[FIXED] Extremely low network speeds over Ethernet
For me EndeavourOS wasn’t the Problem it was my Powerline Adapters that had issues.
Hey everyone, I recently installed Endeavour and my Ethernet connection is painfully slow.
I have Dualboot with Windows set up and there it works as intendet.
I have tried changing drivers but that didn’t help.
This is some of the info that I think might be relevant:
 $ inxi -Fxxxa --no-host        Sa 09 Dez 2023 18:17:05 CET
  Kernel: 6.6.4-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    clocksource: tsc available: hpet,acpi_pm
    parameters: BOOT_IMAGE=/boot/vmlinuz-linux
    root=UUID=95f207d3-b4ef-49c6-9f7a-246d501b2f92 rw nowatchdog
    nvme_load=YES loglevel=3 r8168.aspm=0
  Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 7 dm:
    1: LightDM v: 1.32.0 2: SDDM note: stopped Distro: EndeavourOS
    base: Arch Linux
  Mobo: ASUSTeK model: PRIME B550-PLUS v: Rev X.0x
    serial: <superuser required> BIOS: American Megatrends v: 2403
    date: 06/15/2021
  Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
    level: v3 note: check built: 2022 process: TSMC n6 (7nm) family: 0x19 (25)
    model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
    L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
    L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 2620 high: 3593 min/max: 2200/4850 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3593 2: 2200
    3: 2200 4: 2874 5: 2200 6: 2200 7: 2874 8: 2874 9: 3445 10: 2200 11: 3593
    12: 2200 13: 2200 14: 2873 15: 2200 16: 2200 bogomips: 121408
  Vulnerabilities:
  Type: gather_data_sampling status: Not affected
  Type: spec_rstack_overflow status: Vulnerable: Safe RET, no microcode
    prctl
    sanitization
    STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: AMD Navi 22 [Radeon RX 6700/6700 XT/6750 XT / 6800M/6850M XT]
    vendor: Sapphire driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
    process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s
    lanes: 16 ports: active: DP-2,HDMI-A-1 empty: DP-1,DP-3 bus-ID: 08:00.0
    chip-ID: 1002:73df class-ID: 0300
  Display: x11 server: X.Org v: 21.1.9 compositor: kwin_x11 driver: X:
    loaded: amdgpu unloaded: modesetting,radeon alternate: fbdev,vesa
    dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
  Screen-1: 0 s-res: 5760x2160 s-dpi: 96 s-size: 1524x571mm (60.00x22.48")
    s-diag: 1627mm (64.07")
  Monitor-1: DP-2 mapped: DisplayPort-1 pos: primary,left model: ASUS VP28U
    serial: 105569 built: 2019 res: 3840x2160 hz: 60 dpi: 157 gamma: 1.2
    size: 621x341mm (24.45x13.43") diag: 708mm (27.9") ratio: 16:9 modes:
    max: 3840x2160 min: 640x350
  Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: right model: EIZO NANAO EV2455
    serial: 26982077 built: 2017 res: 1920x1200 hz: 60 dpi: 94 gamma: 1.2
    size: 519x324mm (20.43x12.76") diag: 616mm (24.2") ratio: 16:10 modes:
    max: 1920x1200 min: 720x400
  API: EGL v: 1.5 hw: drv: amd radeonsi platforms: device: 0 drv: radeonsi
    device: 1 drv: swrast surfaceless: drv: radeonsi x11: drv: radeonsi
    inactive: gbm,wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.2.1-arch1.2
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6700 XT (navi22 LLVM
    16.0.6 DRM 3.54 6.6.4-arch1-1) device-ID: 1002:73df memory: 11.72 GiB
    unified: no
  Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel pcie:
    gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 08:00.1 chip-ID: 1002:ab28
    class-ID: 0403
  Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16
    bus-ID: 0a:00.4 chip-ID: 1022:1487 class-ID: 0403
  API: ALSA v: k6.6.4-arch1-1 status: kernel-api
  Server-1: PipeWire v: 1.0.0 status: active with: 1: pipewire-pulse
    vendor: ASUSTeK PRIME B450M-A driver: r8168 v: 8.052.01-NAPI modules: r8169
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 05:00.0
    chip-ID: 10ec:8168 class-ID: 0200
  IF: enp5s0 state: up speed: 100 Mbps duplex: full mac: 04:42:1a:22:cb:c9
  Device-2: Microsoft Xbox 360 Wireless Adapter driver: xpad type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-1:2 chip-ID: 045e:0719
    class-ID: ff00 serial: E1541D30
  Local Storage: total: 2.84 TiB used: 27.44 GiB (0.9%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB
    size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: S3Z9NB0K204247R fw-rev: 1B6Q scheme: MBR
  ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: SV300S37A120G
    size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: 50026B785A01E0EB fw-rev: BBF0 scheme: MBR
  ID-3: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST2000DM008-2FR102
    size: 1.82 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: HDD rpm: 7200 serial: ZFL3WETC fw-rev: 0001 scheme: MBR
  ID-1: / raw-size: 195.39 GiB size: 191.27 GiB (97.89%)
    used: 27.44 GiB (14.3%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
  System Temperatures: cpu: 47.8 C mobo: N/A gpu: amdgpu temp: 51.0 C
    mem: 54.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 0
  Processes: 350 Uptime: 13m wakeups: 0 Memory: total: 16 GiB
  available: 15.5 GiB used: 3.84 GiB (24.8%) Init: systemd v: 255
  default: graphical tool: systemctl Compilers: gcc: 13.2.1 Packages:
  pm: pacman pkgs: 1046 libs: 238 tools: paru,yay Shell: fish v: 3.6.2
  running-in: konsole inxi: 3.3.31
My Ethernet controller:
  ~  lspci -vnn | grep -A8 Ethernet        1184ms  Sa 09 Dez 2023 18:19:34 CET
libkmod: kmod_config_parse: /etc/modprobe.d/r8168.conf line 1: ignoring bad line starting with 'option'
05:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 15)
        Subsystem: ASUSTeK Computer Inc. PRIME B450M-A Motherboard [1043:8677]
        Flags: bus master, fast devsel, latency 0, IRQ 35, IOMMU group 13
        I/O ports at f000 [size=256]
        Memory at fce04000 (64-bit, non-prefetchable) [size=4K]
        Memory at fce00000 (64-bit, non-prefetchable) [size=16K]
        Capabilities: <access denied>
        Kernel driver in use: r8168
        Kernel modules: r8169, r8168
And my bootlog
Dez 09 18:05:50 floriangk-desktop kernel: Linux version 6.6.4-arch1-1 (linux@archlinux) (gcc (GCC) 13.2.1 20230801, GNU ld (GNU Binutils) 2.41.0) #1 SMP PREEMPT_DYNAMIC Mon, 04 Dec 2023 00:29:19 +0000
Dez 09 18:05:50 floriangk-desktop kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-linux root=UUID=95f207d3-b4ef-49c6-9f7a-246d501b2f92 rw nowatchdog nvme_load=YES loglevel=3 r8168.aspm=0
Dez 09 18:05:50 floriangk-desktop kernel: BIOS-provided physical RAM map:
Dez 09 18:05:50 floriangk-desktop kernel: BIOS-e820: [mem 0x0000000000000000-0x000000000009d3ff] usable
Dez 09 18:05:50 floriangk-desktop kernel: BIOS-e820: [mem 0x000000000009d400-0x000000000009ffff] reserved
Dez 09 18:05:50 floriangk-desktop kernel: BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved
