Hey folks, just switched from debian to endeavour here, and as the title says, my ethernet speed is very slow. it went from 800Mbps to 80. I’ve already tried numerous things like changing my DNS to 1.1.1.1, disabling ipv6, setting “metered” to no, link negotiation to automatic, using reflector simple to update my mirrors, but nothing seems to work. Could someone provide a solution ?
Welcome to the community @Arrox78 ![]()
Try connecting to your network in a different way, to try and isolate a possible adaptor issue. If you’re connecting via WiFi, try via LAN cable, or visa-versa.
I don’t suggest this as a “solution”, rather, a troubleshooting step to isolate the issue.
thanks for the quick reply. I tried to connect through wifi but my network is still anormaly slow.
Fixed the problem ! I had a bad configuration on one of my uplinks on my switch. thanks again for your response earlier
