Hi, everyone. I’m new to the bspwm edition of endeavourOS, and i seem to have this issue where my Fn+F1/2/3/… combination keys aren’t registering. After running xev, i found out that my Fn key is not registering. With my limited knowledge, I don’t know if an Fn key should have a keycode or not, but it does not register anything when i just press the Fn code.
I have seen solutions for other editions of EOS (such as i3, xfce, plasma), but have yet to find a similar one to mine which uses a BSPWM edition.
My laptop is Asus Vivobook Slate 13 OLED, and i set up my EOS to use the generic 105 key layout
Fn keys are hardwired in the bios and not detectable, though you may have luck trying the names of the functions of the keys. I don’t have bspwm installed any more, but in sway:
bindsym XF86MonBrightnessUp exec brightnessctl -c backlight set +5%
bindsym XF86MonBrightnessDown exec brightnessctl -c backlight set 5%-
xmodmap -pke
shows all the keycodes
So as an example xmodmap -pke | grep F2
shows the code of F2
You can write either F2 or XF86Switch_VT_2 into ~/.config/sxhkd/sxhkdrc super + Esc activates the changes
(This Fn thing can be set in BIOS whether F2 or XF86AudioLowerVolume is the default. IMHO)
Edit:
xev | sed -n 's/[ ]*state.* \([^ ]*\)).*/\1/p'
Shows in human friendly form the ‘names’ of the pressed keys
