Flatpak not updating. Curl-8.10.1 may be cause
When trying to update all my flatpak apps, I get this error:
Updating 1/7…**
OSTree:ERROR:src/libostree/ostree-fetcher-curl.c:534:sock_cb: code should not be reached
Bail out! OSTree:ERROR:src/libostree/ostree-fetcher-curl.c:534:sock_cb: code should not be reached
Aborted (core dumped)
After some searching I found this:
https://bugs.gentoo.org/939813
According to the Gentoo forum, flatpak has an issue with curl-8.10.1. Guess which version of curl came with the EOS update I just ran? 8.10.1.
Question: How can I fix this? Should I just wait for another update, revert to an older version of curl, or … Is there a more correct place to post bugs for the EOS devs to see?
The ostree package was just updated 20 minutes ago to fix this issue.
hi,
the man page says 8.10.0.
Regards
Johny
Thanks. Amazing how fast this fix came!
Yes, the rebuild of the ostree package is a quick-fix workaround, as noted in the commit.
