Failed to load the anti-cheat module
Hi,
I’m getting the following error "Failed to load the anti-cheat module " that I don’t understand why this game has to give me this error.
BTW a friend tried on Pop_Os and has no problem.
I don’t want the same error to happen on other games that use Easy Anti-Cheat.
Already check on https://areweanticheatyet.com/ and the game is on the list of “supported”.
This is the error
and these are the installed pkgs
Some others info:
OS -> EndeavourOS
-> rolling rolling
-> Linux 6.6.32-1-lts
DE/WM -> KWin (Wayland)
-> sddm-autologin 0.21.0 (Wayland)
CPU
Architecture:             x86_64
 CPU op-mode(s):         32-bit, 64-bit
 Address sizes:          46 bits physical, 48 bits virtual
 Byte Order:             Little Endian
CPU(s):                   20
 On-line CPU(s) list:    0-19
Vendor ID:                GenuineIntel
 Model name:             13th Gen Intel(R) Core(TM) i5-13600K
   CPU family:           6
   Model:                183
   Thread(s) per core:   2
   Core(s) per socket:   14
   Socket(s):            1
   Stepping:             1
   CPU(s) scaling MHz:   21%
   CPU max MHz:          5100,0000
   CPU min MHz:          800,0000
   BogoMIPS:             6991,00
   Flags:                fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc art arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf tsc_known_freq pni pclmulqdq dtes64 monitor ds_cpl vmx smx est tm2 ss se3 sdbg fma cx16 xtpr pdcm sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm 3dnowprefetch cpuid_fault epb ssbd ibrs ibpb stibp ibrs_enhanced tpr_shadow flexpriority ept vpid ept_ad fsgsbase tsc_adjust bmi1 avx2 smep bmi2 erms invpcid rdseed adx smap clflushopt clwb intel_pt sha_ni xsaveopt xsavec xgetbv1 xsaves split_lock_detect user_shstk avx_vnni dtherm ida arat pln pts hwp hwp_notify hwp_act_window hwp_epp hwp_pkg_r eq hfi vnmi umip pku ospke waitpkg gfni vaes vpclmulqdq tme rdpid movdiri movdir64b fsrm md_clear serialize pconfig arch_lbr ibt flush_l1d arch_capabilities
Game: Vampire: The Masquerade - Bloodhunt
ProtonDB: https://www.protondb.com/app/760160
Tested on ProtonDB: Experimental, 9 and 8 with DX11 or latest
What’s the game you’re trying to run?
On ProtonDB, people are talking about some unofficial patch for the game that is required for the game to work. Perhaps try that patch out?
I think they are talking about a game update, and the report is 1 yo
Ok it seems a problem related to glibc
But don’t know how to fix it
From steam…
anyidea?
Adding process 11539 for gameID 760160
Fossilize INFO: Overriding serialization path: "/home/blackpraedicator/.local/share/Steam/steamapps/shadercache/760160/fozpipelinesv6/steamapprun_pipeline_cache".
wine: setpriority 3 for pid -1 failed: 3
Fossilize WARN: Pipeline library handle 0xffffffffe875e918 is not registered.
It has either not been recorded, or it failed to be recorded earlier (which is expected if application uses an extension that is not recognized by Fossilize).
GameOverlay: started '/home/blackpraedicator/.local/share/Steam/ubuntu12_32/gameoverlayui' (pid 11587) for game process 11539
06/15 20:43:33 minidumps folder is set to /tmp/dumps
06/15 20:43:33 Init: Installing breakpad exception handler for appid(gameoverlayui)/version(20240613183916)/tid(11587)
06/15 20:43:33 Init: Installing breakpad exception handler for appid(gameoverlayui)/version(1.0)/tid(11587)
