So after about playing for 10 hours or so I noticed the radio wasn’t working correctly in Fallout New Vegas, after a bit of searching found an easy fix. Use winetricks to download lavfilters, thats it now the radio should work as expected. Not sure if this is an issue with the steam version or not as I have it on GOG but if it is the fix should be similar just use protontricks instead.
