External display not detected after sleep via Thunderbolt
After sleep my external display doesn’t wake up.
I tried to Google this problem extensively, without finding anything helpful. So I’d like to ask for help here.
It starts working if I do the following steps:
  1. unplug the monitor
  2. set the xrandr config to only built-in display
  3. plug back in the display
  4. Adjust the xrandr config once more
If there’s no fix to this, maybe there’s a workaround command, I could execute to force waking up the display without unplugging it every time?
In the systemctl logs I get the following message, when I try to unplug and plug back in the display via Thunderbolt:
Jan 19 08:00:46 <my-pc-name> kernel: ucsi_acpi USBC000:00: UCSI_GET_PDOS failed (-95)
Jan 19 08:00:46 <my-pc-name> kernel: usb 3-5: new high-speed USB device number 18 using xhci_hcd
Jan 19 08:00:46 <my-pc-name> kernel: usb 3-5: New USB device found, idVendor=0451, idProduct=8142, bcdDevice= 1.00
Jan 19 08:00:46 <my-pc-name> kernel: usb 3-5: New USB device strings: Mfr=0, Product=0, SerialNumber=1
Jan 19 08:00:46 <my-pc-name> kernel: usb 3-5: SerialNumber: EE050061DE91
Jan 19 08:00:46 <my-pc-name> kernel: hub 3-5:1.0: USB hub found
Jan 19 08:00:46 <my-pc-name> kernel: hub 3-5:1.0: 4 ports detected
Jan 19 08:00:47 <my-pc-name> kernel: usb 3-5.4: new full-speed USB device number 19 using xhci_hcd
Jan 19 08:00:47 <my-pc-name> kernel: usb 3-5.4: New USB device found, idVendor=043e, idProduct=9a39, bcdDevice= 2.03
Jan 19 08:00:47 <my-pc-name> kernel: usb 3-5.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jan 19 08:00:47 <my-pc-name> kernel: usb 3-5.4: Product: USB Controls
Jan 19 08:00:47 <my-pc-name> kernel: usb 3-5.4: Manufacturer: LG Electronics Inc.
Jan 19 08:00:47 <my-pc-name> kernel: usb 3-5.4: SerialNumber: 010NTPCDR160
Jan 19 08:00:47 <my-pc-name> kernel: hid-generic 0003:043E:9A39.000C: hiddev99,hidraw7: USB HID v1.11 Device [LG Electronics Inc. USB Controls] on usb-0000:00:14.0-5.4/input0
Jan 19 08:00:47 <my-pc-name> kernel: cdc_acm 3-5.4:1.1: ttyACM0: USB ACM device
Jan 19 08:00:47 <my-pc-name> mtp-probe[53567]: checking bus 3, device 19: "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-5/3-5.4"
Jan 19 08:00:47 <my-pc-name> mtp-probe[53567]: bus: 3, device: 19 was not an MTP device
Jan 19 08:00:47 <my-pc-name> mtp-probe[53571]: checking bus 3, device 19: "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-5/3-5.4"
Jan 19 08:00:47 <my-pc-name> mtp-probe[53571]: bus: 3, device: 19 was not an MTP device
Jan 19 08:01:04 <my-pc-name> kernel: usb 3-5.4: USB disconnect, device number 19
Jan 19 08:01:06 <my-pc-name> kernel: usb 3-5: USB disconnect, device number 18
Jan 19 08:01:11 <my-pc-name> kernel: usb 3-5: new high-speed USB device number 20 using xhci_hcd
Also when trying to execute the following xrandr command I get an error xrandr: cannot find mode 3840x2160:
xrandr --output eDP-1-1 --mode 1920x1080 --pos 0x540 --rotate normal --output HDMI-1-1 --off --output DP-1-1 --scale 0.75x0.75 --mode 3840x2160 --pos 1920x0 --rotate normal --output DP-1-2 --off --output DP-1-3 --off --output DP-1-4 --off
The problem occurs both when using Intel as well as Nvidia GPU.
