… but are not full hardware RAID controllers with all RAID features implemented. Therefore, this type of RAID is sometimes called FakeRAID. dmraid from the official repositories, will be used to deal with these controllers. Here are some examples of FakeRAID controllers: Intel Rapid Storage, JMicron JMB36x RAID ROM, AMD RAID, ASMedia 106x, and NVIDIA MediaShield
I would prefer to be using RAID as that means I can have a “larger” drive, but I can deal with having it be split if needed. As it stands, I think I’m limited to finding a solution involving hardware RAID.
I’m afraid I don’t know what a disk head is. Do you mean a partition table? I’ve tried remaking it several times. As for the kernel image, that’s not on me, I’m just using the official EndeavourOS live environment, most recent version.
Is it possible to remove the raid array with mdadm? If it sees the current Raid you should be able to remove it. You have to use a command to fail it first and then you can remove it.
@killbotvii
I think maybe @BONK & @FLVAL may be right also to just use gparted and created a new GPT partition on each drive. Then the raid array should be gone.
Warning: These steps erase everything on a device, so type carefully!
If the device is being reused or re-purposed from an existing array, erase any old RAID configuration information:
# mdadm --misc --zero-superblock /dev/<drive>
or if a particular partition on a drive is to be deleted:
# mdadm --misc --zero-superblock /dev/<partition>
And here if the GPT Partition Table works :
GUID Partition Table
After creating the partitions, their partition type GUIDs should be A19D880F-05FC-4D3B-A006-743F0F84911E (it can be assigned by selecting partition type Linux RAID in fdisk or FD00 in gdisk ).
If a larger disk array is employed, consider assigning filesystem labels or partition labels to make it easier to identify an individual disk later.
Creating partitions that are of the same size on each of the devices is recommended.
I did, I selected the live ISO in gparted, that’s what he asked for. I also have good news, it looks like the installer now sees the two drives as seperate as well as as them as the RAID drive. I will note that I still cannot modify them individually in gparted.
