Did someone alread had this problem just after installing the os ?
It says:
See ‘systemctl status systemd-modulels-load.service’ for details.
Please run the command in a terminal and post the output back here.
It might give some forum members some clues as to what might be the issue.
Also good idea to post some specs, logs, etc.
If your bootloader is grub, then while posting the logs, please post also the contents of file /boot/grub/grub.cfg.
Nevermind , i fix my problem by addind the lts kermel , thank you for trying to help me