  Device-1: Intel Alder Lake-P Integrated Graphics vendor: Lenovo driver: i915
    v: kernel arch: Gen-12.2 ports: active: eDP-1 empty: DP-1, DP-2, DP-3,
    DP-4, HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:46a6
  Device-2: NVIDIA GA107M [GeForce RTX 3050 Mobile] vendor: Lenovo
    driver: nvidia v: 525.78.01 arch: Ampere pcie: speed: 2.5 GT/s lanes: 8
    bus-ID: 01:00.0 chip-ID: 10de:25a2
  Device-3: Chicony Integrated Camera type: USB driver: uvcvideo
    bus-ID: 3-4:5 chip-ID: 04f2:b6be
  Display: x11 server: X.Org v: 21.1.6 with: Xwayland v: 22.1.7 driver: X:
    loaded: modesetting,nvidia dri: iris gpu: i915 display-ID: :0 screens: 1
  Screen-1: 0 s-res: 4800x1620 s-dpi: 128
  Monitor-1: eDP-1 mapped: eDP-1-1 model: BOE Display 0x098e res: 1920x1080
    dpi: 142 diag: 395mm (15.5")
  API: OpenGL v: 4.6.0 NVIDIA 525.78.01 renderer: NVIDIA GeForce RTX 3050
    Laptop GPU/PCIe/SSE2 direct render: Yes
Optimus xorg.config:
Section "Files"
	ModulePath "/usr/lib/nvidia"
	ModulePath "/usr/lib32/nvidia"
	ModulePath "/usr/lib32/nvidia/xorg/modules"
	ModulePath "/usr/lib32/xorg/modules"
	ModulePath "/usr/lib64/nvidia/xorg/modules"
	ModulePath "/usr/lib64/nvidia/xorg"
	ModulePath "/usr/lib64/xorg/modules"
EndSection
Section "ServerLayout"
	Identifier "layout"
	Screen 0 "nvidia"
	Inactive "integrated"
EndSection
Section "Device"
	Identifier "nvidia"
	Driver "nvidia"
	BusID "PCI:1:0:0"
	Option "Coolbits" "28"
EndSection
Section "Screen"
	Identifier "nvidia"
	Device "nvidia"
	Option "AllowEmptyInitialConfiguration"
EndSection
Section "Device"
	Identifier "integrated"
	Driver "modesetting"
	BusID "PCI:0:2:0"
EndSection
Section "Screen"
	Device "integrated"
EndSection
Here are some more systemctl logs, while unplugging the cable and plugging it back and resetting the xrand config. It’s quite definitely not the cable, because it works on my Ubuntu Laptop. Screen always wakes up after sleep.
Jan 19 08:24:50 <my-pc-name> mtp-probe[86038]: bus: 3, device: 23 was not an MTP device
Jan 19 08:24:50 <my-pc-name> kernel: i915 0000:00:02.0: [drm] *ERROR* failed to enable link training
Jan 19 08:24:53 <my-pc-name> kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Jan 19 08:24:58 <my-pc-name> kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Jan 19 08:24:58 <my-pc-name> kernel: usb usb2-port1: attempt power cycle
Jan 19 08:25:03 <my-pc-name> kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Jan 19 08:25:05 <my-pc-name> kernel: i915 0000:00:02.0: [drm] *ERROR* Timeout waiting for DDI BUF D to get active
Jan 19 08:25:07 <my-pc-name> kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Jan 19 08:25:07 <my-pc-name> kernel: usb usb2-port1: unable to enumerate USB device
Jan 19 08:25:08 <my-pc-name> kernel: usb 3-5.4: USB disconnect, device number 23
Jan 19 08:25:14 <my-pc-name> kernel: usb 3-5: USB disconnect, device number 22
Jan 19 08:25:21 <my-pc-name> kernel: ucsi_acpi USBC000:00: UCSI_GET_PDOS failed (-95)
Jan 19 08:25:33 <my-pc-name> kernel: i915 0000:00:02.0: [drm] *ERROR* failed to enable link training
Jan 19 08:25:37 <my-pc-name> kernel: ucsi_acpi USBC000:00: UCSI_GET_PDOS failed (-95)
Jan 19 08:25:37 <my-pc-name> kernel: usb 3-5: new high-speed USB device number 24 using xhci_hcd
Jan 19 08:25:37 <my-pc-name> kernel: usb 3-5: New USB device found, idVendor=0451, idProduct=8142, bcdDevice= 1.00
Jan 19 08:25:37 <my-pc-name> kernel: usb 3-5: New USB device strings: Mfr=0, Product=0, SerialNumber=1
Jan 19 08:25:37 <my-pc-name> kernel: usb 3-5: SerialNumber: EE050061DE91
Jan 19 08:25:37 <my-pc-name> kernel: hub 3-5:1.0: USB hub found
Jan 19 08:25:37 <my-pc-name> kernel: hub 3-5:1.0: 4 ports detected
Jan 19 08:25:38 <my-pc-name> kernel: usb 3-5.4: new full-speed USB device number 25 using xhci_hcd
Jan 19 08:25:38 <my-pc-name> kernel: usb 3-5.4: New USB device found, idVendor=043e, idProduct=9a39, bcdDevice= 2.03
Jan 19 08:25:38 <my-pc-name> kernel: usb 3-5.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jan 19 08:25:38 <my-pc-name> kernel: usb 3-5.4: Product: USB Controls
Jan 19 08:25:38 <my-pc-name> kernel: usb 3-5.4: Manufacturer: LG Electronics Inc.
