I have a Seagate 2tb external hard drive that I had previously used formatted as NTFS in the past when I was a Windows user. I recently reformatted it as xfs and I’m running into issues. I can’t create files on the drive, nor can I move files to the drive, and Steam (I plan to download some of my larger games onto this drive) won’t detect it. The drive mounts just fine and when I run mount | grep portable
, I get /dev/sda1 on /run/media/cora/portable type xfs (rw,relatime,attr2,inode64,logbufs=8,logbsize=32k,noquota)
, indicating that it’s read-write.
The problem doesn’t occur when formatting the drive as both NTFS or exfat (however, I’d prefer to be able to format it as xfs.)
Partition & format info:
NAME TYPE SIZE PTTYPE FSTYPE
sda disk 1.8T dos
└─sda1 part 1.8T dos xfs
sdb disk 0B
sdc disk 0B
nvme0n1 disk 476.9G gpt
├─nvme0n1p1 part 1G gpt vfat
└─nvme0n1p2 part 475.9G gpt ext4
My fstab:
# 1st 2 are internal ssd
# 3rd is internal
# 4th is swap
# 5th is external drive
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=B789-852F /efi vfat fmask=0137,dmask=0027 0 2
UUID=18e4f4d2-5d50-4df2-863c-49992b4d53f4 / ext4 noatime 0 1
tmpfs /tmp tmpfs defaults,noatime,mode=1777 0 0
/swapfile none swap defaults 0 0
UUID=564a715c-0fad-4d87-9ce1-38a01ba4850e /run/media/cora/portable xfs rw,defaults,noatime,nofail 0 3
Hardware info:
Kernel: 6.13.8-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
Desktop: Xfce v: 4.20.1 tk: Gtk v: 3.24.48 wm: xfwm4 dm: SDDM
Type: Laptop System: LENOVO product: 20Y50011US v: ThinkPad X1 Extreme Gen
4i serial: <superuser required> Chassis: type: 10
Mobo: LENOVO model: 20Y50011US v: SDK0J40697 WIN
serial: <superuser required> part-nu: LENOVO_MT_20Y5_BU_Think_FM_ThinkPad
X1 Extreme Gen 4i UEFI: LENOVO v: N40ET47W (1.29 ) date: 07/31/2024
Battery:
ID-1: BAT0 charge: 73.7 Wh (99.2%) condition: 74.3/90.1 Wh (82.5%)
volts: 17.4 min: 15.5 model: SMP 5B11B79217 serial: <filter>
status: not charging
Info: 8-core model: 11th Gen Intel Core i7-11850H bits: 64 type: MT MCP
arch: Tiger Lake rev: 1 cache: L1: 640 KiB L2: 10 MiB L3: 24 MiB
Speed (MHz): avg: 3441 min/max: 800/4800 cores: 1: 3441 2: 3441 3: 3441
4: 3441 5: 3441 6: 3441 7: 3441 8: 3441 9: 3441 10: 3441 11: 3441 12: 3441
13: 3441 14: 3441 15: 3441 16: 3441 bogomips: 79872
Device-1: NVIDIA GA104M [GeForce RTX 3070 Mobile / Max-Q] vendor: Lenovo
driver: nvidia v: 570.133.07 arch: Ampere pcie: speed: 2.5 GT/s lanes: 16
ports: active: none off: HDMI-A-1,eDP-1 empty: DP-1,DP-2 bus-ID: 01:00.0
chip-ID: 10de:249d
Device-2: Luxvisions Innotech Integrated RGB Camera driver: uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 bus-ID: 3-8:6 chip-ID: 30c9:0032
Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6
compositor: xfwm4 v: 4.20.0 driver: X: loaded: nvidia unloaded: modesetting
alternate: fbdev,nouveau,nv,vesa gpu: nvidia,nvidia-nvswitch
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 3460x1080 s-dpi: 291
Monitor-1: not-matched mapped: DP-2 pos: left res: 3840x2400 hz: 60
dpi: 284 diag: 406mm (15.97")
Monitor-2: not-matched mapped: HDMI-0 pos: primary,right res: 1920x1080
hz: 60 dpi: 82 diag: 686mm (27.01")
API: EGL v: 1.5 platforms: device: 0 drv: nvidia gbm: drv: nvidia
surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland
API: OpenGL v: 4.6.0 vendor: nvidia v: 570.133.07 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce RTX 3070 Laptop GPU/PCIe/SSE2
API: Vulkan v: 1.4.309 surfaces: xcb,xlib device: 0 type: discrete-gpu
driver: N/A device-ID: 10de:249d
Info: Tools: api: clinfo, eglinfo, glxinfo, vulkaninfo de: kscreen-console,
kscreen-doctor, xfce4-display-settings gpu: nvidia-smi wl: wayland-info
x11: xdpyinfo, xprop, xrandr
Device-1: Intel Tiger Lake-H HD Audio vendor: Lenovo
driver: sof-audio-pci-intel-tgl bus-ID: 00:1f.3 chip-ID: 8086:43c8
Device-2: NVIDIA GA104 High Definition Audio vendor: Lenovo
bus-ID: 01:00.1 chip-ID: 10de:228b
Device-3: DisplayLink Plugable UD-3900PDH driver: cdc_ncm,snd-usb-audio
type: USB rev: 3.2 speed: 5 Gb/s lanes: 1 bus-ID: 2-2.1:3 chip-ID: 17e9:4323
Device-4: Samson GoMic compact condenser mic
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 bus-ID: 3-1:2 chip-ID: 17a0:0305
API: ALSA v: k6.13.8-arch1-1 status: kernel-api
Server-1: PipeWire v: 1.4.1 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin
Device-1: Intel Wi-Fi 6E AX210/AX1675 2x2 [Typhoon Peak] driver: iwlwifi
v: kernel pcie: speed: 5 GT/s lanes: 1 bus-ID: 09:00.0 chip-ID: 8086:2725
IF-ID-1: enp0s13f0u2u1i5 state: up speed: 1000 Mbps duplex: half
mac: <filter>
Bluetooth:
Device-1: Intel AX210 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 bus-ID: 3-14:10 chip-ID: 8087:0032
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.3
lmp-v: 12
Local Storage: total: 2.29 TiB used: 342.09 GiB (14.6%)
ID-1: /dev/nvme0n1 vendor: Samsung model: MZVL2512HCJQ-00BL7
size: 476.94 GiB speed: 63.2 Gb/s lanes: 4 serial: <filter> temp: 50.9 C
ID-2: /dev/sda vendor: Seagate model: Portable size: 1.82 TiB type: USB
rev: 3.0 spd: 5 Gb/s lanes: 1 serial: <filter>
ID-1: / size: 467.4 GiB used: 306.04 GiB (65.5%) fs: ext4
dev: /dev/nvme0n1p2
ID-1: swap-1 type: file size: 8 GiB used: 4.12 GiB (51.5%) priority: -2
file: /swapfile
System Temperatures: cpu: 67.0 C mobo: N/A
Fan Speeds (rpm): fan-1: 3171 fan-2: 2781
Memory: total: 16 GiB note: est. available: 15.39 GiB
used: 10.71 GiB (69.6%)
Processes: 452 Power: uptime: 2d 25m wakeups: 0 Init: systemd v: 257
default: graphical
Packages: pm: pacman pkgs: 1400 Compilers: gcc: 14.2.1 Shell: Bash
v: 5.2.37 running-in: xfce4-terminal inxi: 3.3.37
