Could not find a general “Networking” section so I am going to try here.
Ok, I am having problems with my firewall setup. I have NoMachine installed on all of my computers: A server with Debian, a desktop with Endeavour, a laptop freshly installed with Endeavour, and another laptop with Garuda. Both the server and desktop connect to each other just fine and both laptops connect to the server and desktop, but there is no access into either the Endeavour or Garuda laptops. I can see them after setting up the firewall (TCP 4000 and UDP 4011-4999) but I get the error:
“The remote host ‘192.168.1.x’ refused to establish a network connection on port ‘4000’. Please verify that NoMachine is correctly installed and listening on the port where you are trying to connect, and that incoming traffic is not being blocked by a firewall or NAT.”
The desktop has an older install of Endeavour and so did the laptop, but I did a new install with the current ISO and now it does not work. I don’t know enough about firewalld to troubleshoot it.
That link looks to be related to port forwarding. All these computers are on the same network and when I do connect to them remotely I use Tailscale so port forwarding and NAT do not apply in this case.
Also, the issues above are replicated when routing though Tailscale.
Any ideas? It is like there is another firewall blocking it.
Here is what I get on the Desktop:
jeremiah LR-Desktop ~ sudo firewall-cmd --list-all
[sudo] password for jeremiah:
home (active)
target: default
icmp-block-inversion: no
interfaces: eno1
sources:
services: dhcp dhcpv6-client dns ftp kdeconnect mdns samba samba-client samba-dc ssh transmission-client vnc-server wireguard
ports: 8622/tcp 4000/tcp 4011-4999/udp
protocols: icmp ipv6-icmp
forward: yes
masquerade: no
forward-ports:
source-ports:
icmp-blocks:
rich rules:
jeremiah LR-Desktop ~ nmap -p 4000 localhost
Starting Nmap 7.93 ( https://nmap.org ) at 2022-12-29 23:38 CST
Nmap scan report for localhost (127.0.0.1)
Host is up (0.000096s latency).
Other addresses for localhost (not scanned): ::1
PORT STATE SERVICE
4000/tcp open remoteanything
Nmap done: 1 IP address (1 host up) scanned in 0.98 seconds
Here is the laptop:
jeremiah JLaptop-Endeavour ~ sudo firewall-cmd --list-all
trusted (active)
target: ACCEPT
interfaces: wlan0
sources:
services: kdeconnect samba samba-client wireguard ws-discovery
protocols:
forward: yes
masquerade: no
forward-ports:
source-ports:
icmp-blocks:
rich rules:
jeremiah JLaptop-Endeavour ~ nmap -p 4000 localhost
Starting Nmap 7.93 ( https://nmap.org ) at 2022-12-29 23:40 CST
Host is up (0.00024s latency).
PORT STATE SERVICE
4000/tcp closed remoteanything
Nmap done: 1 IP address (1 host up) scanned in 0.09 seconds
I am stuck at this point. I really need to redo my desktop since I have a faulty drive but I cannot do this until I can fix this issue since I use NoMachine almost daily on the desktop.
Sorry for necrobumping, however this is the first result on google if searching for “endeavour os firewalld issues” so I believe this will also be helpful for other people. You have to allow both TCP and UDP connections on port 4000 for nomachine. If you want to permenently allow TCP and UDP on port 4000, you will have to run the following commands as root:
