For a motherboard that doesn't suport my 2400g apu it sure does work well
also i didnt have to go looking for where the xmmp profile was hidden in the bios. it was there in bright bold red on the bios screen,
here i’ll list endeavours inxi first
System:    Kernel: 5.11.6-lqx1-1-lqx x86_64 bits: 64 compiler: gcc v: 10.2.1 Desktop: MATE 1.24.1 Distro: EndeavourOS
           base: Arch Linux
Machine:   Type: Desktop System: Gigabyte product: B550I AORUS PRO AX v: N/A serial: N/A
           Mobo: Gigabyte model: B550I AORUS PRO AX serial: N/A BIOS: American Megatrends LLC. v: F13c date: 02/17/2021
Battery:   Device-1: hidpp_battery_0 model: Logitech M570 charge: 100% status: Discharging
           Device-2: hidpp_battery_1 model: Logitech Wireless Keyboard K360 charge: 100% (should be ignored)
           status: Discharging
Memory:    RAM: total: 15.64 GiB used: 1.89 GiB (12.1%)
           RAM Report: missing: Required program dmidecode not available
CPU:       Info: Quad Core model: AMD Ryzen 5 2400G with Radeon Vega Graphics bits: 64 type: MT MCP arch: Zen rev: 0
           L2 cache: 2 MiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 57494
           Speed: 1604 MHz min/max: 1600/3600 MHz boost: enabled Core speeds (MHz): 1: 1604 2: 1645 3: 1422 4: 1421 5: 1784
           6: 1422 7: 1421 8: 1430
Graphics:  Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere [Radeon RX 470/480/570/570X/580/580X/590] vendor: ASRock
           driver: amdgpu v: kernel bus ID: 01:00.0
           Display: server: X.org 1.20.10 driver: loaded: amdgpu,ati unloaded: fbdev,modesetting,vesa
           resolution: <missing: xdpyinfo>
           OpenGL: renderer: Radeon RX 570 Series (POLARIS10 DRM 3.40.0 5.11.6-lqx1-1-lqx LLVM 11.1.0) v: 4.6 Mesa 20.3.4
           direct render: Yes
Audio:     Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590] vendor: ASRock driver: snd_hda_intel v: kernel
           bus ID: 01:00.1
           Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Gigabyte driver: snd_hda_intel v: kernel
           bus ID: 08:00.6
           Sound Server: ALSA v: k5.11.6-lqx1-1-lqx
Network:   Device-1: Realtek RTL8125 2.5GbE vendor: Gigabyte driver: r8125 v: 9.005.01-NAPI port: e000 bus ID: 06:00.0
           IF: eno1 state: up speed: 1000 Mbps duplex: full mac: <filter>
           Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: e000 bus ID: 07:00.0
Bluetooth: Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus ID: 1-8:4
           Message: Required tool hciconfig not installed. Check --recommends
Drives:    Local Storage: total: 2.85 TiB used: 618.75 GiB (21.2%)
           ID-1: /dev/nvme0n1 vendor: Sabrent model: Rocket Q size: 931.51 GiB temp: 37.9 C
           ID-2: /dev/sda vendor: Seagate model: ST1000LM035-1RK172 size: 931.51 GiB
           ID-3: /dev/sdb vendor: Micron model: MT-128 size: 119.24 GiB
           ID-4: /dev/sdc vendor: Toshiba model: MK5075GSX size: 465.76 GiB
           ID-5: /dev/sdd vendor: SanDisk model: Ultra II 500GB size: 465.76 GiB
Partition: ID-1: / size: 48.96 GiB used: 35.88 GiB (73.3%) fs: ext4 dev: /dev/nvme0n1p3
Swap:      ID-1: swap-1 type: partition size: 32 GiB used: 0 KiB (0.0%) dev: /dev/sdb2
Sensors:   System Temperatures: cpu: 48.1 C mobo: N/A gpu: amdgpu temp: 31.0 C
           Fan Speeds (RPM): N/A gpu: amdgpu fan: 1530
Info:      Processes: 311 Uptime: 8m Init: systemd Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: 1139 Shell: Bash v: 5.1.4
           inxi: 3.3.00
then arch-ish just to keep the continuity
sudo inxi -Fxzmc0
System:    Kernel: 5.11.6-lqx1-1-lqx x86_64 bits: 64 compiler: gcc v: 10.2.1 Desktop: MATE 1.24.1 Distro: Arch-ish Linux
           base: Arch Linux
           Mobo: Gigabyte model: B550I AORUS PRO AX serial: N/A BIOS: American Megatrends v: F10 date: 09/18/2020
           status: Discharging
Memory:    RAM: total: 15.64 GiB used: 1.98 GiB (12.7%)
           Array-1: capacity: 128 GiB slots: 4 EC: None max module size: 32 GiB note: est.
