Hi all,
i’ve recently done a fresh install of endeavour, switching from manjaro. Had some issues at the beginning concerning boot time, but that was fixed by adding the kernel parameter it=off
and installing NVIDIA drivers.
Up until now, my external monitors are not working, i have connected them to my thunderbolt 3 dock via displayport, though plugging them in directly with HDMI also doesnt do anything. They are not showing up in the settings for display configuation.
I am on a lenovo p1 g4 with nvidia dedicated graphics, KDE Plasma, already installed bolt (and optimus manager)
I’ve also read on the forums already of issues with Plasma and externeal monitors. I am familliar with a bit buggieness of plasma, as i was also using it with manjaro. There my configuration was sometimes “forgotten” and the monitors were deactivated in the settings, i was able to activate them by going into the display settings, sellection the monitor and simply disabling the checkbox disabled
thoug this time, the monitors arent even recognized by my system…
Thanks in advance for any help and tricks!
My KDE version is 5.27
Edit: this is a windows dual boot machine, everything works fine with windows.
Edit 2:
Device-1: Intel TigerLake-H GT1 [UHD Graphics] driver: i915 v: kernel
Device-2: NVIDIA GA104M [GeForce RTX 3070 Mobile / Max-Q] driver: nvidia
v: 525.89.02
Device-3: Luxvisions Innotech Integrated RGB Camera type: USB
driver: uvcvideo
Display: x11 server: X.Org v: 21.1.7 with: Xwayland v: 22.1.8 driver: X:
loaded: modesetting,nvidia dri: iris gpu: i915 resolution: 3840x2400~60Hz
API: OpenGL v: 4.6 Mesa 22.3.4 renderer: Mesa Intel UHD Graphics (TGL GT1)
$ inxi -Ga
Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: Lenovo driver: i915
v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21 ports:
active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:9a60 class-ID: 0300
Device-2: NVIDIA GA104M [GeForce RTX 3070 Mobile / Max-Q] vendor: Lenovo
driver: nvidia v: 525.89.02 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2023-02) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: none empty: DP-5,DP-6,HDMI-A-2 bus-ID: 01:00.0
chip-ID: 10de:249d class-ID: 0300
driver: uvcvideo bus-ID: 3-8:2 chip-ID: 30c9:0032 class-ID: 0e02
serial: 01.00.00
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia dri: iris
gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x2400 s-dpi: 96 s-size: 1016x635mm (40.00x25.00")
s-diag: 1198mm (47.17")
Monitor-1: eDP-1 model: LG Display 0x06aa built: 2020 res: 3840x2400
hz: 60 dpi: 284 gamma: 1.2 size: 344x215mm (13.54x8.46") diag: 406mm (16")
ratio: 16:10 modes: 3840x2400
direct-render: Yes