Dez 09 18:05:50 floriangk-desktop kernel: BIOS-e820: [mem 0x0000000000100000-0x0000000009d1efff] usable
Dez 09 18:05:50 floriangk-desktop kernel: BIOS-e820: [mem 0x0000000009d1f000-0x0000000009ffffff] reserved
Dez 09 18:05:50 floriangk-desktop kernel: BIOS-e820: [mem 0x000000000a000000-0x000000000a1fffff] usable
Dez 09 18:05:50 floriangk-desktop kernel: BIOS-e820: [mem 0x000000000a200000-0x000000000a20dfff] ACPI NVS
Dez 09 18:05:50 floriangk-desktop kernel: BIOS-e820: [mem 0x000000000a20e000-0x000000000affffff] usable
Dez 09 18:05:50 floriangk-desktop kernel: BIOS-e820: [mem 0x000000000b000000-0x000000000b01ffff] reserved
Dez 09 18:05:50 floriangk-desktop kernel: BIOS-e820: [mem 0x000000000b020000-0x00000000c4cd8fff] usable
Dez 09 18:05:50 floriangk-desktop kernel: BIOS-e820: [mem 0x00000000c4cd9000-0x00000000c4cd9fff] reserved
Dez 09 18:05:50 floriangk-desktop kernel: BIOS-e820: [mem 0x00000000c4cda000-0x00000000c8452fff] usable
Dez 09 18:05:50 floriangk-desktop kernel: BIOS-e820: [mem 0x00000000c8453000-0x00000000c87abfff] reserved
Dez 09 18:05:50 floriangk-desktop kernel: BIOS-e820: [mem 0x00000000c87ac000-0x00000000c8a12fff] ACPI data
Dez 09 18:05:50 floriangk-desktop kernel: BIOS-e820: [mem 0x00000000c8a13000-0x00000000ca13efff] ACPI NVS
Dez 09 18:05:50 floriangk-desktop kernel: BIOS-e820: [mem 0x00000000ca13f000-0x00000000cbbfefff] reserved
Dez 09 18:05:50 floriangk-desktop kernel: BIOS-e820: [mem 0x00000000cbbff000-0x00000000ccffffff] usable
Dez 09 18:05:50 floriangk-desktop kernel: BIOS-e820: [mem 0x00000000cd000000-0x00000000cfffffff] reserved
Dez 09 18:05:50 floriangk-desktop kernel: BIOS-e820: [mem 0x00000000f0000000-0x00000000f7ffffff] reserved
Dez 09 18:05:50 floriangk-desktop kernel: BIOS-e820: [mem 0x00000000fd200000-0x00000000fd2fffff] reserved
Dez 09 18:05:50 floriangk-desktop kernel: BIOS-e820: [mem 0x00000000fd600000-0x00000000fd7fffff] reserved
Dez 09 18:05:50 floriangk-desktop kernel: BIOS-e820: [mem 0x00000000fea00000-0x00000000fea0ffff] reserved
Dez 09 18:05:50 floriangk-desktop kernel: BIOS-e820: [mem 0x00000000feb80000-0x00000000fec01fff] reserved
Dez 09 18:05:50 floriangk-desktop kernel: BIOS-e820: [mem 0x00000000fec10000-0x00000000fec10fff] reserved
Dez 09 18:05:50 floriangk-desktop kernel: BIOS-e820: [mem 0x00000000fec30000-0x00000000fec30fff] reserved
Dez 09 18:05:50 floriangk-desktop kernel: BIOS-e820: [mem 0x00000000fed00000-0x00000000fed00fff] reserved
Dez 09 18:05:50 floriangk-desktop kernel: BIOS-e820: [mem 0x00000000fed40000-0x00000000fed44fff] reserved
Dez 09 18:05:50 floriangk-desktop kernel: BIOS-e820: [mem 0x00000000fed80000-0x00000000fed8ffff] reserved
Dez 09 18:05:50 floriangk-desktop kernel: BIOS-e820: [mem 0x00000000fedc2000-0x00000000fedcffff] reserved
Dez 09 18:05:50 floriangk-desktop kernel: BIOS-e820: [mem 0x00000000fedd4000-0x00000000fedd5fff] reserved
Dez 09 18:05:50 floriangk-desktop kernel: BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
Dez 09 18:05:50 floriangk-desktop kernel: BIOS-e820: [mem 0x0000000100000000-0x000000042f37ffff] usable
Dez 09 18:05:50 floriangk-desktop kernel: BIOS-e820: [mem 0x000000042f380000-0x000000042fffffff] reserved
Dez 09 18:05:50 floriangk-desktop kernel: NX (Execute Disable) protection: active
Dez 09 18:05:50 floriangk-desktop kernel: APIC: Static calls initialized
Dez 09 18:05:50 floriangk-desktop kernel: SMBIOS 3.3.0 present.
