ethtool shows me here that Flowcontrol is activated
ethtool --show-pause enp10s0 Pause parameters for enp10s0: Autonegotiate: on RX: on TX: on RX negotiated: off TX negotiated: off
but in the log I see that it is off
tg3 0000:0a:00.0 enp10s0: Flow control is off for TX and off for RX
Is this a bug?
Is it possible that is telling you that you have enabled flow control, but it is not actually enabled because the negotiation failed?
So I haven’t changed anything, it’s all standard. I discovered this when I looked at the firewall logs. But now I’m not sure if the flow control is working or not
