For those that multi-boot Linux distros......why?
You know what they say about assume - perhaps it has struck again! Would it depend on which VM solution was in use?
I suppose it could but I can’t think of one off the top of my head that wouldn’t support it.
I have tested all flavors of boot managment solutions in a VM. Honestly, stuff like that is easier to test in a VM because of snapshots. You can instantly revert a VM to a previous state including the bootloader/efi variables/etc
Well - I may not be too old to learn - but I may be too old to make use of the knowledge! :grin: Thanks for the info - and another thing to work on…
I used to be a single distro user (Ubuntu) for a while. I currently have a triple boot setup - Endeavour, Ubuntu and Fedora - one for each of the ā€˜families (arch/debian/redhat-fedora-centos)’ - with a data partition shared between them… I ended up with this when I started distrohopping, but the reasons why I left the multi-boot setup as-is:
  • (As someone already mentioned) - If something fails to boot/breaks - easy to boot into another and fix - failover, essentially
  • I’m in the process of creating software that could be deployed/used on multiple distros - so a more thorough test setup thats not on the cloud - one for each family… (test installing an built .deb, an .rpm, etc with folder structures that could be specific to a distro) without using/affecting the main OS… Thats the idea…
That said, Endeavour has become my main desktop, I havent needed to boot into Ubuntu for a while now… So the first reason may not be valid anymore… I may end up trying out Silverblue - or Qubes - sometime - may revisit this then…
While shoe-horning…
the only point i see in doing it is like i do and dual boot endeavouros with windows and i use windows for gaming (what linux can’t do anyways) and use linux for everything else. i don’t see a real point in dual booting more than one linux os because the only real difference sometimes is package managers and maybe if you wanted to dual boot vanilla arch just to tinker around with it
Thanks for the post and welcome to the forum!
thanks for the info on linux gaming! if i can get the games i want to play to work in linux then i’ll be more than happy to ditch windows completely because i don’t use it for anything else anyways.
Sure, my pleasure :wink:
If you’ll have any trouble or question - just ask in gaming section, maybe we can help figuring it out :upside_down_face:
I’ve dropped Windows couple of years ago, 98% of games from my personal library are working great, but you know…There are some problematic ones, in online realms with DRM i’ve heard (not online player myself).
It’s getting even better with time!
awesome! yea, i’m not an online player either anyways so it won’t hurt my feelings if the online feature doesn’t work. i heard that the new kernel, i think they said 5.12 will have some patches added to fix a lot of games that have issues with DRM. not sure about the exact kernel version but i know that they’re working on it
You mean EndeavourOS and vanilla Arch? There really is no point, they are pretty much identical.
yea, i agee. i just installed endeavor when i made that comment but the more i use it, the more i realize that it’s pretty much identical like you said to vanilla arch
