Picked up a new HP Laptop with Ryzen 4700u that has AMD graphics onboard. So i installed KDE and with just a swap file. Now I’m wondering if i should have gone with Hibernation and swap. The reason i ask is because laptops typically when you close the lid want to hibernate or suspend or whatever. Not being a big laptop user and the fact that a lot of laptops don’t come out of suspend or hibernation well and you either get graphic anomalies, or black screen or garbled. This happens especially with onboard graphics due to power settings i guess. So i set the close lid setting to shutdown on KDE which works fine. Everything works including the touchpad and wifi. I only had to add acpi_backlight=vendor for the backlight control.
My swapfile shows size 524284 which i think is the hard drive size? (500GB)
I just did erase disc with swap file? What does this mean then?
Tlp is installed but i haven’t touched it as it boots fine and works fine. Starts right up, reboots, shuts down.
Just wondering if i should have done something different? I suppose hibernation can be added now? Should i leave it the way it is? Add hibernation? Reinstall with a different set up?
Just asking for some feed back. This laptop is like an ultrabook. Very thin very light, 14" full HD screen. The fan does speed up a bit when you push it.
[ricklinux@eos-kde ~]$ inxi -Fxxxa --no-host
System: Kernel: 5.9.14-arch1-1 x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-linux root=UUID=df7f4bc6-98b4-4161-838c-c1b4d887eb43 rw quiet
acpi_backlight=vendor loglevel=3 nowatchdog
Desktop: KDE Plasma 5.20.4 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM Distro: EndeavourOS
Machine: Type: Laptop System: HP product: HP Laptop 14-fq0xxx v: N/A serial: <superuser required> Chassis: type: 10
Mobo: HP model: 87B8 v: 37.18 serial: <superuser required> UEFI: AMI v: F.12 date: 07/03/2020
Battery: ID-1: BAT0 charge: 40.7 Wh condition: 40.7/40.7 Wh (100%) volts: 13.1/11.6 model: Hewlett-Packard Primary
type: Li-ion serial: N/A status: Full cycles: 365
CPU: Info: 8-Core model: AMD Ryzen 7 4700U with Radeon Graphics bits: 64 type: MCP arch: Zen 2 family: 17 (23)
model-id: 60 (96) stepping: 1 microcode: 8600104 L2 cache: 4 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 31959
Speed: 1397 MHz min/max: 1400/2000 MHz boost: enabled Core speeds (MHz): 1: 1397 2: 1397 3: 1397 4: 1397 5: 1397
6: 1397 7: 1397 8: 1397
Vulnerabilities: Type: itlb_multihit status: Not affected
Type: spec_store_bypass mitigation: Speculative Store Bypass disabled via prctl and seccomp
Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user pointer sanitization
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW, STIBP: disabled, RSB filling
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Renoir vendor: Hewlett-Packard driver: amdgpu v: kernel bus ID: 03:00.0
chip ID: 1002:1636
Device-2: Chicony HP TrueVision HD Camera type: USB driver: uvcvideo bus ID: 1-3:2 chip ID: 04f2:b6f1 serial: 0001
Display: x11 server: X.org 1.20.10 compositor: kwin_x11 driver: amdgpu,ati unloaded: fbdev,modesetting,vesa
resolution: <missing: xdpyinfo>
Audio: Device-1: Advanced Micro Devices [AMD/ATI] vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus ID: 03:00.1
chip ID: 1002:1637
Device-2: Advanced Micro Devices [AMD] Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Hewlett-Packard
driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x bus ID: 03:00.5 chip ID: 1022:15e2
Device-3: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
bus ID: 03:00.6 chip ID: 1022:15e3
Sound Server: ALSA v: k5.9.14-arch1-1
Network: Device-1: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter vendor: Hewlett-Packard driver: rtw_8822ce
v: N/A modules: rtw88_8822ce port: f000 bus ID: 01:00.0 chip ID: 10ec:c822
IF: wlan0 state: up mac: 20:4e:f6:1a:40:db
Drives: Local Storage: total: 476.94 GiB used: 10.62 GiB (2.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba model: KBG40ZNV512G KIOXIA size: 476.94 GiB block size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: 80RPH7RRQ9D2 rev: HP00AE00 temp: 27.9 C
Partition: ID-1: / raw size: 476.64 GiB size: 468.16 GiB (98.22%) used: 10.62 GiB (2.3%) fs: ext4 dev: /dev/nvme0n1p2
maj-min: 259:2
ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%) used: 280 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1
maj-min: 259:1
Swap: Kernel: swappiness: 60 (default) cache pressure: 100 (default)
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2 file: /swapfile
Sensors: System Temperatures: cpu: 51.1 C mobo: N/A gpu: amdgpu temp: 41.0 C
Fan Speeds (RPM): N/A
Info: Processes: 225 Uptime: 43m wakeups: 798 Memory: 7.2 GiB used: 1.46 GiB (20.3%) Init: systemd v: 247 Compilers:
gcc: 10.2.0 Packages: pacman: 1092 lib: 261 Shell: Bash v: 5.1.4 running in: konsole inxi: 3.2.00