Jan 19 08:25:38 <my-pc-name> kernel: usb 3-5.4: SerialNumber: 010NTPCDR160
Jan 19 08:25:38 <my-pc-name> mtp-probe[87092]: checking bus 3, device 25: "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-5/3-5.4"
Jan 19 08:25:38 <my-pc-name> mtp-probe[87092]: bus: 3, device: 25 was not an MTP device
Jan 19 08:25:38 <my-pc-name> kernel: hid-generic 0003:043E:9A39.000F: hiddev99,hidraw7: USB HID v1.11 Device [LG Electronics Inc. USB Controls] on usb-0000:00:14.0-5.4/input0
Jan 19 08:25:38 <my-pc-name> kernel: cdc_acm 3-5.4:1.1: ttyACM0: USB ACM device
Jan 19 08:25:38 <my-pc-name> mtp-probe[87096]: checking bus 3, device 25: "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-5/3-5.4"
Jan 19 08:25:38 <my-pc-name> mtp-probe[87096]: bus: 3, device: 25 was not an MTP device
Jan 19 08:25:42 <my-pc-name> kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Jan 19 08:25:46 <my-pc-name> kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Jan 19 08:25:46 <my-pc-name> kernel: usb usb2-port1: attempt power cycle
Jan 19 08:25:51 <my-pc-name> kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Jan 19 08:25:55 <my-pc-name> kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Jan 19 08:25:55 <my-pc-name> kernel: usb usb2-port1: unable to enumerate USB device
Have you tried disabling usb auto suspend? Not sure if you are using grub or systemd-boot.
Hi ricklinux,
thank you for your suggestion. I use systemd-boot. Is that a kernel parameter?
I found this Arch Wiki article, where I can disable the auto-suspend for a specific device, but I’m not sure where to get the idVendor or idProduct for the thunderbolt. I don’t find such a value in lshw.
I currently have the same problem running sway/grub. Apparently it is related to something in the kernel, a temporary fix can be found here (haven’t tested it myself yet):
https://bbs.archlinux.org/viewtopic.php?id=281375
My current workaround: don’t suspend my laptop while on an external display :smiley:
This is a complicated issue on a complicated system :smile: (Optimus).
I would first ask what your DE says about it. DE is important on this, so give more info.
Also,
  • are there any other USB devices that cannot wake up after sleep?
  • is there a difference when suspension is forced, in comparison to idle/timeout auto suspend?
If the issue is not strictly related to an USB issue, you may try:
xrandr --auto
Get status report from these:
xrandr --listproviders
xrandr --listactivemonitors
xrandr --listmonitors
For troubleshooting, I suggest you start from a good state (all monitors working), and:
  • Get status report
  • Suspend and wake
  • Get status report
  • Run xrandr --auto
  • Get status report
  • Repeat with timeout suspend
If nothing helps, try the linked workaround (blacklist ucsi_acpi).
I leave this last, since this module may have other functions that may be missed if it is disabled. :person_shrugging:
Yes you can use a kernel parameter with systemd-boot. Add it to /etc/kernel/cmdline and then run sudo reinstall-kernels
You would need to add
usbcore.autosuspend=-1
The other way from the Arch wiki:
To allow autosuspend only for devices that are known to work, use simple matching against vendor and product IDs (use lsusb to get these values):
❯ i3 --moreversion 2>&- || i3 --version
Binary i3 version:  4.22 (2023-01-02) © 2009 Michael Stapelberg and contributors
Running i3 version: 4.22 (2023-01-02) (pid 2814)
Loaded i3 config:
  /home/rai/.config/i3/config (main) (last modified: Sa 14 Jan 2023 17:55:06 CET, 430717 seconds ago)
The i3 binary you just called: /usr/bin/i3
The i3 binary you are running: i3
  • No there is no differece between suspension idle/timeout. Also when turning off the display manually and turning it back on, the signal from the laptop is lost and can only be regained after reconnecting the cable and calling xrandr.