Dez 09 18:05:50 floriangk-desktop kernel: DMI: ASUS System Product Name/PRIME B550-PLUS, BIOS 2403 06/15/2021
Dez 09 18:05:50 floriangk-desktop kernel: tsc: Fast TSC calibration using PIT
Dez 09 18:05:50 floriangk-desktop kernel: tsc: Detected 3792.974 MHz processor
Dez 09 18:05:50 floriangk-desktop kernel: e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
Dez 09 18:05:50 floriangk-desktop kernel: e820: remove [mem 0x000a0000-0x000fffff] usable
Dez 09 18:05:50 floriangk-desktop kernel: last_pfn = 0x42f380 max_arch_pfn = 0x400000000
Dez 09 18:05:50 floriangk-desktop kernel: total RAM covered: 3327M
Dez 09 18:05:50 floriangk-desktop kernel: Found optimal setting for mtrr clean up
Dez 09 18:05:50 floriangk-desktop kernel:  gran_size: 64K         chunk_size: 128M         num_reg: 4          lose cover RAM: 0G
Dez 09 18:05:50 floriangk-desktop kernel: MTRR map: 7 entries (3 fixed + 4 variable; max 20), built from 9 variable MTRRs
Dez 09 18:05:50 floriangk-desktop kernel: x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
Dez 09 18:05:50 floriangk-desktop kernel: e820: update [mem 0xc9bc0000-0xc9bcffff] usable ==> reserved
Dez 09 18:05:50 floriangk-desktop kernel: e820: update [mem 0xd0000000-0xffffffff] usable ==> reserved
Dez 09 18:05:50 floriangk-desktop kernel: last_pfn = 0xcd000 max_arch_pfn = 0x400000000
Dez 09 18:05:50 floriangk-desktop kernel: Using GB pages for direct mapping
Dez 09 18:05:50 floriangk-desktop kernel: RAMDISK: [mem 0x361c7000-0x370dafff]
Dez 09 18:05:50 floriangk-desktop kernel: ACPI: Early table checksum verification disabled
Dez 09 18:05:50 floriangk-desktop kernel: ACPI: RSDP 0x00000000000F05B0 000024 (v02 ALASKA)
Dez 09 18:05:50 floriangk-desktop kernel: ACPI: XSDT 0x00000000C8A11728 0000D4 (v01 ALASKA A M I    01072009 AMI  01000013)
Dez 09 18:05:50 floriangk-desktop kernel: ACPI: FACP 0x00000000C8A02000 000114 (v06 ALASKA A M I    01072009 AMI  00010013)
Dez 09 18:05:50 floriangk-desktop kernel: ACPI: DSDT 0x00000000C89F6000 00B99A (v02 ALASKA A M I    01072009 INTL 20120913)
Dez 09 18:05:50 floriangk-desktop kernel: ACPI: FACS 0x00000000CA124000 000040
Dez 09 18:05:50 floriangk-desktop kernel: ACPI: SSDT 0x00000000C8A08000 008C98 (v02 AMD    AmdTable 00000002 MSFT 04000000)
Dez 09 18:05:50 floriangk-desktop kernel: ACPI: SSDT 0x00000000C8A04000 003B1B (v01 AMD    AMD AOD  00000001 INTL 20120913)
Dez 09 18:05:50 floriangk-desktop kernel: ACPI: SSDT 0x00000000C8A03000 000221 (v02 ALASKA CPUSSDT  01072009 AMI  01072009)
Dez 09 18:05:50 floriangk-desktop kernel: ACPI: FIDT 0x00000000C89F5000 00009C (v01 ALASKA A M I    01072009 AMI  00010013)
Dez 09 18:05:50 floriangk-desktop kernel: ACPI: FPDT 0x00000000C8901000 000044 (v01 ALASKA A M I    01072009 AMI  01000013)
Dez 09 18:05:50 floriangk-desktop kernel: ACPI: MCFG 0x00000000C89F3000 00003C (v01 ALASKA A M I    01072009 MSFT 00010013)
Dez 09 18:05:50 floriangk-desktop kernel: ACPI: HPET 0x00000000C89F2000 000038 (v01 ALASKA A M I    01072009 AMI  00000005)
