How to beautify the xfce4 system? Not elegant enough, the vscode font is not good-looking, and how to set the shortcut keys, for example, what should I do if I want to set the win key to open the start menu (similar to windows 10)?
The default is xfce4 after installation. If I want to install and switch to Deepin or KDE desktop, but I don’t want to delete xfce4 (keep it as a backup desktop, so I can switch back later), what should I do?
How to use NVIDIA’s closed source driver?
How can the remote desktop connection of endeavoros use RDP to facilitate the connection to the remote windows desktop? Currently I installed the Reminna remote tool, but I did not find support for the RDP protocol.
—For this question, could u pls give some advice or direction? xfce is lack of self customization and the theme provided can’t match my requirement.
—I have already read the link you provide, but I still get confused:
i.Should I install one DDE and uninstall another one meanwhile? and they can’t be conexist?
ii. Should I need to do some configuration about x11 or xinit config files about the new DDE?
My default DDE is xfce4, and I just installed deepin DDE without uninstall xfce4 dde,
and after my reboot, it’s still stay on xfce4 dde.
How can endeavoros support 32-bit? (i386)
—I need to install the vpn namd univpn and use which to login my remote desktop in my company, follow is the download site:
univpn-linux-64-10781.7.0.1025.zip https://cloud.leagsoft.com/download/UniVPN/linux/univpn-linux-64-10781.7.0.1025.zip
But I can’t install this tool, hint is not support 32 bit system.
Could u pls help to have a look?
Could u pls provide your telegram, we can have a instance cotact.(@petercao01)
sudo pacman -Syu <package> updates the system and installs <package>
NEVER use sudo pacman -Sy <package> This is a partial upgrade, which isn’t supported. It installs <package> with a newer database from the Arch repos but DOESN’T upgrade the rest.
sudo pacman -S <package> installs <package> according to your local database which is probably out of date, so the package will be too.
EndeavourOS Xfce is already beautiful and elegant and is the flagship here. Deepin is not one of the Desktops included as there are too many issues with it on Arch. You want nvidia drivers then you install them. You want remote desktop you need to install the packages and needed dependencies. 32 bit is out.
Hi guys,
I just reinstall to the eos kde system, and it looked so much fun,
But I still got some problem:
1.the kde startup command line will stuck in lines like :host name xxx for several seconds, which is too much long time, I hope it’s 10s for startup to my kde window.
2.Some times, my kde desktop will be stuck, even no action was triggered, so in this case, I have to reboot the machine, and it wil be recovery to good state,
so is there something wrong with this? and how to solve or avoid this kind of issues?
3.In KDE desktop, I can’t find source program like xfce or gnome, my admire is to config the nvidia and network card driver in this way, but no program can be found. should I need to install some apps?