  • Other USB device seem to have no problem. Only the display.
  • xrandr --auto doesn’t wake the monitor.
External Monitor on:
❯ xrandr --listactivemonitors
Monitors: 2
 0: +eDP-1-1 1920/344x1080/194+0+540  eDP-1-1
 1: +DP-1-1 2880/600x1620/340+1920+0  DP-1-1
❯ xrandr --listmonitors
Monitors: 2
❯ xrandr --listproviders
Providers: number : 2
Provider 0: id: 0x1b7 cap: 0x1, Source Output crtcs: 0 outputs: 0 associated providers: 1 name:NVIDIA-0
Provider 1: id: 0x1e0 cap: 0xf, Source Output, Sink Output, Source Offload, Sink Offload crtcs: 4 outputs: 6 associated providers: 1 name:modesetting
External monitor off:
Monitors: 2
 1: +DP-1-1 2880/762x1620/429+1920+0  DP-1-1
Monitors: 2
  • /var/log/Xorg.0.log doesn’t say much, only logs the times, when the monitor was connected succesfully.
  • And i3wm log dump doesn’t seem to produce anything useful in this matter neither.
19.01.2023 17:49:31 - _NET_WM_NAME changed to "Terminal - i3-dump-log | grep --color=auto  -i "DP-""
19.01.2023 17:49:32 - _NET_WM_NAME changed to "Terminal - i3-dump-log | grep --color=auto  -i "DP-""
19.01.2023 17:49:33 - _NET_WM_NAME changed to "Terminal - i3-dump-log | grep --color=auto  -i "DP-""
19.01.2023 17:49:34 - _NET_WM_NAME changed to "Terminal - i3-dump-log | grep --color=auto  -i "DP-""
19.01.2023 17:49:50 - ../src/render.c:render_con:49 - Rendering node 0x56340ee1c8d0 / eDP-1-1 / layout 4 / children 3
19.01.2023 17:49:56 - ../src/randr.c:randr_query_outputs_15:680 - name eDP-1-1, x 0, y 0, width 1920 px, height 1080 px, width 344 mm, height 194 mm, primary 0, automatic 1
19.01.2023 17:49:56 - ../src/randr.c:randr_query_outputs:935 - output 0x56340ee2cc00 / eDP-1-1, position (0, 0), checking for clones
19.01.2023 17:49:56 - ../src/randr.c:randr_disable_output:1048 - Output DP-1-1 disabled, re-assigning workspaces/docks
19.01.2023 17:49:56 - ../src/render.c:render_con:49 - Rendering node 0x56340ee1c8d0 / eDP-1-1 / layout 4 / children 3
19.01.2023 17:49:56 - ../src/scratchpad.c:scratchpad_fix_resolution:259 - output eDP-1-1's resolution: (0, 0) 1920 x 1080
19.01.2023 17:49:56 - WM_NAME changed to "i3bar for output eDP-1-1"
19.01.2023 17:49:56 - ../src/manage.c:manage_window:252 - Starting search at output eDP-1-1
19.01.2023 17:49:57 - ../src/randr.c:randr_query_outputs_15:680 - name eDP-1-1, x 0, y 0, width 1920 px, height 1080 px, width 344 mm, height 194 mm, primary 0, automatic 1
19.01.2023 17:49:57 - ../src/randr.c:randr_query_outputs:935 - output 0x56340ee2cc00 / eDP-1-1, position (0, 0), checking for clones
19.01.2023 17:49:57 - ../src/randr.c:randr_disable_output:1048 - Output DP-1-1 disabled, re-assigning workspaces/docks
19.01.2023 17:49:57 - ../src/render.c:render_con:49 - Rendering node 0x56340ee1c8d0 / eDP-1-1 / layout 4 / children 3
19.01.2023 17:49:57 - ../src/scratchpad.c:scratchpad_fix_resolution:259 - output eDP-1-1's resolution: (0, 0) 1920 x 1080
19.01.2023 17:49:57 - WM_NAME changed to "i3bar for output eDP-1-1"
19.01.2023 17:49:57 - ../src/manage.c:manage_window:252 - Starting search at output eDP-1-1
19.01.2023 17:49:58 - ../src/render.c:render_con:49 - Rendering node 0x56340ee1c8d0 / eDP-1-1 / layout 4 / children 3
19.01.2023 17:49:59 - ../src/render.c:render_con:49 - Rendering node 0x56340ee1c8d0 / eDP-1-1 / layout 4 / children 3
