Hi everyone,
I have EOS installed on a laptop that I connect every day to an external monitor via USB-C. About half the time, the resolution defaults to 1080p even though the monitor is not 1080p. In fact the laptop has never been connected to a 1080p monitor, and even its own resolution is not 1080p, so I don’t know why it decided to use that setting. If I go into display settings there are no options higher than 1080p until I unplug the laptop and plug it back in, then I have to go into display settings and select the correct resolution. Any ideas what might cause this?