           Device-1: DIMM 0 size: No Module Installed
           Device-2: DIMM 1 size: 8 GiB speed: 3000 MT/s type: DDR4
           Device-3: DIMM 0 size: No Module Installed
           Device-4: DIMM 1 size: 8 GiB speed: 3000 MT/s type: DDR4
           L2 cache: 2 MiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 57489
           Speed: 1416 MHz min/max: 1600/3600 MHz boost: enabled Core speeds (MHz): 1: 1416 2: 2534 3: 2736 4: 1734 5: 1361
           6: 1377 7: 2902 8: 1362
           direct render: Yes
           bus ID: 01:00.1
           bus ID: 08:00.6
Network:   Device-1: Realtek RTL8125 2.5GbE vendor: Gigabyte driver: r8169 v: kernel port: e000 bus ID: 06:00.0
           IF: eth0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Bluetooth: Device-1: Intel type: USB driver: btusb v: 0.8 bus ID: 1-8:4
Drives:    Local Storage: total: 931.51 GiB used: 183.61 GiB (19.7%)
           ID-1: /dev/nvme0n1 vendor: Sabrent model: Rocket Q size: 931.51 GiB temp: 28.9 C
Partition: ID-1: / size: 48.97 GiB used: 20.94 GiB (42.8%) fs: ext4 dev: /dev/nvme0n1p6
Swap:      Alert: No Swap data was found.
Sensors:   System Temperatures: cpu: 38.9 C mobo: N/A gpu: amdgpu temp: 27.0 C
           Fan Speeds (RPM): N/A gpu: amdgpu fan: 1511
Info:      Processes: 315 Uptime: 3m Init: N/A rc: OpenRC v: 0.42.1 runlevel: default Compilers: gcc: 10.2.0 clang: 11.1.0
           Packages: 912 Shell: Bash v: 5.1.4 inxi: 3.3.01
looks like i have enough clearance and wont need the water cooler.
:smile:
My power supply is about a half inch to deep for this case. Forcing the ssd mount in scratched the sticker on the power supply so I doubt I could return it now. Of course I don’t really need all these ssd and hdd. On physical hdd for backups would be sufficient because this motherboard has 2 nvme slots. One up top under a heat shield and one underneath next to the very heavy backplate.
The fit is really tight and there is literally nowhere to hide cables.
Well the good thing is it supports a lot of newer 5000 series! :wink:
yah! funy that. it’s almost as if someone was future-proofing their computer? ahahahahaha!
on endeavour though the 2.5 gigabit ethernet seems not to work. wifi ax works great…
I think there is a special module for that but, not sure you tried it? This is for Realtek . Is that what you have?
Edit: Looks like it!
yay -S r8125-dkms
Awesomesauce!
The question is …does it work?
will let you know shortly…
while i have you here is there a bios setting for virtualizantion? amd-v? i’m struggling to find it on the web… it’s under cbs or csb or something like that?
On my Aorus MB it was under “Tweaker”–>“Advanced CPU Settings”–>“SVM Mode”
Should be a setting for virtualization. It is SVM mode and default is disabled.
Found it! SVM mode was there i just was looking the wrong place!
ALSO! Wired conection 1 is now online! WOOT WOOT WOOT! TY TY TY TY TY TY! <3
Most excellent! :smile:
yes you are!
now the question is do i cancel the order for the ryzen 5 3600 and stick with my apu until i can afford a 5600 cpu? the 5600 cpu has an overall rated perfomace improvement of 70% while the 3600 is about 30% but it also costs 160$ more and really wants 3700 memory not the 3200 i have ordered. for the moment i am well pleased with my little beast…
Here the Ryzen 5 3600 is $249.00 Cdn and the 3600X is $329.99 Cdn (some available)
The Ryzen 5 5600X is 439.00 Cdn No Stock
Edit: Some are available at $$$ (gouging)
yah… the 3600 is 200$ us and the 5600 is 360$ us i literally ordered the 3600 and 2 32gb 3200 ddr4 memory chips for the price of the 5600 cpu.
Also, i canceled the water cooler. the thing said this case supported a sigle fan all in one water cooler but after all the time i spent putting this together i can assure everyone there is no room for a watercooler anywhere inside this machine. maybe if i mount it to the mesh front someway? but then i’m blowing hot air out the front… a 700watt psu seems like a lot (and it’s a very tight fit) but when gpu prices drop one day i’ll upgrade…
I guess it depends on the cooler. They do make some that mount in the front that are rad like with fans.
Also i booted into windows and used the bios update tool and my system actually updated the bios. took forever. would have been so much easier to go into bios but i wanted to see if gigabyte really does it and they do…
