First experiment with installing on BTRFS
It’s quite easy to have systemd monitor the folder and run a command on change.
I first thought about solving the problem this way but then decided against it. The above command (update grub) would be run on every change of the snapshot folder (e. g. adding, deleting snapshots) which is desired behavior BUT the grub update would then be run multiple times. For instance it would be called during a system update and then again because the folder would have changed.
The on-shutdown workaround is called only once before I actually need the grub entries (on next boot) and only adds about two to five seconds to the shutdown.
Very reasonable covering of the potential hole in the process - and better than my first simplistic thought! Too much procedural programming in my past, I suspect…
I just need you to verify if a newly created manual snapshot really shows up in the grub menu on the next reboot.
You could check this by running two simple commands …
  1. creating a manual snapshot with
    sudo timeshift --create --comments "manual"
  2. and then reboot (without running an update etc. before)
    sudo reboot -n
Does the above created snapshot really show up in the grub menu on this reboot?
Excuse my uninformed question (all this is quite new to me and very exciting): couldn’t the “monitor-folder-chnange” be scripted separately and “baked into” the same
limit-timeshift-snapshots-update-grub.service. If there is a change then the rest otherwise only shutdown?
Ran those commands and on reboot check the actual snapshots listed and I was wrong only 3 from to day were actually listed. I’m assuming 2 from updates and the 3rd which was a manual. I’m assuming the manual is only showing cause I dis a grub-update after creating that one. the other one made manually made by me today and the one I just made are not showing up. That to me is a bug. The newest snapshots should always show up on the grub snapshot menu in my book without further user intervention than creating the snapshot.
Thanks a lot - and welcome to the club … you’re probably having the same issues we noticed :cry:
I tried to mount the “subvolume” timeshift-btrfs at /.snapshots by using its subvolid. It does mount and you can browse the content. But the problem is running Timeshift again, it creates a new subvolume. See:
sudo btrfs subvolume list -p /
ID 271 gen 4601 parent 5 top level 5 path timeshift-btrfs/snapshots/2020-09-19_15-49-33/@
ID 279 gen 4857 parent 5 top level 5 path timeshift-btrfs/snapshots/2020-09-23_23-39-40/@
So the actual subvolume is not timeshift-btrfs but
etc…
So how to do the following from the instructions at Github:
  • Mount your subvolume which contains snapshots to /.snapshots
There is a missing link here…
:thinking:
If I understand correctly, you’re asking for the shutdown service only to run if actually necessary.
On shutdown we’d have to check if the snapshot folder was modified.
The problem here is that for some of the snapshots the grub already has been updated, but not for the manual created snapshots.
So how to reliably check if a grub update is really needed?
The only thing I can think of right now is actually comparing the grub entries with the snapshot folder contents. But this is a bit of a script overkill; I think I’ll stick to my workaround for the time being :wink: .
If you run
findmnt -t btrfs | grep timeshift
you’ll notice that the mountpoint is actually /run/timeshift/backup .
The snapshots are then added to
/run/timeshift/backup/timeshift-btrfs/snapshots/
as far as I can see. This is our .snapshots folder I assume.
Hello,
I am interested in your discussion.
can someone give the output of:
btrfs subvolume list -sa /
No, I am afraid it isn’t. Otherwise the grub-btrfs.service would be triggered at any modifications in .snapshots and the problem would be solved. .snapshots need to be created by the user if I have understood it correctly.
When I looked at the system partition from “outside”, I could see @, @home and timeshift-btrfs
containing the actual snapshot folders:
I understand. Thank you for sticking around this thread. I appreciate it very much.
Hi,
Good to have you here!
I had only one on-demand snapshot ( I deleted the other ones before). But I just made a new one as well, just in case. Here is:
sudo btrfs subvolume list -sa /
ID 271 gen 4601 cgen 2015 top level 5 otime 2020-09-19 15:49:33 path <FS_TREE>/timeshift-btrfs/snapshots/2020-09-19_15-49-33/@
ID 273 gen 4946 cgen 4946 top level 5 otime 2020-09-24 00:53:51 path <FS_TREE>/timeshift-btrfs/snapshots/2020-09-24_00-53-51/@
Rather than giving myself a headache reading through the recent post I’ll simply ask the following. Why can’t a script be written to run in the background that does a grub-update when a manual snapshot is taken.
