[FAILED] Failed to mount /boot/efi (due to some important system package removals)
After today’s update it shows this on boot screen. Not sure how much damage has been done due to this mistake.
  • cat /etc/fstab
# <file system>             <mount point>  <type>  <options>  <dump>  <pass>
UUID=93AD-C341                            /efi           vfat    defaults,noatime 0 2
UUID=d9cfe184-7867-44b4-9039-a6e8510950e9 /              ext4    defaults,noatime 0 1
UUID=d504206f-2a25-4aec-a99d-f9d32057ef15 swap           swap    defaults   0 0
  • sudo parted -l
sudo: unable to find terminal name for device 136, 1
Model: ATA ST1000DM003-1SB1 (scsi)
Disk /dev/sda: 1000GB
Sector size (logical/physical): 512B/4096B
Partition Table: gpt
Disk Flags:
Number  Start   End     Size    File system     Name         Flags
 1      2097kB  1051MB  1049MB  fat32                        boot, esp
 2      1051MB  991GB   990GB   ext4            endeavouros
 4      991GB   1000GB  9449MB  linux-swap(v1)               swap
Model: hp v236w (scsi)
Disk /dev/sdb: 31.0GB
Sector size (logical/physical): 512B/512B
Partition Table: msdos
Disk Flags:
Number  Start   End     Size   Type     File system  Flags
 2      2799MB  2969MB  170MB  primary  fat32        esp
  • pacman -Q | grep -E “(dracut|mkinitcpio)”
dracut 105-1
kernel-install-for-dracut 1.10.1-1
  • find /efi
/efi
  • ls /usr/lib/modules
6.10.4-arch2-1 6.11.6-arch1-1 6.6.59-1-lts
I want to know how to fix this so that next time I reinstall EOS I don’t have to face similar issues or fix it myself.
Does the fallback entry work?
What does find /efi return?(You need to mount the EFI partition before running the command)
Sorry, how do I mount that? Using gparted ?
From outside the chroot:
sudo mount /dev/sda1 /mnt/efi
From inside the chroot:
mount /dev/sda1 /efi
It gives me this error
(I’m inside the chroot root@EndeavourOS )
Oops, don’t use sudo inside the chroot.
/efi
/efi/EFI
/efi/EFI/systemd
/efi/EFI/systemd/systemd-bootx64.efi
/efi/EFI/BOOT
/efi/EFI/BOOT/BOOTX64.EFI
/efi/EFI/Linux
/efi/loader
/efi/loader/entries
/efi/loader/entries/e1d2dd3581684e4a9f82128f55dc08d1-6.11.5-arch1-1-fallback.conf
/efi/loader/entries/e1d2dd3581684e4a9f82128f55dc08d1-6.11.5-arch1-1.conf
/efi/loader/entries/e1d2dd3581684e4a9f82128f55dc08d1-6.6.5-arch1-1-fallback.conf
/efi/loader/entries/e1d2dd3581684e4a9f82128f55dc08d1-6.6.5-arch1-1.conf
/efi/loader/entries/e1d2dd3581684e4a9f82128f55dc08d1-6.6.57-1-lts-fallback.conf
/efi/loader/entries/e1d2dd3581684e4a9f82128f55dc08d1-6.6.57-1-lts.conf
/efi/loader/entries/e1d2dd3581684e4a9f82128f55dc08d1-6.11.6-arch1-1-fallback.conf
/efi/loader/entries/e1d2dd3581684e4a9f82128f55dc08d1-6.11.6-arch1-1.conf
/efi/loader/entries/e1d2dd3581684e4a9f82128f55dc08d1-6.6.59-1-lts-fallback.conf
/efi/loader/entries/e1d2dd3581684e4a9f82128f55dc08d1-6.6.59-1-lts.conf
/efi/loader/loader.conf
/efi/loader/random-seed
/efi/loader/entries.srel
/efi/e1d2dd3581684e4a9f82128f55dc08d1
/efi/e1d2dd3581684e4a9f82128f55dc08d1/6.6.59-1-lts
/efi/e1d2dd3581684e4a9f82128f55dc08d1/6.6.59-1-lts/initrd-fallback
/efi/e1d2dd3581684e4a9f82128f55dc08d1/6.6.59-1-lts/linux
/efi/e1d2dd3581684e4a9f82128f55dc08d1/6.6.5-arch1-1
/efi/e1d2dd3581684e4a9f82128f55dc08d1/6.6.5-arch1-1/initrd-fallback
/efi/e1d2dd3581684e4a9f82128f55dc08d1/6.6.5-arch1-1/linux
/efi/e1d2dd3581684e4a9f82128f55dc08d1/6.11.5-arch1-1
/efi/e1d2dd3581684e4a9f82128f55dc08d1/6.11.5-arch1-1/initrd-fallback
/efi/e1d2dd3581684e4a9f82128f55dc08d1/6.11.5-arch1-1/linux
/efi/e1d2dd3581684e4a9f82128f55dc08d1/6.11.6-arch1-1
/efi/e1d2dd3581684e4a9f82128f55dc08d1/6.11.6-arch1-1/initrd-fallback
/efi/e1d2dd3581684e4a9f82128f55dc08d1/6.11.6-arch1-1/linux
That is a mess. Remove everything under /efi/e1d2dd3581684e4a9f82128f55dc08d1 and /efi/loader/entries
The run reinstall-kernels
Done. Now everything should be okay?