19.01.2023 17:50:00 - ../src/render.c:render_con:49 - Rendering node 0x56340ee1c8d0 / eDP-1-1 / layout 4 / children 3
19.01.2023 17:50:00 - ../src/randr.c:randr_query_outputs_15:680 - name eDP-1-1, x 0, y 0, width 1920 px, height 1080 px, width 344 mm, height 194 mm, primary 0, automatic 1
19.01.2023 17:50:00 - ../src/randr.c:randr_query_outputs:935 - output 0x56340ee2cc00 / eDP-1-1, position (0, 0), checking for clones
19.01.2023 17:50:00 - ../src/randr.c:randr_disable_output:1048 - Output DP-1-1 disabled, re-assigning workspaces/docks
19.01.2023 17:50:00 - ../src/scratchpad.c:scratchpad_fix_resolution:259 - output eDP-1-1's resolution: (0, 0) 1920 x 1080
19.01.2023 17:50:00 - WM_NAME changed to "i3bar for output eDP-1-1"
19.01.2023 17:50:00 - ../src/manage.c:manage_window:252 - Starting search at output eDP-1-1
19.01.2023 17:50:01 - ../src/render.c:render_con:49 - Rendering node 0x56340ee1c8d0 / eDP-1-1 / layout 4 / children 3
19.01.2023 17:50:01 - ../src/randr.c:randr_query_outputs_15:680 - name eDP-1-1, x 0, y 0, width 1920 px, height 1080 px, width 344 mm, height 194 mm, primary 0, automatic 1
19.01.2023 17:50:01 - ../src/randr.c:randr_query_outputs:935 - output 0x56340ee2cc00 / eDP-1-1, position (0, 0), checking for clones
19.01.2023 17:50:01 - ../src/randr.c:randr_disable_output:1048 - Output DP-1-1 disabled, re-assigning workspaces/docks
19.01.2023 17:50:01 - ../src/scratchpad.c:scratchpad_fix_resolution:259 - output eDP-1-1's resolution: (0, 0) 1920 x 1080
19.01.2023 17:50:01 - WM_NAME changed to "i3bar for output eDP-1-1"
19.01.2023 17:50:01 - ../src/manage.c:manage_window:252 - Starting search at output eDP-1-1
19.01.2023 17:50:10 - ../src/randr.c:randr_query_outputs_15:680 - name eDP-1-1, x 0, y 540, width 1920 px, height 1080 px, width 344 mm, height 194 mm, primary 0, automatic 1
19.01.2023 17:50:10 - ../src/randr.c:randr_query_outputs_15:680 - name DP-1-1, x 1920, y 0, width 2880 px, height 1620 px, width 600 mm, height 340 mm, primary 0, automatic 1
19.01.2023 17:50:10 - ../src/randr.c:randr_query_outputs:935 - output 0x56340ee2cc00 / eDP-1-1, position (0, 540), checking for clones
19.01.2023 17:50:10 - ../src/randr.c:randr_query_outputs:935 - output 0x56340ee27190 / DP-1-1, position (1920, 0), checking for clones
19.01.2023 17:50:10 - ../src/randr.c:randr_query_outputs:977 - Need to initialize a Con for output DP-1-1
19.01.2023 17:50:10 - ../src/randr.c:output_init_con:338 - init_con for output DP-1-1
19.01.2023 17:50:10 - ../src/randr.c:randr_query_outputs:1018 - Should add ws for output DP-1-1
19.01.2023 17:50:10 - ../src/workspace.c:get_assigned_output:93 - Found workspace name="1:" assignment to output "eDP-1"
19.01.2023 17:50:10 - ../src/render.c:render_con:49 - Rendering node 0x56340ee1c8d0 / eDP-1-1 / layout 4 / children 3
19.01.2023 17:50:10 - ../src/render.c:render_con:49 - Rendering node 0x56340eda9de0 / DP-1-1 / layout 4 / children 3
19.01.2023 17:50:10 - ../src/x.c:x_push_node:895 - pushing name [i3 con] output DP-1-1 for con 0x56340eda9de0
19.01.2023 17:50:10 - ../src/x.c:x_push_node:895 - pushing name [i3 con] content DP-1-1 for con 0x56340ee24980
19.01.2023 17:50:10 - ../src/x.c:x_push_node:895 - pushing name [i3 con] top dockarea DP-1-1 for con 0x56340eda9fe0
19.01.2023 17:50:10 - ../src/x.c:x_push_node:895 - pushing name [i3 con] bottom dockarea DP-1-1 for con 0x56340ee20940