Dez 09 18:05:50 floriangk-desktop kernel: ACPI: IVRS 0x00000000C89F0000 0000D0 (v02 AMD    AmdTable 00000001 AMD  00000001)
Dez 09 18:05:50 floriangk-desktop kernel: ACPI: WPBT 0x00000000C8915000 00003C (v01 ALASKA A M I    00000001 ASUS 00000001)
Dez 09 18:05:50 floriangk-desktop kernel: ACPI: PCCT 0x00000000C8914000 00006E (v02 AMD    AmdTable 00000001 AMD  00000001)
Dez 09 18:05:50 floriangk-desktop kernel: ACPI: SSDT 0x00000000C8910000 003FB9 (v02 AMD    AmdTable 00000001 AMD  00000001)
Dez 09 18:05:50 floriangk-desktop kernel: ACPI: CRAT 0x00000000C890F000 000E98 (v01 AMD    AmdTable 00000001 AMD  00000001)
Dez 09 18:05:50 floriangk-desktop kernel: ACPI: CDIT 0x00000000C890E000 000029 (v01 AMD    AmdTable 00000001 AMD  00000001)
Dez 09 18:05:50 floriangk-desktop kernel: ACPI: SSDT 0x00000000C890D000 000293 (v01 AMD    ArticDGP 00000001 INTL 20120913)
Dez 09 18:05:50 floriangk-desktop kernel: ACPI: SSDT 0x00000000C890B000 0010B4 (v01 AMD    ArticTPX 00000001 INTL 20120913)
Dez 09 18:05:50 floriangk-desktop kernel: ACPI: SSDT 0x00000000C890A000 00052C (v01 AMD    ArticNOI 00000001 INTL 20120913)
Dez 09 18:05:50 floriangk-desktop kernel: ACPI: SSDT 0x00000000C8906000 003EB3 (v01 AMD    ArticN   00000001 INTL 20120913)
Dez 09 18:05:50 floriangk-desktop kernel: ACPI: WSMT 0x00000000C8905000 000028 (v01 ALASKA A M I    01072009 AMI  00010013)
Dez 09 18:05:50 floriangk-desktop kernel: ACPI: APIC 0x00000000C8904000 00015E (v03 ALASKA A M I    01072009 AMI  00010013)
Dez 09 18:05:50 floriangk-desktop kernel: ACPI: SSDT 0x00000000C8903000 00007D (v01 AMD    ArticDIS 00000001 INTL 20120913)
Dez 09 18:05:50 floriangk-desktop kernel: ACPI: SSDT 0x00000000C8902000 0000BF (v01 AMD    AmdTable 00001000 INTL 20120913)
Dez 09 18:05:50 floriangk-desktop kernel: ACPI: Reserving FACP table memory at [mem 0xc8a02000-0xc8a02113]
Dez 09 18:05:50 floriangk-desktop kernel: ACPI: Reserving DSDT table memory at [mem 0xc89f6000-0xc8a01999]
Dez 09 18:05:50 floriangk-desktop kernel: ACPI: Reserving FACS table memory at [mem 0xca124000-0xca12403f]
Dez 09 18:05:50 floriangk-desktop kernel: ACPI: Reserving SSDT table memory at [mem 0xc8a08000-0xc8a10c97]
Dez 09 18:05:50 floriangk-desktop kernel: ACPI: Reserving SSDT table memory at [mem 0xc8a04000-0xc8a07b1a]
Dez 09 18:05:50 floriangk-desktop kernel: ACPI: Reserving SSDT table memory at [mem 0xc8a03000-0xc8a03220]
Dez 09 18:05:50 floriangk-desktop kernel: ACPI: Reserving FIDT table memory at [mem 0xc89f5000-0xc89f509b]
Dez 09 18:05:50 floriangk-desktop kernel: ACPI: Reserving FPDT table memory at [mem 0xc8901000-0xc8901043]
Dez 09 18:05:50 floriangk-desktop kernel: ACPI: Reserving MCFG table memory at [mem 0xc89f3000-0xc89f303b]
Dez 09 18:05:50 floriangk-desktop kernel: ACPI: Reserving HPET table memory at [mem 0xc89f2000-0xc89f2037]
Dez 09 18:05:50 floriangk-desktop kernel: ACPI: Reserving IVRS table memory at [mem 0xc89f0000-0xc89f00cf]
Dez 09 18:05:50 floriangk-desktop kernel: ACPI: Reserving WPBT table memory at [mem 0xc8915000-0xc891503b]
Dez 09 18:05:50 floriangk-desktop kernel: ACPI: Reserving PCCT table memory at [mem 0xc8914000-0xc891406d]
