Firefox WeGL issue
Hi all, since about 1 week ago (probably the update to 75.0.1) I’m getting messages like “This app requires a WebGL-enabled browser to run” in Firefox.
I’ve checked about:config and I see
webgl.disabled is False
webgl.enable-webgl2 is True
same site works fine in Chromium.
any ideas on how to solve this?
Hello @Amsterdam4572
Install: mesa-demos
Run: glxinfo | grep OpenGL
See what that gives you after.
OpenGL vendor string: Intel
OpenGL renderer string: Mesa Intel® UHD Graphics 630 (CFL GT2)
OpenGL core profile version string: 4.6 (Core Profile) Mesa 20.0.4
OpenGL core profile shading language version string: 4.60
OpenGL core profile context flags: (none)
OpenGL core profile profile mask: core profile
OpenGL core profile extensions:
OpenGL version string: 4.6 (Compatibility Profile) Mesa 20.0.4
OpenGL shading language version string: 4.60
OpenGL context flags: (none)
OpenGL profile mask: compatibility profile
OpenGL extensions:
OpenGL ES profile version string: OpenGL ES 3.2 Mesa 20.0.4
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20
OpenGL ES profile extensions:
Now you try the site and see?
no, still same problem. Even made a new Firefox directory on my home drive
ah ha solved it with help from https://www.reddit.com/r/firefox/comments/fxltkx/webgl_not_working_in_ff_75_in_linux/
security.sandbox.content.level set to 2, not 4 allows WebGL to work again.
Good find…guess you got stuck in the sand box! :laughing:
well looks like a bug that I’ve hit that somebody is now fixing
