Hello EOS people! Long time lurker finally deciding to post as well as I’m facing an issue that I can’t seem to solve no matter how many posts here, on reddit or the arch forums I read. (Also pardon if formatting is incorrect, doing my best to keep it tidy and organized, any suggestions on how should I update the format are appreciated!)
My system:
Operating System: EndeavourOS
KDE Plasma Version: 6.3.4
KDE Frameworks Version: 6.12.0
Qt Version: 6.9.0
Kernel Version: 6.14.2-arch1-1 (64-bit)
Graphics Platform: Wayland
Processors: 16 × AMD Ryzen 9 5900HS with Radeon Graphics
Memory: 30.7 GiB of RAM
Graphics Processor 1: AMD Radeon Graphics
Graphics Processor 2: zink Vulkan 1.4
Manufacturer: ASUSTeK COMPUTER INC.
Product Name: ROG Zephyrus G14 GA401QM_GA401QM
System Version: 1.0
My problem:
As the title states, I have an issue where if I plug an external monitor via USB-C into my laptop, no video output shows. I have verified the cable works and supports video by plugging a friends Win 11 laptop and that worked fine with the external monitor. Similarly, I remember using this port on my laptop back when I had Win 11 myself for external monitors so I am certain it is the DP enabled USB-C port (it’s on the left side of the laptop for those familiar with the machine).
What I’ve tried so far:
This was mainly chatgpt (I know I feel horrible, I should just rtfm) but even rtfm did not get me far. I started with the system as mentioned above where the second graphics processor was always stated as Zink Vulkan 1.4. This made me think that it might’ve been the issue as I have EOS on my desktop too (there I have an RTX 4070 Ti) and the graphics processor is mentioned as discreet while that is not the case on my laptopt.
Since I realized this I installed envycontrol and nvidia-inst and ran
nvidia-inst --prime
and afterwards to select the GPU/Nvidia mode only
sudo envycontrol -s nvidia
This however did not help. Following what seemed to be asked from others havinig similar issues, further I am posting outputs of:
inxi -G
Device-1: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] driver: nvidia
v: 570.133.07
Device-2: Advanced Micro Devices [AMD/ATI] Cezanne [Radeon Vega Series /
Radeon Mobile Series] driver: amdgpu v: kernel
Display: wayland server: X.org v: 1.21.1.16 with: Xwayland v: 24.1.6
compositor: kwin_wayland driver: X: loaded: amdgpu,nvidia dri: radeonsi
gpu: amdgpu resolution: 2560x1440~120Hz
API: EGL v: 1.5 drivers: kms_swrast,nouveau,nvidia,radeonsi,swrast
platforms: gbm,wayland,x11,surfaceless,device
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 25.0.3-arch1.1
renderer: AMD Radeon Graphics (radeonsi renoir ACO DRM 3.61 6.14.2-arch1-1)
API: Vulkan v: 1.4.309 drivers: N/A surfaces: xcb,xlib,wayland
de: kscreen-console,kscreen-doctor gpu: nvidia-settings,nvidia-smi
nvidia-smi
| NVIDIA-SMI 570.133.07 Driver Version: 570.133.07 CUDA Version: 12.8 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap | Memory-Usage | GPU-Util Compute M. |
| | | MIG M. |
| 0 NVIDIA GeForce RTX 3060 ... On | 00000000:01:00.0 Off | N/A |
| N/A 40C P8 752W / 60W | 49MiB / 6144MiB | 0% Default |
| | | N/A |
| Processes: |
| GPU GI CI PID Type Process name GPU Memory |
| ID ID Usage |
| 0 N/A N/A 860 G /usr/lib/Xorg 38MiB |
Hopefully I remembered to include everything I somewhat tried so far, I would be extremely grateful for anyone and everyone to help in any way they can!
EDIT #1: Remembered to mention couple more things:
- I’ve tried connecting external monitor via HDMI and that works without any issues/selecting modes, etc. etc.
- I tried switching from Wayland to X11, however to no avail, behavior was consistent no matter the window manager.
EDIT #2: Adding output of lspci that I forgot to append before (the command was executed while the external monitor was plugged in via USB-C):
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne Root Complex
00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne IOMMU
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:01.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe GPP Bridge
00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:02.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne PCIe GPP Bridge
00:02.4 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne PCIe GPP Bridge
00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir Internal PCIe GPP Bridge to Bus
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 51)
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 0
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 3
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 4
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 5
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 6
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 7
01:00.0 VGA compatible controller: NVIDIA Corporation GA106M [GeForce RTX 3060 Mobile / Max-Q] (rev a1)
01:00.1 Audio device: NVIDIA Corporation GA106 High Definition Audio Controller (rev a1)
02:00.0 Network controller: MEDIATEK Corp. MT7921 802.11ax PCI Express Wireless Network Adapter
03:00.0 Non-Volatile memory controller: SK hynix Gold P31/BC711/PC711 NVMe Solid State Drive
04:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Cezanne [Radeon Vega Series / Radeon Vega Mobile Series] (rev c4)
04:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Renoir Radeon High Definition Audio Controller
04:00.2 Encryption controller: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) Platform Security Processor
04:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne USB 3.1
04:00.4 USB controller: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne USB 3.1
04:00.5 Multimedia controller: Advanced Micro Devices, Inc. [AMD] ACP/ACP3X/ACP6x Audio Coprocessor (rev 01)
04:00.6 Audio device: Advanced Micro Devices, Inc. [AMD] Family 17h/19h/1ah HD Audio Controller