Dez 09 18:05:50 floriangk-desktop kernel: ACPI: Reserving SSDT table memory at [mem 0xc8910000-0xc8913fb8]
Dez 09 18:05:50 floriangk-desktop kernel: ACPI: Reserving CRAT table memory at [mem 0xc890f000-0xc890fe97]
Dez 09 18:05:50 floriangk-desktop kernel: ACPI: Reserving CDIT table memory at [mem 0xc890e000-0xc890e028]
Dez 09 18:05:50 floriangk-desktop kernel: ACPI: Reserving SSDT table memory at [mem 0xc890d000-0xc890d292]
Dez 09 18:05:50 floriangk-desktop kernel: ACPI: Reserving SSDT table memory at [mem 0xc890b000-0xc890c0b3]
Dez 09 18:05:50 floriangk-desktop kernel: ACPI: Reserving SSDT table memory at [mem 0xc890a000-0xc890a52b]
Dez 09 18:05:50 floriangk-desktop kernel: ACPI: Reserving SSDT table memory at [mem 0xc8906000-0xc8909eb2]
Dez 09 18:05:50 floriangk-desktop kernel: ACPI: Reserving WSMT table memory at [mem 0xc8905000-0xc8905027]
Dez 09 18:05:50 floriangk-desktop kernel: ACPI: Reserving APIC table memory at [mem 0xc8904000-0xc890415d]
Dez 09 18:05:50 floriangk-desktop kernel: ACPI: Reserving SSDT table memory at [mem 0xc8903000-0xc890307c]
Dez 09 18:05:50 floriangk-desktop kernel: ACPI: Reserving SSDT table memory at [mem 0xc8902000-0xc89020be]
Dez 09 18:05:50 floriangk-desktop kernel: No NUMA configuration found
Dez 09 18:05:50 floriangk-desktop kernel: Faking a node at [mem 0x0000000000000000-0x000000042f37ffff]
Dez 09 18:05:50 floriangk-desktop kernel: NODE_DATA(0) allocated [mem 0x42f37b000-0x42f37ffff]
Dez 09 18:05:50 floriangk-desktop kernel: Zone ranges:
Dez 09 18:05:50 floriangk-desktop kernel:   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
Dez 09 18:05:50 floriangk-desktop kernel:   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
Dez 09 18:05:50 floriangk-desktop kernel:   Normal   [mem 0x0000000100000000-0x000000042f37ffff]
Dez 09 18:05:50 floriangk-desktop kernel:   Device   empty
Dez 09 18:05:50 floriangk-desktop kernel: Movable zone start for each node
Dez 09 18:05:50 floriangk-desktop kernel: Early memory node ranges
I have the dkms version of r8168 and I set the r8168.aspm=0 flag in the boot
Thanks for reading all that, sorry if this is some extremely obvious issue I’m overlooking
go speed test first
your net could be down
Have you tried the r8169 driver?
My network isn’t down, the speed is just extremely slow, on my phone I have 35mbit/s
speedtest        39.6s  Sa 09 Dez 2023 18:24:24 CET
Retrieving speedtest.net configuration...
Retrieving speedtest.net server list...
Selecting best server based on ping...
Hosted by Studenten Net Twente (Enschede) [151.38 km]: 87.618 ms
Testing download speed................................................................................
Download: 1.32 Mbit/s
Testing upload speed......................................................................................................
Upload: 1.04 Mbit/s
I have, that had about the same speeds.
strange
Alright folks, I found the culprit.
My Powerline Adapters shat themselves.
I’m sorry for not checking them earlyer. Powerline Lan is a fickle thing.