It showed me in few dracut errors
Details
Installing kernel 6.11.6-arch1-1
dracut[I]: Executing: /usr/bin/dracut --no-hostonly --force /efi/e1d2dd3581684e4a9f82128f55dc08d1/6.11.6-arch1-1/initrd-fallback 6.11.6-arch1-1
dracut[I]: 35network-legacy: Could not find any command of 'arping arping2'!
dracut[I]: *** Including module: bash ***
dracut[I]: *** Including module: shell-interpreter ***
dracut[I]: *** Including module: systemd ***
dracut[I]: *** Including module: systemd-ask-password ***
dracut[I]: *** Including module: systemd-cryptsetup ***
dracut[I]: *** Including module: systemd-initrd ***
dracut[I]: *** Including module: systemd-journald ***
dracut[I]: *** Including module: systemd-modules-load ***
dracut[I]: *** Including module: systemd-pcrphase ***
dracut[I]: *** Including module: systemd-sysctl ***
dracut[I]: *** Including module: systemd-sysusers ***
dracut[I]: *** Including module: systemd-tmpfiles ***
dracut[I]: *** Including module: systemd-udevd ***
dracut[I]: *** Including module: modsign ***
dracut[I]: *** Including module: i18n ***
dracut[I]: *** Including module: drm ***
dracut[I]: *** Including module: plymouth ***
dracut[I]: *** Including module: btrfs ***
dracut[I]: *** Including module: crypt ***
dracut[I]: *** Including module: dm ***
dracut[I]: *** Including module: kernel-modules ***
dracut[I]: *** Including module: kernel-modules-extra ***
dracut[I]: *** Including module: lvm ***
dracut[I]: *** Including module: mdraid ***
dracut[I]: *** Including module: nvdimm ***
dracut[I]: *** Including module: qemu ***
dracut[I]: *** Including module: qemu-net ***
dracut[I]: *** Including module: fido2 ***
dracut[I]: *** Including module: pkcs11 ***
dracut[I]: *** Including module: hwdb ***
dracut[I]: *** Including module: lunmask ***
dracut[I]: *** Including module: resume ***
dracut[I]: *** Including module: rootfs-block ***
dracut[I]: *** Including module: terminfo ***
dracut[I]: *** Including module: udev-rules ***
dracut[I]: *** Including module: virtiofs ***
dracut[I]: *** Including module: dracut-systemd ***
dracut[I]: *** Including module: usrmount ***
dracut[I]: *** Including module: base ***
dracut[I]: *** Including module: fs-lib ***
dracut[I]: *** Including module: shutdown ***
dracut-install: ERROR: installing 'poweroff'
dracut-install: ERROR: installing 'reboot'
dracut-install: ERROR: installing 'halt'
dracut[E]: FAILED: /usr/lib/dracut/dracut-install -D /var/tmp/dracut.TCJMpD/initramfs -a umount poweroff reboot halt losetup stat sleep timeout
dracut[I]: *** Including modules done ***
dracut[I]: *** Installing kernel module dependencies ***
dracut[I]: *** Installing kernel module dependencies done ***
dracut[I]: *** Resolving executable dependencies ***
dracut[I]: *** Resolving executable dependencies done ***
dracut[I]: *** Hardlinking files ***
dracut[I]: *** Hardlinking files done ***
dracut[I]: *** Generating early-microcode cpio image ***
dracut[I]: *** Store current command line parameters ***
dracut[I]: *** Stripping files ***
dracut[I]: *** Stripping files done ***
dracut[I]: *** Creating image file '/efi/e1d2dd3581684e4a9f82128f55dc08d1/6.11.6-arch1-1/initrd-fallback' ***
dracut[I]: *** Creating initramfs image file '/efi/e1d2dd3581684e4a9f82128f55dc08d1/6.11.6-arch1-1/initrd-fallback' done ***
dracut[I]: Executing: /usr/bin/dracut --hostonly --no-hostonly-cmdline -f /efi/e1d2dd3581684e4a9f82128f55dc08d1/6.11.6-arch1-1/initrd 6.11.6-arch1-1
dracut[E]: FAILED: /usr/lib/dracut/dracut-install -D /var/tmp/dracut.T8QNE6/initramfs -a umount poweroff reboot halt losetup stat sleep timeout
dracut[I]: *** Creating image file '/efi/e1d2dd3581684e4a9f82128f55dc08d1/6.11.6-arch1-1/initrd' ***
dracut[I]: *** Creating initramfs image file '/efi/e1d2dd3581684e4a9f82128f55dc08d1/6.11.6-arch1-1/initrd' done ***
Installing kernel 6.6.59-1-lts
dracut[I]: Executing: /usr/bin/dracut --no-hostonly --force /efi/e1d2dd3581684e4a9f82128f55dc08d1/6.6.59-1-lts/initrd-fallback 6.6.59-1-lts
dracut[E]: FAILED: /usr/lib/dracut/dracut-install -D /var/tmp/dracut.LbQ3sV/initramfs -a umount poweroff reboot halt losetup stat sleep timeout
dracut[I]: *** Creating image file '/efi/e1d2dd3581684e4a9f82128f55dc08d1/6.6.59-1-lts/initrd-fallback' ***