For grub-btrfs.path, i wrote this:
Mount your subvolume which contains snapshots to / .snapshots
which means :
You need to create the .snapshots folder.
and you need to mount or create snapshots in it.
Why Mount your subvolume which contains snapshots ?
Because my layout of btrfs subvolume is :
@racine (my subvolume containing linux root system)
@snapshots (my subvolume containing my manuals snapshots)
etc…
Your is :
@home
etc…
Timeshift creates its working folder at the root of the btrfs system top level 5.
You can check it like this:
mount -o subvolid=5 /dev/sda1 /mnt
This will mount the root of the btrfs filesystem in /mnt.
Remember to modify /dev/sda1 if it isn’t your btrfs system partition, and /mnt if you want to mount it elsewhere.
You can see your subvolumes and timeshift working folder there.
for example:
@home
timeshift
etc…
Then timeshift mounts this folder to/run/timeshift...
I don’t use timeshift, but if you want to make grub-btrfs.path work, the easiest way would be to modify the service like this:
[Unit]
Description=Monitors for new snapshots
[Path]
PathModified=/run/timeshift/backup/timeshift-btrfs/snapshots
[Install]
WantedBy=multi-user.target
Or something close.
That’s great! I was exactly starting to think in similar vein! To skip /.snapshots altogether.
I’ll give this a try and report back!
After modification of the path in grub-btrfs.path, I made an on-demand snapshot and checked the status of the grub-btrfs.service. And here you go:
$ systemctl status  grub-btrfs.service
● grub-btrfs.service - Regenerate grub-btrfs.cfg
     Loaded: loaded (/usr/lib/systemd/system/grub-btrfs.service; static)
     Active: inactive (dead) since Thu 2020-09-24 01:42:06 CEST; 46s ago
TriggeredBy: ● grub-btrfs.path
    Process: 6530 ExecStart=/bin/bash -c if [ -s "/boot/${GRUB_BTRFS_DIRNAME:-grub}/grub-btrfs.cfg" ]; then /et>
   Main PID: 6530 (code=exited, status=0/SUCCESS)
Sep 24 01:42:06 eos-cinnamon bash[6867]: Warning: snapper detected but config 'root' does not exist
Sep 24 01:42:06 eos-cinnamon bash[6531]: Found snapshot: 2020-09-24 01:42:04 | timeshift-btrfs/snapshots/2020-0>
Sep 24 01:42:06 eos-cinnamon bash[6531]: Found snapshot: 2020-09-24 00:53:51 | timeshift-btrfs/snapshots/2020-0>
Sep 24 01:42:06 eos-cinnamon bash[6531]: Found snapshot: 2020-09-19 15:49:33 | timeshift-btrfs/snapshots/2020-0>
Sep 24 01:42:06 eos-cinnamon bash[6531]: Found 3 snapshot(s)
Sep 24 01:42:06 eos-cinnamon bash[6909]: submenu 'EndeavourOS snapshots' {
Sep 24 01:42:06 eos-cinnamon bash[6909]:         configfile "${prefix}/grub-btrfs.cfg"
Sep 24 01:42:06 eos-cinnamon bash[6909]: }
Sep 24 01:42:06 eos-cinnamon systemd[1]: grub-btrfs.service: Succeeded.
Sep 24 01:42:06 eos-cinnamon systemd[1]: Finished Regenerate grub-btrfs.cfg.
GREAT!!
:partying_face:
The whole issue was then this difference:
Thank you so much for stepping by! I wrote before that there was a missing link. You provided it!
Merci!
I recommend that you do not modify the grub-btrfs.path file, because each time the package is updated it will be overwritten.
Instead use:
systemctl edit grub-btrfs.path
Write your changes and save.
To erase your changes:
use: systemctl revert grub-btrfs.path
Right! That’s is much better! Thanks for pointing it out!
Merci encore une fois!
Your are welcome. :slight_smile:
I added a paragraph on timeshift
Hope this is understandable.
