Hey friends,
so I just updated my system and noticed some videos not playing on for example Reddit (AVC decoder). ffmpeg was updated to version 5.0 and at the same time ffmpeg4.4 got added to the official repos.
After also installing the ffmpeg4.4 package, everything works fine again. Does anybody know what the deal is with those two packages?
Hm, strange, I hav eonly 5.0-3…
I’ll install 4.4.1-3
$ LANG=C sudo pacman -Ss ffmpeg
extra/ffmpeg 2:5.0-3 [installed]
Complete solution to record, convert and stream audio and video
extra/ffmpeg4.4 4.4.1-3
Maybe your mirror is not up-to-date yet as I0F mentioned in the post above…
I have both versions installed now… In the future, once firefox is ready to handle 5.0, I’ll remove 4.4
This happened to me when I tried to downgrade 5.0 to 4.4
But as mentioned above, both can coexist, so I cancelled the downgrade process and just installed 4.4 along with 5.0 which was already installed…
Everything just worked
So now after updating i have this and video still plays.
[ricklinux@eos-kde ~]$ sudo pacman -Ss fmpeg
[sudo] password for ricklinux:
extra/ffmpeg4.4 4.4.1-3 [installed]
extra/ffmpegthumbnailer 2.2.2-3 [installed]
Lightweight video thumbnailer that can be used by file managers.
extra/ffmpegthumbs 21.12.2-2 (kde-applications kde-multimedia)
FFmpeg-based thumbnail creator for video files
extra/ffnvcodec-headers 11.1.5.1-1
FFmpeg version of headers required to interface with Nvidias codec APIs
extra/gst-libav 1.20.0-2 [installed]
Multimedia graph framework - libav plugin
extra/qtav 1.13.0-3
A cross-platform multimedia playback framework based on Qt and FFmpeg
community/ffmpeg2theora 0.30-7
Simple converter to create Ogg Theora files
community/ffms2 2.40-2
A libav/ffmpeg based source library and Avisynth plugin for easy frame accurate access
community/ffnvcodec-headers8.1 8.1.24.11-1
community/kmplayer 0.12.0.b-4
Video player plugin for Konqueror and basic MPlayer/Xine/ffmpeg/ffserver/VDR frontend for KDE
community/opera-ffmpeg-codecs 97.0.4692.99-1
additional support for proprietary codecs for opera
community/vivaldi-ffmpeg-codecs 98.0.4710.4-2
additional support for proprietary codecs for vivaldi