19.01.2023 17:50:10 - ../src/scratchpad.c:scratchpad_fix_resolution:259 - output eDP-1-1's resolution: (0, 540) 1920 x 1080
19.01.2023 17:50:10 - ../src/scratchpad.c:scratchpad_fix_resolution:259 - output DP-1-1's resolution: (1920, 0) 2880 x 1620
19.01.2023 17:50:11 - ../src/render.c:render_con:49 - Rendering node 0x56340ee1c8d0 / eDP-1-1 / layout 4 / children 3
19.01.2023 17:50:11 - ../src/render.c:render_con:49 - Rendering node 0x56340eda9de0 / DP-1-1 / layout 4 / children 3
19.01.2023 17:50:11 - WM_NAME changed to "i3bar for output DP-1-1"
19.01.2023 17:50:11 - ../src/manage.c:manage_window:252 - Starting search at output DP-1-1
19.01.2023 17:50:11 - WM_NAME changed to "i3bar for output eDP-1-1"
19.01.2023 17:50:11 - ../src/manage.c:manage_window:252 - Starting search at output eDP-1-1
19.01.2023 17:50:13 - ../src/render.c:render_con:49 - Rendering node 0x56340ee1c8d0 / eDP-1-1 / layout 4 / children 3
19.01.2023 17:50:13 - ../src/render.c:render_con:49 - Rendering node 0x56340eda9de0 / DP-1-1 / layout 4 / children 3
19.01.2023 17:50:14 - ../src/render.c:render_con:49 - Rendering node 0x56340ee1c8d0 / eDP-1-1 / layout 4 / children 3
19.01.2023 17:50:14 - ../src/render.c:render_con:49 - Rendering node 0x56340eda9de0 / DP-1-1 / layout 4 / children 3
19.01.2023 17:50:15 - _NET_WM_NAME changed to "Terminal - i3-dump-log | grep --color=auto  -i "DP-""
19.01.2023 17:50:15 - ../src/render.c:render_con:49 - Rendering node 0x56340ee1c8d0 / eDP-1-1 / layout 4 / children 3
19.01.2023 17:50:15 - ../src/render.c:render_con:49 - Rendering node 0x56340eda9de0 / DP-1-1 / layout 4 / children 3
19.01.2023 17:51:03 - _NET_WM_NAME changed to "Terminal - i3-dump-log | grep --color=auto  -i "DP-""
19.01.2023 17:51:04 - _NET_WM_NAME changed to "Terminal - i3-dump-log | grep --color=auto  -i "DP-""
I’m assuming you are running display port cable to the monitor? Have you tried shutting down. Unplug the monitor form the power source for almost 1 minute then plug back in. This is worth trying as simple as it seems. It may not work in your situation but one doesn’t know until you try.
I’m using USB-C Thunderbolt cable, that came originally with the monitor.
Still I tried, yet no success.
HDMI connection doesn’t have this problem. Only the USB-C Thunderbolt does.
For personal reasons, I would prefer to use USB-C.
Have you checked Archwiki?
Try this (as root, not with sudo):
echo 1 > /sys/bus/pci/rescan
Also check your BIOS settings
Are you using a Thunderbolt dock?
@petsam somehow I missed that particular page. I will look into it. However, the command doesn’t seem to help.
@ricklinux no docking station or adapter - directly plugged into the laptop.
@vraimonds
Maybe read through this…
https://docs.kernel.org/admin-guide/thunderbolt.html#forcing-power
Not much I could find in bios. I turned off PCIe Tunneling. But also this seems to have no effect @petsam .
Thanks for the recommendations @ricklinux and @petsam. I gotta go now, so I will read up on them later and report back, in case I find out anything new.
Next time you test it again, have another terminal logging:
journalctl -f --no-hostname
and also check Xorg log.
Look for BIOS/firmware updates from your vendor, as it looks like a HW issue, or you may report upstream to the kernel bug tracker.
I would also look through sudo dmesg for error messages related to this.
