works too and may better than xhost as it does not need xoeg-xhost to be installed.
What is the exact error when trying to use meld with root permissions?
What happens if using this:
DIFFPROG='dbus-launch meld' su -c pacdiff
The latter is working?
strange ? yes!! why i can simply run meld as root?
Looks like it!
But what happens if you do it in Welcome’s Pacdiff button?
I have the feeling that sudo is the problem. su seems to work.
without access to xhost it simply does not start from welcome, it opens the terminal ask for password but if i put V (view) it returns to question without open the gui…
Strange.
And one more question: does this work:
The meld and root problem is strange.
It all works on a traditional DE, so it could be because of some missing package that is related to xorg vs. wayland?
basicly wayland does not want do a gui in root
as Odiousimp mention is also kinda work around also like -sudo -HE i believe
can be a typo lol
but stil
xhost is also just a workaround
and gnome fixed it internally it seems
I tested it here and with xhost it can be made to work almost OK.
This means (at least here) that
meldis extremely slow and erratic but sometimes work… -
diffuseseems to work quite well with xhost.
So this really is a wayland “feature” that can be worked around with xhost temporarily.
Not the desired solution, but seems to work anyway.
So I’ll make some wayland changes to Welcome, and for pacdiff in wayland we need packages
- xorg-xhost
- diffuse
Fortunately neither is very large.
Just made new Welcome 3.11.9-1 available.
It hopefully works around Welcome’s pacdiff problem under wayland (by using xhost temporarily).
Please test it and report.
Note that it should complain if either xorg-xhost or diffuse is not installed.
Unfortunately meld is so slow (here in a VM) that it cannot really be used, that’s why diffuse was selected.
at first i was thinking yad was reverted ![]()
GNOME shows the warning in a very huge window.
Thanks! Have to make the warning smaller.
Edit: Done. Releasing to mirrors now.