dracut[I]: *** Creating initramfs image file '/efi/e1d2dd3581684e4a9f82128f55dc08d1/6.6.59-1-lts/initrd-fallback' done ***
dracut[I]: Executing: /usr/bin/dracut --hostonly --no-hostonly-cmdline -f /efi/e1d2dd3581684e4a9f82128f55dc08d1/6.6.59-1-lts/initrd 6.6.59-1-lts
dracut[E]: FAILED: /usr/lib/dracut/dracut-install -D /var/tmp/dracut.Topded/initramfs -a umount poweroff reboot halt losetup stat sleep timeout
dracut[I]: *** Creating image file '/efi/e1d2dd3581684e4a9f82128f55dc08d1/6.6.59-1-lts/initrd' ***
dracut[I]: *** Creating initramfs image file '/efi/e1d2dd3581684e4a9f82128f55dc08d1/6.6.59-1-lts/initrd' done ***
but otherwise looks okay.
That seems bad.
What happens if you update your system pacman -Syu
Nothing much just updated few packages. I tried reinstall-kernels again but again it shows those dracut errors.
Can I see the full output from reinstall-kernels
Sorry, here:
dracut[E]: FAILED: /usr/lib/dracut/dracut-install -D /var/tmp/dracut.jGg1lw/initramfs -a umount poweroff reboot halt losetup stat sleep timeout
dracut[E]: FAILED: /usr/lib/dracut/dracut-install -D /var/tmp/dracut.eF3bt7/initramfs -a umount poweroff reboot halt losetup stat sleep timeout
dracut[E]: FAILED: /usr/lib/dracut/dracut-install -D /var/tmp/dracut.5MJvWX/initramfs -a umount poweroff reboot halt losetup stat sleep timeout
dracut[E]: FAILED: /usr/lib/dracut/dracut-install -D /var/tmp/dracut.j8QCuR/initramfs -a umount poweroff reboot halt losetup stat sleep timeout
Can you share the output of cat /etc/dracut.conf.d/*
Also, can you run pacman -Syu base --needed
bash: /etc/dracut.conf.d/eos-defaults.conf: Permission denied
omit_dracutmodules+=" network cifs nfs brltty "
compress="zstd"
add_dracutmodules+=" resume "
[root@EndeavourOS /]# pacman -Syu base --needed
 endeavouros is up to date
 core is up to date
 extra is up to date
 multilib is up to date
resolving dependencies...
Package (5)              New Version  Net Change
core/iputils             20240905-1     0.57 MiB
core/licenses            20240728-1     1.54 MiB
core/psmisc              23.7-1         0.76 MiB
core/systemd-sysvcompat  256.7-1        0.00 MiB
core/base                3-2            0.00 MiB
Total Installed Size:  2.88 MiB
:: Proceed with installation? [Y/n]
(5/5) checking keys in keyring                                        [---------------------------------------] 100%
(5/5) checking package integrity                                      [---------------------------------------] 100%
(5/5) loading package files                                           [---------------------------------------] 100%
(5/5) checking for file conflicts                                     [---------------------------------------] 100%
:: Processing package changes...
(1/5) installing psmisc                                               [---------------------------------------] 100%
(2/5) installing licenses                                             [---------------------------------------] 100%
(3/5) installing systemd-sysvcompat                                   [---------------------------------------] 100%
(4/5) installing iputils                                              [---------------------------------------] 100%
(5/5) installing base                                                 [---------------------------------------] 100%
Optional dependencies for base
    linux: bare metal support [installed]
(1/2) Arming ConditionNeedsUpdate...
(2/2) Refreshing PackageKit...
Error connecting: Could not connect: No such file or directory
error: command failed to execute correctly
 core is up to date
 extra                                      7.5 MiB   677 KiB/s 00:11 [---------------------------------------] 100%
warning: base-3-2 is up to date -- skipping
 there is nothing to do
1st run it showed me “command failed to execute correctly” error, but on running it 2nd time no errors.
Please see my edit above:
Try running reinstall-kernels again.
I don’t see any errors now but still here is the full output.
Try rebooting
Thanks, that fixed it.
Can you please explain in simple words why/what this happened and how you fixed it for for future reference. I’ll mark your reply as the “Solution” for search engines.
