmgcoreczne21 audit: BPF prog-id=40 op=LOAD
maj 19 23:33:14 swebow-xmgcoreczne21 plasmashell[1080]: kf.service.services: The desktop entry file "/usr/share/applications/qemu.desktop" has Type= "Application" but no Exec line
maj 19 23:33:14 swebow-xmgcoreczne21 plasmashell[1080]: kf.service.sycoca: Invalid Service :  "/usr/share/applications/qemu.desktop"
maj 19 23:33:14 swebow-xmgcoreczne21 rtkit-daemon[1226]: Supervising 7 threads of 5 processes of 1 users.
maj 19 23:33:14 swebow-xmgcoreczne21 rtkit-daemon[1226]: Successfully made thread 7427 of process 2765 owned by '1000' RT at priority 10.
maj 19 23:33:14 swebow-xmgcoreczne21 rtkit-daemon[1226]: Supervising 8 threads of 6 processes of 1 users.
maj 19 23:33:15 swebow-xmgcoreczne21 su[3882]: pam_unix(su:session): session closed for user root
maj 19 23:33:15 swebow-xmgcoreczne21 audit[3882]: USER_END pid=3882 uid=1000 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=? addr=? terminal=/dev/pts/1 res=success'
maj 19 23:33:15 swebow-xmgcoreczne21 audit[3882]: CRED_DISP pid=3882 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=? addr=? terminal=/dev/pts/1 res=success'
maj 19 23:33:15 swebow-xmgcoreczne21 rtkit-daemon[1226]: Supervising 8 threads of 6 processes of 1 users.
maj 19 23:33:16 swebow-xmgcoreczne21 plasmashell[1080]: kf.service.services: The desktop entry file "/usr/share/applications/qemu.desktop" has Type= "Application" but no Exec line
maj 19 23:33:16 swebow-xmgcoreczne21 plasmashell[1080]: kf.service.sycoca: Invalid Service :  "/usr/share/applications/qemu.desktop"
maj 19 23:33:17 swebow-xmgcoreczne21 rtkit-daemon[1226]: Supervising 8 threads of 6 processes of 1 users.
maj 19 23:33:48 swebow-xmgcoreczne21 kwin_x11[1005]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 9605, resource id: 16788450, major code: 3 (GetWindowAttributes), minor code: 0
maj 19 23:33:48 swebow-xmgcoreczne21 kwin_x11[1005]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 9606, resource id: 16788450, major code: 14 (GetGeometry), minor code: 0
maj 19 23:33:48 swebow-xmgcoreczne21 kwin_x11[1005]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 9609, resource id: 16788450, major code: 3 (GetWindowAttributes), minor code: 0
maj 19 23:33:48 swebow-xmgcoreczne21 kwin_x11[1005]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 9610, resource id: 16788450, major code: 14 (GetGeometry), minor code: 0
EDIT2: It froze during the
etc.
I would just reinstall EOS with KDE nothing else and no changes to anything to see how it works. Had the same issue with another user and reinstalled and everything works no issues.
In such cases, it is always recommended to boot with the LTS kernel, if it is installed at all.
I’ve found the culprit!
It’s Timeshift. When I update, it updates a snapshot. While it does that, it slows the system down. Apparently a known issue, but no real solution?
If you google “timeshift slowdown” it’s a lot of issues with it. I wonder if it’s just Timeshift or other software(s) like it that slows the system down.
I gonna clean out like almost all snapshots from 2 months ago (even tho it shouldn’t keep that old?) and tell it not to keep as many. Let’s see if it makes any difference!
I don’t use timeshift. I use btrfs-assistant with snapshots. Never ever had an issue. :crossed_fingers:
Oh!
Seems to be the two following:
btrfs-cleaner
btrfs-transaction
they seem to be the main culprits that gets triggered
Btw, can I use that software together with grub-btrfs, or lets say in a catastrophic failure, I just boot a livecd?
